Technical Dropped front axle
Discussion in 'Traditional Customs' started by Tikisteve, Sep 21, 2015.
  1. Tikisteve
    Tikisteve
    I am looking to purchase a dropped front axle for my 57 f100 the person selling the axle has a 3 inch dropped axle with blocks and tie rod ends but my axle is straight this one has what I believe to be "dimpled" the center has a drop in it can I use this or no any help is appreciated thanks ImageUploadedByH.A.M.B.1442869705.556739.jpg
  2. seb fontana
    seb fontana
    from ct
  3. snopeks garage
    snopeks garage
    from macomb MI
    Does he know what year truck that's off of?
  4. snopeks garage
    snopeks garage
    from macomb MI
    Measure the gap between the bolt holes. You have a 2 in wide spring some of those axles are for 1 3/4 spring the 53-56 Ford's, those won't work.
  5. Tikisteve
    Tikisteve
    The axle is for a 57-60 f100
  6. seb fontana
    seb fontana
    from ct
    Check the part number on the axle per the site in post #2. If it matches the part number on your axle it will work..
  7. Tikisteve
    Tikisteve
    Seb Fontana the numbers match thanks for the advice [emoji106] much appreciated
