Technical 1947-54 CHEVY TRUCK AXLE??
Discussion in 'The Hokey Ass Message Board' started by budgetbuilt50, Sep 21, 2015.
  1. budgetbuilt50
    budgetbuilt50
    from san jose
    Will a 47-54 chevy truck front axle stock or drop fit a 1938 CHEVY TRUCK?
  2. deathrowdave
    deathrowdave
    from NKy
    I'm thinking it is wider , springs in a different location ? Any reason not use the 38 axle ?
  3. budgetbuilt50
    budgetbuilt50
    from san jose
    I have a drop one for sale and a friend was interested in it but he has the 38 truck.
  4. hubcap
    hubcap
    from phx
    Didn't Pat Gahnl use one in his 32 Chevy back in the day? I'm thinking the only difference is the diameter of the king pins?
  5. Mr48chev
    Here, Sid has somewhat of a chart that tells what the axle measurements are. http://www.droppedaxles.com/CHEVY_AXLES.html
    Reading that it looks like it will work as long as you use kingpins and spindles that match the axle.
    I've got an axle and spindles for my roadster project that were given to me with he belief that they were 47/54 but they may be earlier because of the diameter of the spindle where the inner bearing race rides. Not a big problem as a guy can swap races and go.
  6. Scott67
    Scott67
    from NJ
    If it does not work out for your friend, hit me with a pm. I would like to buy it from you
  7. 55 Mercury
    55 Mercury
    The 28-54 pickup axles will all interchange except for the kingpin and spindles. 28-40 has .734dia kingpins and 41-54 has .866 dia kingpins. The 38 steering arms will bolt on to spindles 28-59
  8. fro5555
    fro5555
    from No IL.
    hi do you still have that 47-54 dropped axle for a chevy 1/2 ton truck ???
