Technical *** September 2015 Banger Meet - Shadows Getting Longer in the North ***
Discussion in 'Traditional Hot Rods' started by Jiminy, Sep 1, 2015.
  1. Jiminy
    Jiminy
    Here is the banger link list .
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Flat Ernie maintains the monthly link list. Every month is listed:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    Post #105 of link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=6
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://www.centuryperformance.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    http://www.scribd.com/doc/22469332/The-High-Speed-Internal-Combustion-Engine-Ricardo-1931
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    kozmo likes this.
  2. Binger
    Binger
    from wyoming
    Thanks for the link to the new meet!!!
  3. Thanks Jiminy, just checking in.
  4. hot-irons
    hot-irons
    Hey guys. Let me jump into September with an update from my engine builder.
    This guy is the real deal!
  5. Crazydaddyo
    Crazydaddyo
    Thanks for the links.
  6. denis4x4
    denis4x4
    from Colorado
    In the process of putting a Weber on my banger.
  7. chopnchaneled
    chopnchaneled
    from Buford Ga.
    In the process of getting babbit poured for my mains on my B engine after getting the block
    pressure checked.
    Have been thinking of going to an A block and getting the crank turned down, then decided to
    give the this B block a chance after talking to Putt Smith, He said just put a mechanical gauge
    on it and don't let it get hot and it should last.
    Stay Tuned
  8. Hi, anybody here going to the Auburn Ca. Hill Climb on the 26th of this month?
  9. jim1932
    jim1932
    ok.. umm is this an option? I guess I will save the cash and run my model B head until I can get a winfield on it.
  10. blgitn
    blgitn
    Is it a DCOE? I'd like to see that! I have a pair of them on my GTV and am building Triples for my Hudson
    R/ Roger.
  11. Ummm, looks like it might leak a little.
    Send pics as they come, J
  12. waxhead
    waxhead
    from West Oz
    I believe there are still some lion speed 3 heads in stock at the moment if you want one. Not sure how many are left though.
    http://www.secretsofspeed.com/lion-speed-head.htm
  13. waxhead
    waxhead
    from West Oz
    What can you tell us about the engine??
  14. denis4x4
    denis4x4
    from Colorado
    No, I'm using the 32/36. I do have an A project involving an 1800 cc OHC Ford Courier engine with a pair 42 DCOE Webers. Image 1.jpg
  15. blgitn
    blgitn
    Dang! That oughta git it!
  16. Im running was running a stock B head on my A motor earlyer this year, such a beter engine then the model A head, i will try to mill of a few MM's of the B head before the new engine is in and give an update, but i destroyed my bearings during a roadtrip, so it might take a while.. :p
  17. hot-irons
    hot-irons
    It's a full pressure counterweighted B motor with a big cam and a '27 Chevy head.
  18. hot-irons,
    Sounds like a fun build, but don't use that '27 head! The single exhaust heads are prone to cracking- not a matter of if, but when, and they don't flow well at all. Keep your eyes out for a good '28 head- it'll be worth the wait!
    hot-irons likes this.
  19. Hi, I have a friend with a big stack of them heads. He's in Anderson Ca.
    His name is Greg Sabourin. Great guy! http://www.jernthunderbolt.com/ (R.I.P. Neil Jern)
    Joe
  20. hot-irons
    hot-irons
    Maybe I'm wrong on the year. It has two intake ports on one side and two exhaust on the other. Is that the later style head you are talking about?
  21. orangeamcs
    orangeamcs
    Just got my fresh model b distributor for my trog car. Now I can install my lion head and that this weekend. If in just installed the distributor hoe much of a driveability improvement would I see. Also have a dual updraft intake for it but I am waiting on the b carbs to come back from rebuilder.
  22. I think you have the 28 head!:D
  23. You do have a '28 head- looking forward to seeing your progress!!!
  24. X2!
    Hey hot-irons, are you gonna be running single or dual carbs?
  25. winduptoy
    winduptoy
    If you had a good A distributor set up changing to a stock B dizzy all by its self and no other changes, not much change in the drivability. Compression increase is going to be the biggest change when you get enough fuel to it.
  26. hot-irons
    hot-irons
    Ummmm. Both.
    Jet96, out plowing and Kjell Elias like this.
  27. Wow! is that photo shopped or is that real? Have they been grafted together to make a 4 barrel?
    I can't wait to see your intake manifold!:D
  28. hot-irons
    hot-irons
    Thats the real deal sir. The fella I got it from used to wrench for Ak Miller.
    He made two of these for the El Cabilero Mexico road race because he didn't like the Carter wcfb.
    Jet96 likes this.
  29. hot-irons
    hot-irons
    Newens equip co magneto side drive.
    out plowing and waxhead like this.
  30. Wow!!!! that's a true pedigree!!
