Event Coverage My Run to The Race O Gentlemen
Discussion in 'The Hokey Ass Message Board' started by safari-wagon, Sep 5, 2015.
  1. safari-wagon
    safari-wagon
    I got the acceptance email a few weeks ago, but have been too buried in work & club projects (ie; Concours d'Elegance, etc) to start prepping the rod until today.
    I got a list of bits the are to be removed in the name of safety or being period correct for the pre-war vibe of the event.
    Here's a pic of how we ran the car at the Hot Rod Hill Climb in June.
    lothiandon1940 and AHotRod like this.
  2. safari-wagon
    safari-wagon
    My photo of the car pales in comparison to Mike Rodgers' work.
  3. safari-wagon
    safari-wagon
    The list of items to be removed are:
    Windshield.
    Headlights.
    Trim Rings.
    Moon Tank (not period)
    White Wall Tyres (not period)
    I'm looking forward to this new look for the Singlefinger Special, plus this forces me to fix a few things that I've been ignoring..
    AHotRod likes this.
  4. AHotRod
    AHotRod
    Well, Congratulations !
    The roadster is awesome.
  5. DUSTY13
    DUSTY13
  6. safari-wagon
    safari-wagon
  7. 3wLarry
    3wLarry
    from Owasso, Ok
    car is 40's period correct...moon tank is 60's period correct
    put it back on and I will have the Guido Bros pay you a visit
    you have a great car without it
    just my two pennies
  8. safari-wagon
    safari-wagon
    Thx, Larry.
    Here's a pic after I checked off a few things on the list last night.
    Still a lot of stuff left to do.
    -Brent-, RICH B, just Matt and 3 others like this.
  9. Jalopy Joker
    Jalopy Joker
  10. brady1929
    brady1929
    Roadster very cool w/o moon tank. No offense.
  11. Looking great Larry! See you on the sand.
  12. HOLLYWQQD
    HOLLYWQQD
    from central NY
    unnamed.png last pic looks much better , looking forward to seeing it on the beach ! here is a pic of mine ,we'll have to line them up if we get a chance !
    volvobrynk and Jersey Joe 67 like this.
  13. safari-wagon
    safari-wagon
    I can't wait to see your car on the starting line.
    Sounds like we will all have a freakin' good time on the beach!
  14. wheeldog57
    wheeldog57
    Man-o-man! These 28-29 roadsters are awesome! I cannot wait to see them all on the beach. My first time going to ROG. See you there!
  15. loveoftiki
    loveoftiki
    from Livonia,Mi
    Awesome.....represent for us Detroit guys!
  16. safari-wagon
    safari-wagon
    Ever since we put the bigger Flattie in the car, it's been running hot & hates to idle for very long. Pulled the Radiator to have it tanked & pressure checked tomorrow.
    TROG rules require that you only run water in the cooling system to protect the beach from contamination if your rod boils over. So, I'm going to install a couple of restrictors or Thermostats to slow the flow of coolant at idle, which should help a ton.
  17. 62hotcat
    62hotcat
    Still in the 90s here on the jersey shore 3 weeks out.
  18. safari-wagon
    safari-wagon
    Before I pulled the rad, I took the rod out for a quick run w/out the Windshield. I quickly remembered why we have them, when I got a face full of road dirt & a bit of coolant from the leaky rad.
    For years, I've been sitting on a stock seat bottom with a shortened riser. The seat cushion itself is about 8" tall. In order to reduce the wind & dirt in my face, I need to sit at least 4-5" lower.
    Started to mockup a new seat bottom last night. In order to keep it comfortable, I plan to cover plywood with 2" foam & a 3" bolster at the leading edge.
    More pix to follow.
  19. Mr48chev
    The man from the wilds of Oklahoma knows what looks right on a car and he nailed it there. Never figured out why guys build beautiful and clean cars and then stick a "mee Too" zit out on the front. Unless it's a nose high g***er that is, then it's a real race car part if it's hooked up..
    gas pumper likes this.
  20. rtsidejohnny
    rtsidejohnny
    Congrats on the invite...Very nice car!
    If you plan on driving your car a bunch, be sure you use high density seat foam (from upholstery store) if you're only using 2" for the seat bottom...trust me on this one.
    Johnny
  21. HOTRODPRIMER
    HOTRODPRIMER
    I gotta agree with Larry,the moon tank is more of a 60's style thing IMPO and actually distracts from a otherwise *****ing car,no offense intended. HRP
  22. safari-wagon
    safari-wagon
    Since the Elco tank has to go, I can't live with the damaged grille any longer. The tank hid the damage that happened when the rod fell off the jack at last year's Hot Rod Hill Climb. It was pretty depressing looking at that original grill all screwed up.
    So, today the Highlander & I beat the crushed original grille shell back into shape, then we straightened the insert too.
    Looks pretty good for an afternoon's hammering!
  23. theHIGHLANDER
    theHIGHLANDER
    I was happy to give that damage the Singlefinger Salute...:cool:
  24. safari-wagon
    safari-wagon
    I thought you was talking to me then...
  25. safari-wagon
    safari-wagon
    Since I have to run the rid w/o a windshield, I needed to make a new bottom cushion that will let me sit about 5-6" lower.
    My buddy John owns A1 Upholstery in St Clare Shores, MI, so we attacked the issue right off.
    I had already given him the plywood bottom last weekend to measure & mark the foam. So today, he was t******* vinyl when I got there after work.
    2-3 hours of sewing, cutting, glueing & stretching later... we had a seat bottom!
    -Brent- likes this.
  26. Tic Toc Larry...
    The roadster is looking great.
    We should get together on travel plans. Scott from Bay City is running his roadster this year and I'm planning on dragging the Caddyhauler out too. It might be good to hook up and caravan out together???
  27. safari-wagon
    safari-wagon
    Scotty is bringing his truck too.
    Prolly leaving early Fri am, unless we can free up Thurs.
  28. Cool it will be good to see Scotty again.
    I think we left Saginaw at 3:00 A.M. Friday morning last year and drove straight through.
    Long *** haul... I would love to leave Thursday PM this year even I just sleep for a few hours in the truck.
  29. safari-wagon
    safari-wagon
    What time you arrive last year?
  30. safari-wagon
    safari-wagon
    Started this trip with a quick stop at Ferndale Radiator with Mel fixing a sizeable leak in a front tube.
    Off to NJ now, seeya tonight.
