Av8 stance
Discussion in 'The Hokey Ass Message Board' started by hotrod harry, Sep 10, 2015.
  1. hotrod harry
    hotrod harry
    from wisconsin
    Just got this thing out of garage and down the road last week . Just looking at stance from side, is it me or is rear up to high?
  2. 2935ford
    2935ford
    I don't think so! :)
  3. 4BangerDean
    4BangerDean
    Looks really cool. If it was mine I'd like to the outside diameter of the rear tire be even with the top of the wheelwell arch or just below it. By no means do I think it looks bad though.
  4. dumprat
    dumprat
    from b.c.
    Wheel arch looks right. Front dropped too much? Kinda looks 60's style.
  5. hotrod harry
    hotrod harry
    from wisconsin
    Thanks, if dropped to top of wheelwell arch tires will rub
  6. Mr48chev
    Nice rake and the spacing between the tire and the wheel arch is real even which looks great to me.
    Those itty bitty photos always hurt my eyes so I took the privilege of making it so we can see it.
    Hotrodmyk likes this.
  7. Rustridden31
    Rustridden31
    from Denver, CO
    The angle is just right. If you lower it the front and rear should go down together, otherwise I'd leave it. Looks good!
  8. IMHO, it's not that the rear is too high at all.
    I think the front end is too low.
    It's that the front tire diameter is too small.
    Judging by your engine, it looks level.
    A bigger diameter front wheel will give a more proportunate
    look and the engine will slant downward to the rear.
    Just my $.02
  9. 4BangerDean
    4BangerDean
    What size tired are you running?
  10. A Boner
    A Boner
    ^ me too!
  11. hotrod harry
    hotrod harry
    from wisconsin
    Rears are 235/75/15, fronts 185/65/15 , so there is abit of tire rake
  12. AVater
    AVater
    Looks nice to me. In addition to the rear fitting the wheel well evenly, I like the way you see the headlight detail from the side. I guess if you went to 75 profile in the front you pick up maybe 1/2 inch? I guess my two cents too.
  13. Kiwi 4d
    Kiwi 4d
    The stance is cool ,don't stress to much, get it out and enjoy it for a bit. As I see it if you did decide to lower the rear you may need to go to narrower rear tyres or a wider rear to avoid the rub. Just need to keep the tyre tall to keep up the gearing.
  14. SimonSez
    SimonSez
    Looks pretty good, but I think it would be better with 165 front tyres ;)
  15. Manager
    Manager
    Stop looking and keep driving.:)
  16. Petejoe
    Petejoe
    from Zoar, Ohio
    Looks perfect to me. The whole car looks great!
  17. theHIGHLANDER
    theHIGHLANDER
    It's a matter of aggravating angles, to me at least. The stance is fine, it's a hot rod. What mullers it up to my eye is the rear axle brace/bone/ladder bar being white and going against everything else except the pipes (which look fine to me). If that was blacked out the rest would blend, and going out on a limb, you may also seem focused on that because you built it. We who do this **** look at everything completed with an overly critical eye. Bad*** sedan though. The only reason I could see to level it off a wee bit is if you end up ducking your head down when you're 1st at the stop light, the rake and the visor working toward limiting that plane of sight.
  18. hotrod harry
    hotrod harry
    from wisconsin
    Seeing stop lights are not a problem! :confused:
    I can live with rake, it was a comprised to allow rear seating other wise it would be alot lower
  19. 3wLarry
    3wLarry
    from Owasso, Ok
    personally, it's refreshing to see an A sedan that doesn't have its *** end dragging like a dog rubbing its **** across the carpet
  20. 1-SHOT
    1-SHOT
    from Denton
    What are you trying to say windowless !
    3wLarry likes this.
