Technical *** September 2015 Banger Meet - Shadows Getting Longer in the North ***
Discussion in 'Traditional Hot Rods' started by Jiminy, Sep 1, 2015.
  1. colinsmithson
    colinsmithson
    If I remember correct
    Both Chev and Olds used the same block back then Olds had a 2 port and a 3 port head Chev had a single and 2 port head so it get confusing best of the lot if you can find 1 is the Olds
    hot-irons likes this.
  2. Nice side drive! what circa is it?
    I'm looking for one like that so I can run a Gemsa head.
  3. Hi, is this 3 port Olds head your'e talking about a 1928?
    If yes, then I'm off to Anderson machine to do some digging!:D
  4. I thought it was 28 Chevy 2 port, 28 Olds 3 port?
  5. hot-irons
    hot-irons
    That's a brand new piece made by Newens equip co in LaSalle Colorado. I can get you the guys number if you would like.
    out plowing, Kjell Elias and Dannerr like this.
  6. Please do! P.M. me the number and what it cost please.
    Thanks,
    Joe
  7. Binger
    Binger
    from wyoming
    LaSalle is just a few miles down the road from me. What other products is he working on? Always interested in new banger speed stuff.
  8. The Olds 3 port was '23, and there were a couple years that Chevrolet used the 3 port head as well
  9. Cris
    Cris
    from Vermont
  10. 62pan
    62pan
    Is the Alexander a four port? What size Winfieds are on that?
  11. Michael_e
    Michael_e
    I recently got a AA bellhousing(?) and already have the s10-5 speed trans and would like to make my own adapter. Does anyone know how thick the adapter needs to be? Been saving large chunks of aluminum and might even try casting the piece since it should be fairly simple. Thanks
  12. hot-irons
    hot-irons
    Luke at Newens equip co is making these modern high pressure oil pumps for you guys who don't want to rely on a modified stock pump.
  13. hot-irons
    hot-irons
    Here's a picture of above.
    Dannerr likes this.
  14. colinsmithson
    colinsmithson
    While I do not know enough about the years for the Chev and Olds heads I Used to race in vintage cl***es (pre 1932 4 bangers ) with a few chev guys and all preferred the 3 port Olds heads
  15. V4F
    V4F
    from middle ca.
    oil pump looks like a modified V8 pump .
  16. Can't find Newens Equiptment co contact info.
  17. I want one of these too! I've had two modified pumps break on me! (NOT FUN!!!!)
    Heck, I want two! I will drop my pan for one of these!;)
  18. V4F
    V4F
    from middle ca.
    to much pressure will cause leaks . mine is set @ 18#
    Dannerr likes this.
  19. You running 18# at 3,500 rpm. With or without splash rods?
  20. denis4x4
    denis4x4
    from Colorado
    Shot of the 32/36 Weber on my banger. Still sorting out the linkage ImageUploadedByH.A.M.B.1441830484.016345.jpg
    waxhead and Dannerr like this.
  21. V4F
    V4F
    from middle ca.
    18# from idle to ---------- my motor has inserts , aluminum rods & piston . drilled crank & all that stuff .
    that's a clean set up ............. great
  22. Sounds fun! What RPM does it red line at and what is the oil pressure at that rpm?
  23. V4F
    V4F
    from middle ca.
    I don't know . I have ran it up to 3500 , but I keep it around 2200 (60+mph) . I just drive like a car ........
  24. V4F
    V4F
    from middle ca.
    motor pix in my albums
  25. V4F
    V4F
    from middle ca.
    NEED ADVICE ............ ok I screwed up . on a banger that is all together , how do I get the oil pump to prime ? yes I put it together dry . big mistake . I have a pressurized system with a modified V8 pump . thanks for any advice ...... steve
  26. hardtimesainit
    hardtimesainit
    Remove distributor and pour oil down thru dist hole !
  27. V4F
    V4F
    from middle ca.
    did that with no results . ill keep trying . thanks .. steve
  28. fine29
    fine29
    from Des Moines
    Just curious I have a stock A banger in my roadster. What would I need to do in order to run a high comp head and a Riley single carb intake?
  29. V4F
    V4F
    from middle ca.
    be sure your bottom end is in good cond. you might like the 6-1 Snyder or similar .
  30. fine29
    fine29
    from Des Moines
    The engine is all fresh just new to the banger world. I plan on upgrading the ignition this winter too
