Questions about Flathead V8 60
Discussion in 'The Hokey Ass Message Board' started by El Bombero, Jun 8, 2011.
  1. El Bombero
    El Bombero
    I am thinking about using a V8 60 in an upcoming project. I know nothing about these engines. I am looking for any info I can get. Things like rebuild kits, speed equipment and what years are the best/ worse to use. Any information would be much appreciated.
  2. Sloppyseconds
    Sloppyseconds
    from Pasadena
    I would not use a V8 60 in anything but an early midget project or a super light roadster. They have less power than a standard flathead... the speed equipemt is very expensive and getting rare. Rebuild kits... pretty standard and easy to get. So anyways.. send me the 60 and go find a later flathead.... you ll be happy you did
  3. Shaggy
    Shaggy
    from Sultan, WA
    Search....
    There is enough stuff currently on the market to build decent power, but as stated before, you need to put one in a super light car to make it worth doing
    Power wise they are short, but no worse on paper than an MG
  4. Dean Lowe
    Dean Lowe
    As Sloppy said, you will be disappointed with the power from a 135 cu in V8-60. Heads and manifolds are a lot rarer and more expensive than the ones for the 85 flathead. If you are dead set on using one, you want a late '39 or '40 iron side block.
  5. El Bombero
    El Bombero
    What makes these better?
  6. El Bombero
    El Bombero
    I have searched. I have read a lot about these little engines. I am trying to get as much info as I can to make the right choice.
  7. 3wLarry
    3wLarry
    from Owasso, Ok
    Your long lost Uncle 3wLarry just happens to have a complete iron side V860 and ******...and it's for sale. :D
    kidcampbell71 likes this.
  8. 3wLarry
    3wLarry
    from Owasso, Ok
    The early 1937 V860's were made with welded on tin sides...you don't want them...you want the later cast iron sided ones...they're stronger.
  9. Ebbsspeed
    Ebbsspeed
    The 1937 version of the V8 60 had sheet metal sides on the engines. Not as solid a base to build on.
  10. El Bombero
    El Bombero
    I saw yours for sale. My friend has three of them and he said he will sell me a complete one. Yours is tempting, but shipping would kill me!!!!!
    Mike
  11. El Bombero
    El Bombero
    Thanks guys. Both type are available and I didn't know which was better and for what reason.
    Mike
  12. Model A Gomez
    Model A Gomez
    I can tell you from experience that a V8 60 isn't a good engine for anything except a very light car, my avatar is a 28 coupe I built in the early 90's with a V8 60. The engine has no torque and doesn't really make any power until about 2400 rpm, I have a 30 pickup with a warmed over A motor and it would run circles around the 60 powered car up to 60 or so, everything for them is costly. If you are going to build one use the cast iron sided motor, I had three extra motors and some speed parts and sold them to a midget racer. Speedway Motors still sells speed parts for the V 8 60, but I think you will be dissapointed in the preformance.
  13. rattlesnakehoey
    rattlesnakehoey
    from Australia
    Apparently the French used the V8 60 for years. They also utilized an OHV conversion on a 'Simca'. I beleive the heads still available in South America. Uber cool mini Ardun. www.comyoutube Ford Flathead V8 60 Hemi.
  14. Shaggy
    Shaggy
    from Sultan, WA
    If you keep it to a light T roadster, say around 1600lbs or less it'll probably go good
    Also keep in mind that with the small stroke they have they are capable of pulling more R's safely than an 85
  15. El Bombero
    El Bombero
    Thanks for all the responses. The car I am planning this engine for doesn't need a lot of horse power. I think the only drawback for me might be the cost.
  16. Funnycarguy
    Funnycarguy
    I just received a flyer from Andersen Design Speed Equipment in Salem OR. They are advertising 2 versions of cylinder heads, dual carb manifold and a steel flywheel for the V8 60 engine. Their phone number is (503) 393-7575. I have never bought their goods but the fellow was very knowledgeable and the product is there.
    thanks
    Dale
  17. Sheep Dip
    Sheep Dip
    from Central Ca
    A fellow here locally has one of those little 60"s in an old Harley....looks very cool.
  18. Shaggy
    Shaggy
    from Sultan, WA
    Ive heard good about that shop, they make a tripower too, which even though it is more carb, it can be ran progressive and be more streetable.
    I havent seen their stuff up close, but i think "stromberg97's" may have, i think it was him that i got intouch with them
  19. El Bombero
    El Bombero
    Are there any tricks when rebuilding these?
    Mike
  20. strombergs97
    strombergs97
    Here is a Anderson intake 2x2 , excellent casting, runners are great..I believe for a mild built V8 60 2x2 is enough..This one has 81s..
    His heads are also excellent quality..
    Duane.
  21. Jalopy Joker
    Jalopy Joker
    know a guy out of NorCal running a V860 in a short belly tank he built to run at Bonneville. planning on building one with a blower next.
  22. Algon
    Algon
    Should any of you boys want an original Eddie Meyer dual for v8-60 contact me (PM). I ran across one today and can p*** on the information to get it or possibly pick it up for you.
  23. cactusgarage
    cactusgarage
    from france
    hello your engine, there is engine french? .
    What you search? Information.
    if I can learn,
    Mik
  24. 97
    97
    Simca : Vedette, Chambourd or Versailles
  25. jackflash
    jackflash
    from uk
    jeez... you want to try my shipping costs lol...
    Currently looking for a little flathead v8 for a project for next year.. preferably not an early tin sider.
  26. scrap metal 48
    scrap metal 48
    I have a complete 1938 V8 60(not running) and trans still in my avatar for sale...
