Technical Anyone wanna throw in their 2 cents on sbc377 cam options?
Discussion in 'The Hokey Ass Message Board' started by AlmightyCrash, Sep 9, 2015.
  1. AlmightyCrash
    AlmightyCrash
    from Tyler, TX
    Hi guys.
    I have a 377sbc (destroked 400) with flat top Pistons (dual valve reliefs), 190cc aluminum heads, 1.6 roller rockers, Edelbrock performer RPM intake, Edelbrock 750cfm carb, ****** headers.
    If I'm leaving anything out, please ask.
    This will be more street than strip, but I still want it to get up and go...and have a mean sounding idle.
    Any help is greatly appreciated.
    UPDATE:
    I found a Lunati cam with an operating range of 1800-6200 with 227/233 (268/276 Adv) duration and 489/504 lift. I feel that, paired with a 2200-2600 stall should provide me with what I'm looking for.
  2. bostonhemi
    bostonhemi
    I think your leaving out the question.
  3. 56sedandelivery
    56sedandelivery
    Looking at your profile page, I'm guessing this is for the Mercury? That's usually a cruiser/slo-rider type car, while a 377 is far from that in what they're built for. If it's for the Merc, a mild 350/350 is what most would suggest. What is the "intended" purpose? And Tyler, Texas; I'm a TJC 84 graduate of the Radiologic Technologist Program and trained at what was then called Medical Center Hospital; now it's the lead hospital in the "East Texas Hospital Foundation"? I lived out on Hwy 64 East. Wish I could go back to that time. I am Butch/56sedandelivery.
  4. AlmightyCrash
    AlmightyCrash
    from Tyler, TX
    True. I must have skipped that in my post as it was in the ***le. I need help choosing the best cam.
  5. AlmightyCrash
    AlmightyCrash
    from Tyler, TX
    Nice to meet you, Butch. I'm Crash, and I grew up here. Moved away, but got ****ed back in.
    It's actually for my firebird, but i trust the people here, and thought I could get some valuable input. That, and I haven't found any decent firebird forums. The 350 in the Merc was easier to plan out for its build.
  6. Mike VV
    Mike VV
    from SoCal
    Also need the following -
    1. Car weight.
    2. Transmission type (gear ratios).
    3. Rear axle ratio.
    4. Rear tire diameter.
    Mike
  7. AlmightyCrash
    AlmightyCrash
    from Tyler, TX
    Car weighs approximately 3500lbs
    Transmission is th350. I have no problem adding stall converter and shift kit, but it's currently stock.
    Rear axle it 3.73
    Rear tires are 26.8"
  8. You'll e cruising in the low 3Ks range.
    Intake is good to 6500 on a 350, you'll get less rpm out of it at 377. Still somewhere over 125 mph.
    Around a 292 cam with 2800 stall would be my guess of you have the compression to back it up.
  9. AlmightyCrash
    AlmightyCrash
    from Tyler, TX
    I have been leaning towards the Edelbrock RPM cam 7102. How well does everyone think that would pair with my setup?
  10. slammed
    slammed
    Have a real deal cam grinder/engine builder cut you one to the exact driving (street strip, s o m e drag & mostly highway interstate or pure 10 mile radius ricky racer) habit you are going to do. Be honest with yourself.......a roller in the budget. What would Sammy Satire do?
  11. brandon
    brandon
    I'd guess a hyd roller in the lower 500's lift wise and duration @50 around low 230's...I've had really good luck with Bullet racing cams
  12. brandon
    brandon
    Another off the shelf guess...it worked in a 355 and a 406...so your in there somewhere....haha crane 518/536 282/288...
    falcongeorge likes this.
  13. AlmightyCrash
    AlmightyCrash
    from Tyler, TX
    I have a .555 max lift with 1.5 rockers, so approximately .523 with current rockers.
