Hot Rods brake tech
Discussion in 'The Hokey Ass Message Board' started by flatheadgary, Sep 9, 2015.
  1. flatheadgary
    flatheadgary
    from boron,ca
    does anyone know of a shop or person that makes the adapter/spacer that goes on the early ford spindle to put mustang II rotors on. it is the same design as the ones for chevy spindles. i have a very light car and don't want to run large diameter rotors.. the mustang is 9.250" and should work ok. if you don't know how this is done, you put the spacer on and then turn down the outside bearing area on the spindle to fit the bearing and trim the end and re-thread the threaded part, drill a new cotter pin hole. yes, i know this is *** backwards of what everyone does today, going to bigger rotor for more stopping power but, i don't need that much on this light car..
  2. 2racer
    2racer
    pretty sure i have seen that in the speedway catalog
  3. flatheadgary
    flatheadgary
    from boron,ca
    2racer. the only one they have is the one for chevy spindles to mount chevy calipers to the stock axle.
