Projects Project 30 Tudor
Discussion in 'Traditional Hot Rods' started by 340HilbornDuster, Apr 11, 2013.
  1. hey 340 you thinking of coming to cruise paradise 2015 .
  2. 340HilbornDuster
    340HilbornDuster
    Hi Hilo hotrodder....we planned to..just got the steering box in my 29 Phaeton..I dont think it'll be legal by then...wouldn't haul the banger sedsn over there...it's fun to drive but not gor a whole week...ww'll see..
    Tommy
  3. 340HilbornDuster
    340HilbornDuster
    It's home...
  4. 340HilbornDuster
    340HilbornDuster
    Finally scheduled the heart transplant.
    Anyone knows the difference between the 2 blade and the 4 blade prop?
    Thanks for all your help Randy!
    With the motor out I just had to fix the Plywood FireHazardWall.
    When I bought the Sedan the seller included / cut out his firewall but wanted the structural integrity on his body until he welded in a engine tub, so he cut it around the perimeter....Sure beats not having a firewall at all!
    20150808_155101 (Medium).jpg 20150808_180435 (Medium).jpg 20150808_191237 (Medium).jpg
    The tank was leaking fuel and I found out it was full of small rocks...?
    Gutted.
    Kevs56 likes this.
  5. 340HilbornDuster
    340HilbornDuster
    Inside of Tank / Dash painted
    Ol' fire wall cut out.
    20150809_123951 (Medium).jpg 20150809_130131 (Medium).jpg 20150809_130306 (Medium).jpg
    Fits..
    Got the grime off.
    4 blade prop and a different front motor mount... 20150809_141132 (Medium).jpg
    Truck Engine?
  6. 340HilbornDuster
    340HilbornDuster
  7. waxhead
    waxhead
    from West Oz
    The new banger looks good. I hope you are still planning on using the 4 blade fan. If the 2 blade is an original one, they have been know to come apart and damage radiators etc.
  8. 340HilbornDuster
    340HilbornDuster
  9. 340HilbornDuster
    340HilbornDuster
    Hot as Hellsinki 2 day...this is what got done....
    waxhead and '52 F-3 like this.
  10. 340HilbornDuster
    340HilbornDuster
    Firewall's finally fire proof..
    Funny how the Garage turns in to a total mess sometimes. (Work...Torrential Rain throw the $#!+ inside and close the garage door...work...repeat)
    I envy those guys that have all the wrenches and other tools painted in the drawers...Maybe one day?
    barrnone50 and Dannerr like this.
  11. 340HilbornDuster
    340HilbornDuster
    Soon Time to go cruizin again...
    Manifold (came with the banger) looks brand new...on later
  12. 340HilbornDuster
    340HilbornDuster
    Radiator leaked pretty bad...
    took it apart and Found a big blob of solder...
    ...Tried to fix it "fast" without taking the support off....twice....
    ended up taking me three times as long....
    Got the support soldered back together again.
    Hopefully we'll be cruising on Labor Day.
    Dannerr likes this.
  13. 340HilbornDuster
    340HilbornDuster
    That took longer than planned...didn't wanna post untill i knew the engine was good.
    The old (2 years) battey died (semi died)...so I thought I had a dud engine first...
    now the brushes are smoking pretty good (engine came with another starter)
    Tanks inc wanted more in shipping than the tank $
    So I used my swap meet find...(the cap will get an vent hose to under the floor.)
    No fuel lines in Hawaii..used brake lines / fittings from NAPA. should be fine with alcohol free gas.
    Fuel pump + Holley pressure regulator set to 2psi.
    Fuel Switch
    THE ENGINE RUNS LIKE A DREAM!!! QUIET! NO SMOKE! NO LEAKS!...
    Good Deal! Thanks Bobby!
  14. 340HilbornDuster
    340HilbornDuster
    1442706916554.jpg 1st. Cruise...
  15. Congrats!! :D
  16. 340HilbornDuster
    340HilbornDuster
    Windward Mall Saturday Night
    Kevs56, '52 F-3, Dannerr and 2 others like this.
  17. 340HilbornDuster
    340HilbornDuster
    Time to shuffle again...getting dark...
