Projects Fairlane Chronicles
Discussion in 'The Hokey Ass Message Board' started by crazed, Aug 21, 2014.
  1. crazed
    crazed
    It was decided to move shops as we were going to replace the drivers quarter complete
  2. crazed
    crazed
    Fender off
    Interesting patch, and its dented in front of the wheel
  3. crazed
    crazed
    So, they dont make a replacement quarter for a '64 fairlane. ***le is marked on the white one, And plan was to move parts to the blue one, So had to check condition of the quarter.
    Lots of filler probably done by the guy that put it back together after my accident.
    Was decided that the metal is good, dents ok, rust no. So here is the white one ready for her last drive.
    And dropped off for surgery
    Sad..
    Took the other off while we were at it, someone will need it i'm sure.
    Ready for the red car..
    Headed back home
    He tossed it on for a pic to make me feel better..
  4. crazed
    crazed
    Plan at this point was to leave the hood closed on the red car, but you know how things go...we decided to pull the motor / trans so we can do the engine compartment body color...
  5. crazed
    crazed
    Started looking at the inner fenders, and firewall and decided to do some changes. Inner fenders had already been modified for the Mustang II front end..
    So... This!
  6. crazed
    crazed
  7. crazed
    crazed
    Rear end dropped off for paint, Satin black please..
    New inner fenders
    Mock up
    Makin them permanent
    Filled the column mount too
    Adding stiffener plates down the front frame rails
    Had to build this whole area where the steering box used to be to have a flat inner fender
    Inner fenders welded in
  8. 69supercj
    69supercj
    What gauge of steel are you using on your inner fenders? I've seen where some guys are adding a front bar on each side of the car running from the firewall to the front frame area, some curving down and welding into the frame, some just continuing straight and welding/bolting into the core support. These front ends are really compromised when the shock towers are removed. Boxing the frame should help considerably.
    crazed and loudbang like this.
  9. crazed
    crazed
    We put some pretty heavy plates along the frame rails, hoping that takes care of it
  10. crazed
    crazed
    So while we were mocking up the fenders, we decided that we didnt like the random spacing on the bolts..
    So the holes in the fenders were filled and the flanges made twice as thick
    And an even pattern put in
  11. crazed
    crazed
    Quarter panel back from being dipped
    More cleanup on the engine compartment
    Frame stiffening plates
    Boxed the braces for the front bumper / radiator area
  12. crazed
    crazed
    Creating the lip to connect the rear fender to
    Tacked in
    Mocking the fender again
    Almost ready for permanent install
    Got these from ring brothers as my stock ones were way sloppy
    Coated the fender on the backside
    And the car..
    Mocking up the hood / hinges
    Time to start working gaps
    Deuces and Rich B. like this.
  13. loudbang
    Sure hope this is not yours or from somebody else, this blood all over the shop floor. :rolleyes:
    crazed likes this.
  14. crazed
    crazed
    Funny, there has been times thru this that I'm suprized my wife has not made me bleed like that.
    Column mount..Going with a factory column, I found a 4 speed wheel adapter to get rid of the auto shifter gimmick
    Some goodies we have picked up
    Cl***ic gages, set to go behind the factory cluster
    Vintage air under dash unit
    Heat defrost from Old Air (uses factory cables)
    Factory Wheel
    Shelby Mirror
    Deuces likes this.
  15. crazed
    crazed
    White car came home, so it was time to take everything we need to make the blue one go. Hoping to make it a driver without too much investment, Would like it to appear as a hot rodded car would in the late 60's (without too much money added to make it look that new)
    Anyway, gotta take apart the white one first
    Back in the shop
    Here we go
    Pulled the heater, wiper ***ys, wiring harness (all of it)
    This will get cleaned up, need to work on the ****** a bit as the mount is broken from the crash in 2000
    Fresh air vent, wanting to add it to the p***enger side of the red car as it has an aftermarket heater and is loosing the vent
    This is where the fresh air vent goes on the drivers side
    Auto brake ***y removed
    Complete harness (unmodified)
    Up onto the trailer (figure i can pull the suspension on the trailer then just set her on the deck)
    On stands
  16. crazed
    crazed
    Been a bit since i even looked at the blue one, may as well pull it out and see what we got
    Fairly original under the hood
    Big hole in the floor, broken auto column, clutch pedal, and a homemade floor patch
    Battery tray area looks fair
    Big gouge out of the spring tower on the drivers side
    Floor patch
    Heavy rust on the brace above the windshield, (about 2" gone all the way across)
    Put on the wheels from the white car cause they hold air..
    This pretty much has me up to date. I need to finish off the white car so it can get off of my trailer. I will cut off the roof so i can take whatever bracing i need for the blue one. Rearend gas tank, exhaust and the complete front suspension still need to come off to be put on the blue one.
    I have the kit from crites to trim the shock towers and notch the drivers side for the inner headlight tubes, I think I'll use that for the blue one.
  17. ffr1222k
    ffr1222k
    You have been busy lately! Look forward to more progress on both cars.
    crazed likes this.