  14. dusterdave173
    dusterdave173
    Engine builders use them everyday because they Work--not ***y but a 230 at 050 480 lift hyd would be excellent and Cheap--Herberts has them on the shelf for $139 cam and lifters --in that CI in that situation they are Perfect! Leave the fancy stuff to others--spend $139 and have exactly what has worked for ages!! It will sound fantastic and melt rubber until you let up on the pedal--great vacuum etc
    377 is usually built as high winding raise hell engine but in your case it is just a 350 with a NICE overbore--Trust me--the custom stuff is just over paying for your combo. I build and dyno engines every single day --cams are sticks with knots on them --keep to the basic principles and they all work pretty darn well. Hyd rollers are the best if you have a factory roller block and can use stock CHEAP roller lifters otherwise you pay out the Ying Yang for retro rollers --just ain't worth it in a budget build--
    BTW if you do retro make sure they are Morels NOT Johnsons--Johnsons rollers stick the plungers all the time and create havoc--all brands you buy are one of those two in disguise .
  15. wbrw32
    wbrw32
    Mr Crash,,Please go to the top of the Introduction page and read Ryans guidelines for the HAMB. we do NOT do muscle cars here...nice try to slip that in...
    da34guy likes this.
  16. Really ? It's an engine question.
    Need a hug? Coffee maybe?
    AlmightyCrash and B Bay Barn like this.
  17. mcmopar
    mcmopar
    from Strum, wi
    OP never said what it was in, someone else asked.
  18. oj
    oj
    I agree 100% with 'dusterdave' and add one thing he left out: get rid of the 1.6 rockers and get some 1.5's. I wouldn't do a 'roller', keep it all basic old school mechanical. One thing that is hurting you is the short connecting rod (5.5"), you put any kind of big cam with your cars' weight and it'll be a pig at low end. 'dusterdave' is speaking of the 286H cam, I'd even consider smaller like the 298H with .466 lift.
  19. 1934coupe
    1934coupe
    You will get a hundred different answers about cams on any blog/thread you put up, I have the same combo except for the heads (69 Z-28 2.02) and I'm running a 4 speed in my 57 Chevy. This cam works great for me. Ad is from Summit
    Isky Racing Cams 200030 - Isky Mechanical Flat Tappet Cam and Lifter Kits
    Compare
    Cam and Lifters, Mechanical Flat Tappet, Advertised Duration 290/290, Lift .480/.480, Chevy, Small Block, Kit
    Part Number: ISK-200030 More Detail...
    Estimated Ship Date: Tomorrow
  20. bobss396
    bobss396
    Hug.. coffee... I'm personally holding out for a hot ****erscotch enema....
  21. greg32
    greg32
    from Indiana
    Call Comp Cams .
  22. Sicko- that's gonna make a mess
  23. 350/350 Chevy cam....450/460 with 320 duration...great street / strip cam
    oj likes this.
  24. AlmightyCrash
    AlmightyCrash
    from Tyler, TX
    My rods are 7.75"
  25. AlmightyCrash
    AlmightyCrash
    from Tyler, TX
    I spent most of yesterday and all of last night (insomnia is sometimes helpful) reading up on everything and going through hundreds of cams.
    I found a Lunati cam with an operating range of 1800-6200 with 227/233 (268/276 Adv) duration and 489/504 lift. I feel that (paired with a 2200-2600 stall) should provide me with what I'm looking for.
    To those I've offended by my engine being in a muscle car, I apologize....though I got more response to this post than any regarding my Merc.
  26. falcongeorge
    falcongeorge
    from BC
    well, yea but 3.73s with a 26" tire? This question smells like performance...Now if you need advice on which gl***pack will rap the best on your 6 cyl. moredoor...:D
    AlmightyCrash likes this.
  27. get a poser, uh I mean thumper cam. :rolleyes:
    What you are describing is just your basic claimer motor like the short track guys around here used to build when 400 blocks were still plentiful around here. Your bore to stroke ratio lends itself better to revving then to cruising. I could suggest a cam but you wouldn't listen and the real "experts" would shoot it down anyway. Call your favorite cam manufacturer and tell him what you got and what you want it to do and let them suggest a cam for you.
  28. Rex_A_Lott
    Rex_A_Lott
    Better check that again.
  29. AlmightyCrash
    AlmightyCrash
    from Tyler, TX
  30. 5.565 stock shortest rods in the small block lineup stock. I don't think I have ever heard of anyone putting a 7" rod in an SBC, 6" maybe and a 7.75 is a stretch no pun intended.
    Uh that's a pushrod not a rod this is a rod:
