Technical What happened here?
Discussion in 'The Hokey Ass Message Board' started by Lcats, Sep 17, 2015.
  1. Lcats
    Lcats
  2. Mark T
    Mark T
    What oil were you running? modern oils don't work in older engines.
  3. Harms Way
    Harms Way
    Same thing happened to the engine in my sons 66 Mustang when they took Zink out of oil,.. And didn't inform anybody... The cam lobes looked like door knobs..
  4. pitman
    pitman
    In attempting to picture the steps that lead to a failure...
    might have been hard local region(s) that cracked loose and broke away under pressure.
  5. No Zinc in the oil......
  6. aaggie
    aaggie
    This is the results of what happens when modern oil without the Zinc additive is used in older engines. The valve spring pressures squeeze the oil film out of the contact between lifter and cam lobe. Commonly called a flat cam. Modern engines with roller lifters don't have the problem.
    Most instruction sheets that come with new camshafts tell you to run a good break in oil that contains the proper additives and when you first start the engine to run it at about 2000 RPM for 20 minutes to seat the lifters to the cam lobes.
  7. Don's Hot Rods
    Don's Hot Rods
    from florida
    My Son just had a new 455 Olds built for his rpu by a local race shop, and the guy gave us the oil he wants to see run in the motor. We never knew this one existed, but it looks like Lucas has developed this one just for we rodders and cl***ic car owners who run flat tappet cams.
    http://www.jegs.com/p/Lucas-Oil/Lucas-Hot-Rod-Cl***ic-Car-Motor-Oil/2875897/10002/-1
    We have always put in a half bottle of Comp Cams break in additive with every change, but now won't have to..
    Don
  8. Engine man
    Engine man
    from Wisconsin
    How long were they in use? Did only 5 of the lifters show this wear? If it was short term and only 5 showed this wear, I would believe that the problem lies in the metallurgy of the camshaft or lifters. If all of the lifters show similar wear after a short time, one could possibly blame the oil but it could still be a poor hardness match between the cam and lifters or a lack of proper ***embly lubrication. Were they all at one end of the camshaft? Was there a problem with fuel contamination in the oil? Was there an oil pressure problem?
  9. Cheap lifters. Without any more information then you have given us I am going to say "Buy American"
    czuch az and firstinsteele like this.
  10. Dean Lowe
    Dean Lowe
    Good info Don. Thanks for the link. It's not just Chinese lifters that do that without zinc. I had a set of good, made in the USA, lifters do that too. If you are not running roller lifters, ZINC is your best friend!
  11. Jalopy Joker
    Jalopy Joker
    Don's Hot Rods - good info - the special app Lucas oil has been around for a while and mentioned in threads here on zinc - not cheap but, I use it in older motors
    hotrodharry2 likes this.
  12. 56shoebox
    56shoebox
    Brad Penn oil oils and Valvoline racing oils have the necessary zinc.
    there are others as well.
    cactus1 likes this.
  13. So what kind of oil should I be running in my 71 olds cutl*** station wagon????Thanks Bruce.
  14. hotrod1948
    hotrod1948
    from Milton, WI
    Doesn't Rotella brand oil still have zinc in it (Diesel use)?
  15. 2002p51
    2002p51
    I saw lifters like that when we opened up an 80,000 mile 350 Chevy back in 1978!
  16. 2OLD2FAST
    2OLD2FAST
    from illinois
    Nope , not the last I've heard. You can run just about any oil WITH AN ADDITIVE , otherwise Brad penn VR1 RACING ,Lucas ...
    dave
  17. stimpy
    stimpy
    nope rotella has been cut back because of the new emissions systems they run which is like a catalytic system on a car , most diesels have been running roller valve trains for years . if your lucky you can find the old formula of rotella but its still might not be enough to protect the lifters . Case International oil has the zinc and other metallics in it as its made for older tractors and implements that use solid lifters and older style parts and the low ash formula will help keep acid forming down too . you can get it at any CAse international dealer .
  18. SicSpeed
    SicSpeed
    from Idaho
    Those look horrible.
    I was using Joe Gibbs until the price doubled so I switched. I have been using Amsoil Dominator in my racing engines.for 5 years. Never a lube problem but both engines are full roller. A 575hp 347 and a 835hp Roush 358. Synthetic available in 5/20, 10/30, 15/50 and a sae 60
    They also sell a high zinc synthetic oil for street use called Z-Rod in 10/30 and 20/50
    Also available is a synthetic high zinc called Premium Protection in a 10/40 and 20/50
    The have break-in oil also
    I have always been a solid mechanical lifter guy. Now a days almost everything gets a solid roller to keep problems at a minimum. Its expensive but better than losing an engine.
    volvobrynk likes this.
  19. unkledaddy
    unkledaddy
    Lifters Love Brad Penn and Wix Gold filters.
  20. Lcats
    Lcats
    Unknown- bought the truck with this rebuilt motor in it..lol. Had no power - so I pull the intake.
  21. oldsroller
    oldsroller
    from PA
    Run Brad Penn and Wix filters in my older motors have been without issue. Sounds like you just get to pick up the pieces after someone else dropped the ball. My dad refuses to run good oils in his old tractor engines, buys the cheapest stuff he can find. Told him that it will be some of the most expensive money savings he has ever seen one of these days.
    volvobrynk and AHotRod like this.
  22. Lcats
    Lcats
    Dude I bought the truck from just added oil when it ran low from all the leaks and was running water in the motor as well. Pulled the motor and it's now sitting in the corner of the garage. Found a 283 bored .60 over short block- just getting back together. It's was only these five that looked like this. And if I remember they were from the rear. Thanks for all the oil preferences. The ***** was that the truck idled and ran fine...just had no power- thought it was the two banger.
  23. Kan Kustom
    Kan Kustom
    He threw in everything but the kitchen zinc !
  24. Engine man
    Engine man
    from Wisconsin
    So you have no way to tell if it was actually rebuilt. Maybe it was a rattle can rebuild of a worn out engine. I noticed that the oil spots on the cardboard have a lighter colored halo around them. That can be an indication of fuel in the oil.
  25. WIX filters and Valvoline Racing Oil.