  18. crazed
    crazed
    Handy Dandy HF strut compressor works pretty well on a 64 fairlane.
    Other side
    3" Drop coils ready for the Blue one.
    Fresh gas tank removed from the white one, also for the blue one.
    Dropping the rear end. I had put on fresh HD leaves, and it has a fresh rebuilt 3.00 open carrier in the 8" with new bearings / seals.
    Pulled the exhaust complete, it will go in the blue one too.
    Done back here.
  19. crazed
    crazed
    Dropping the front end out, this was all rebuilt a few years back, poly bushings, big sway bar..
    Cut out the ****** tunnel for patches for the blue car
    Got news that my dad has Esophogus Cancer, Was nice to work on the white car together as we bought it together back in '85
    Took the center of the dash, someone will want a factory radio mount im sure..(I bought one)
    Dad laughing about who got dirtier
    The front part of the roof looks way better on the white car then the blue..
    I'm takin it
    Ready for s****
  20. 2dr_sedan
    2dr_sedan
    That's one helluva "scuff'n shott" on the red car!
    Nice reading your story, along with all the pics. Thanks for sharing.
    crazed likes this.
  21. crazed
    crazed
    So been awhile since I posted, I have some progress to report on the red car..
    Welded up every hole we could find in the floors..
    Picked up all the suspension parts from the painter, just a nice coat of satin black..
    Spent alot of time making mustang fastback hinges fit a 64 fairlane...(they werent even close.)
    New fusebox..
    Got the rearend back into the car with steel CalTracs blocks, feels much more solid.
    Putting the front back together..
    Its been a year and a half since this car had wheels on it..
    Back on the ground..
    Deuces likes this.
  22. crazed
    crazed
    Got the AC mounted on some pretty cool mounts, had to build some boxes for the defroster tubimg..
    Heater, AC plumbing will be out in the wheelwell..
    AC condensor and plumbing going in so we can have all the holes done before paint..
    Replacing the gravel guard mount and putting in a lip for future uphoulstery work..
    Hopefully we are going to be ready for paint soon, Its been awhile.
    Deuces and Jeff Walker like this.
  23. crazed
    crazed
    Update time, really has not been much going on since my dad died, but here is some.
    Got the new Corvette MC set into place and the new stainless lines ran..
    (Had to put the motor in to make sure everything cleared ok)
    Random engine bay pics...First ones with the motor in and the metalwork all done..
    How she has been sitting for the last 6 mo or so..
    Setting up the shifter, I dont like it yet, too close to the dash, but we are working on it.
    Drive..
    Park..
    Rich B. likes this.
  24. falcongeorge
    falcongeorge
    from BC
    Yea, the good ol' "scuff and shoot"! :D:eek: This is usually the way that ends up going! :rolleyes:I'm laughing with you, not at you...Great stuff.
    crazed likes this.
  25. low budget
    low budget
    from Central Ky
    Hey man, sorry about your Dad, gotta keep on keepin on and get this thing back on the road.
    Looks like your gettin there.;)
    crazed likes this.
  26. hedg12
    hedg12
    My first car was a 64 Fairlane - wish I still had it.
    Sorry about your dad.
    crazed likes this.
  27. crazed
    crazed
    Thanks for the comments on my Dad.
    Went over to check on the car yesterday, here are a couple new pics..
    This shows the battery tender mount, it has a sealed plugin under the car, just run an extention cord to it and the car is charging. Also shows the battery cutoff, and the new bracing that we had to do on the hinge mounts, as some flex was noticed from the big cylinders required to lift that long trunk lid.
    The long cylinders..
    Set my new stock style wheel in place to confirm shifter placement..
    Trim back on to make sure everything fits right before paint, and to check AC line fitment.
    See the condensor in front of the new radiator..
  28. crazed
    crazed
    Been so long since ive posted, but here we go.
    Shifter is mocked up..
    Picked up a ****** cooler..
    Workin AC lines smore..
    The Heater lines will go right thru the frame
    Ac parts in the front of the wheelwell..
    Inside of the framerail..
    Motor had to be in while we were doing that..
    New patch panel for the trans tunnel..
    Speaker box, battery, and all the bracketry for enclosing the trunk..
    On board trickle charger mounted..
    Playing with the trunk lock..
    Battery cutoff..
    More trunk lock stuff..
    Metal guy sent me this gif.. told me it was time to get to paint..
    Deuces, Cooon and kidcampbell71 like this.
  29. crazed
    crazed
    Looks like at some time in this cars life there was a mirror on the fender..
    Motor is out again..
    Giving the car the last lookover..
    Don't remember if I showed the new factory wheel, also has a 4 speed column adapter, (no shifter up there)..
    Trunk all cleaned out..
    A look at the engine bay..
    Dash trim..
    First time outside in 3 years..
    Back in the garage, on the trailer, ready for the run to paint..
  30. crazed
    crazed
    Had to pull this plate off of a door from my white Fairlane then I have all the parts needed..
    Back outside, and its time to go..
    Off we go!
    And she is in the little door there at the college..
    They are doing final paint on a 65 Chevelle today and tomorrow, should be ready to start sanding on my car after that.