    Sedan / Hot Rod tow truck is done for now...fancy roof and everything.
    Back to work on the tub.
    brEad and AndersF like this.
  18. 340HilbornDuster
    340HilbornDuster
    Found this online..(Pacific Culture Fest 2 yrs. ago)
    That 808shots guy takes nice shots!
    Dannerr likes this.
  19. 340HilbornDuster
    340HilbornDuster
    New Motor Runs Really Smooth!! And No Smoke!
    I'm really stoked! 20151114_171135 (Small).jpg 20151114_171243 (Small).jpg 20151114_174816 (Small).jpg
  20. 340HilbornDuster
    340HilbornDuster
    Sedan needs a new head gasket for tomorrow's Car Show...
    I think this one should do it...?...If I could only get the darn Head Off the car first!!...ANY GOOD SUGGESTIONS?
    TBone69 likes this.
  21. waxhead
    waxhead
    from West Oz
    Have you tried loosening off the head stud nuts, then tried to crank it over to see if the compression will lift it??
  22. 340HilbornDuster
    340HilbornDuster
    Good Idea waxhead....i dowsed the head studs with penetrating oil...tomorrow I'll see if your trick works...
  23. 340HilbornDuster
    340HilbornDuster
    Dannerr likes this.
  24. 340HilbornDuster
    340HilbornDuster
    Front Wheels are off the ground...Sitting in car...running the starter...
    Soaking with Penetrants, ATF / Acetone, Heat...
    Bottom end is good & I don't think the starter fluid trick would do any good...
    I'm starting to wedge a sharp thin spackling knife on top of the gasket...
    Studs would probably snap in the head if i tried to get them out...
    Any other ideas?
    daddio211 likes this.
  25. 340HilbornDuster
    340HilbornDuster
    HELP!...Christmas cruise coming up!
    Headline News!
    BBQ - Heated the head to 600F (IR temp gun) outside and inside the water channel....
    Hoping to burn any sealants, shellac etc...Still not budging....!
    When running the starter and a fresh coat of penetrant on all bolts and around the head gasket...
    There's bubbles coming out around the head gasket, mostly on the drivers side and some of the bolts...
    Any last ideas B4 I break off the studs in the head?
    A Cornwell A201 stud remover should arrive any day now...
    DYNAMITE?
    Kevs56 and kidcampbell71 like this.
  26. A 2 B
    A 2 B
    from SW Ontario
    Remove a spark plug, preferably from an end cylinder, crank engine over until the piston is low in the cylinder, insert a length of nylon 3/8" rope through the spark plug hole, then crank engine over. By applying cranking pressure and any other external lifting/prying methods simultaneously, it may give you the edge you need to remove the head. Good luck!
    Dannerr and kidcampbell71 like this.
  27. junk yard kid
    junk yard kid
    I have welded the nuts to the studs the. Quenched with wax and backed them out with an impact. Ruins the studs and nuts though.
  28. 340HilbornDuster
    340HilbornDuster
    Thanks A2B
    I've heard that idea before...I'm afraid to damage the Babbitt bearings though...
    Another idea was to wire all spark plugs together to the coil...Spray starter fluid in all holes and fire all four at the same time...Same thing, I think it may damage the bearings?
    2nd LAST RESORT!
    Mahalo Junkyard Kid
    Mac's and Snyder's sell studs so that's probably my next project...I'll try with my stud tool..if that doesn't work .. I'll TIG the Nuts on and hit it with the impact!
    Did you do that with the head still on or off?
    Last Resort is cutting the head off....I can get a new aluminum head for ~ $400.
    Reason? No-one does Babbitt Bearings on the island anymore!
    And machine work to convert to "real bearings" is too much $$$/HP for my taste...
  29. '52 F-3
    '52 F-3
    from Central PA
    any luck getting the f*&#%ng head off?
  30. 340HilbornDuster
    340HilbornDuster
    Hi Gregg
    Nope...Just stole her Shoes for the Tub, So Maybe she'll blow a gasket...?
    I'm going to try your method and also introduce the Air Chisel for some vibration...
