Projects 1937 Plymouth Build Thread
Discussion in 'The Hokey Ass Message Board' started by 56 Dodge Pickup, Jan 29, 2015.
  1. coilover
    coilover
    from Texas
    Here's a 37 Plymouth coupe under construction. I like the firewall being recessed from side to side about a third of the way down from the top.
    1947knuck likes this.
  2. 56 Dodge Pickup
    56 Dodge Pickup
    Very cool coilover I was thinking about cutting a recess section to clear the distributor but looking at yours with recess I might reconsider That frame is Awesome! Thank you for posting the pics. Have a Great Day! Jim
  3. ramrod36
    ramrod36
    from Upstate NY
    Jim---
    Looking good!
    lc
  4. 56 Dodge Pickup
    56 Dodge Pickup
    Thank you!! I still have to figure out the bracing and the final mounting hopefully this weekend I will finalize the layout.
  5. 56 Dodge Pickup
    56 Dodge Pickup
    Fire wall bracing is installed now the fire wall is rock solid.
    I used two inch angle iron to tie in the top to the bottom of the body sides then I ran two U channels across the opening for the upper and lower studs for the brake booster to bolt into.
    In keeping with my goal of making as many parts as possible for this build the new fire wall is installed and ready for finishing and primmer.
    1947knuck and 340 Power like this.
  6. 56 Dodge Pickup
    56 Dodge Pickup
    OK so as with an project it just keeps getting deeper than what was originally planned I welded in the motor mounts in an earlier post but I just couldn't stop thinking about the strength of the welds because of the difficulty I had in getting into a good position. I didn't want to find out that my welds were not strong enough when I was going down the highway this will also give me an opportunity to thoroughly clean the front end and engine before painting.
  7. 56 Dodge Pickup
    56 Dodge Pickup
    I really like the tri bar spinner look of the 60's MOPAR hub caps so I decided to make my own version not sure if I am going to go with beauty ring or not after the wheels are painted ,but I do like the hub cap tri bar combination. Jim
    1947knuck and tb33anda3rd like this.
  8. 56 Dodge Pickup
    56 Dodge Pickup
    The Motor is back in I fabricated new brackets for the motor mounts a little bit of over engineering but it eases my mind, also changed the oil pan gasket motor looks good for a 77 SBC. I also was able to really clean up the cross member and front suspension. Jim
  9. 56 Dodge Pickup
    56 Dodge Pickup
    Brought my 56 Home from winter storage I'm very excited to have one to drive and one to build feeling really Blessed!! Jim
    I just had to include the black and white shot too cool not to IMHO enjoy Jim
  10. 40Ford!!
    40Ford!!
    That is some nice work my friend and very resourceful!
  11. 56 Dodge Pickup
    56 Dodge Pickup
    Thank you very much 40 Ford I appreciate your comment Have a Great Day! Jim
  12. 56 Dodge Pickup
    56 Dodge Pickup
    Its been a long time in between updates I have completed the firewall and installation I have also started sorting out the wiring that was shown in an earlier post thanks for viewing Jim
  13. Rocky
    Rocky
    Classified Editor
    Coming along nicely
  14. 56 Dodge Pickup
    56 Dodge Pickup
    Thank you Rocky I appreciate your comments Jim
  15. Mudgy
    Mudgy
    Looking good. What front end cross member is that?
    Subscribed.
  16. 56 Dodge Pickup
    56 Dodge Pickup
    Thank you Mudgy the front clip is from a S-10 pick up it is step welded to the boxed frame just after the firewall. Jim
  17. Mudgy
    Mudgy
  18. DaveH_RRTX
    DaveH_RRTX
    Nice work! Good to see you making progress, gives the rest of us some motivation to get back at it!
  19. 56 Dodge Pickup
    56 Dodge Pickup
    Hey Mudgy I'm sorry I didn't realize you from down under it is a front clip from a Chevy S 10 pickup I'm not sure if they sold them under that name plate down under but it is a mid sized Chevy pickup
    Thanks Dave I should have some updated pics next week stayed tuned Jim
  20. 56 Dodge Pickup
    56 Dodge Pickup
    I started working on some fabrication for my new dash. I found a beat up Model A dash pod in the Old School Round Up at the Syracuse Nationals that I just had to have for five bucks! I really didn't like the flat dash and since that is the part of the car that I will be looking at the most it was time to start cutting.
    Here is a pic of the original dash that I started with
    I had to remove the raised sections to get a flat foundation
    Then I welded in the new steel that would be my base
  21. 56 Dodge Pickup
    56 Dodge Pickup
    Now its onto my new dash and gauge pod using the model A dash as the ends after filling the original gauge holes and cutting it in half
    I laid out the holes for my gauges and welded my new panel to the Model A dash
    Here it is still real rough but you can see where I'm going with this
    I am thinking about possibly frenching this into the dash or just mounting it the way it sits raised of the dash stay tuned and Thanks for looking Jim
  22. Mudgy
    Mudgy
    Good idea! Can you see all the gauges with the column and wheel thrown back in?
    That glove box is industrial grade!
    Cheers, Mudgy
  23. 56 Dodge Pickup
    56 Dodge Pickup
    Yes the vision is fine with the column drop I will be adding a spacer to the gauges that will be angled to tilt the gauges towards the driver. Ha Ha yeah that glove box will be getting redone I just haven't started it yet Thank you for your comments . Jim
    1947knuck and Mudgy like this.
  24. Mudgy
    Mudgy
    What are you using for a trunk latch?
    I notice your cars have external hinges.... how far up can you lift the trunk?
    Our Aussie made ones have internal hinges. Which means I'll be on my knees forever, if I want to get something from out of the back of the car.... damn!
  25. 56 Dodge Pickup
    56 Dodge Pickup
    With the external hinges I can lift the trunk lid all the way open I currently do not have a latch on the truck I believe the previous owner drove it without one relying on the weight of the trunk lid to keep it closed. I will be fabricating a trunk handle and latch stay tuned.
  26. Mudgy
    Mudgy
    Sorry to ask all these questions... your steering column - does it have to be swapped for a modern collapsible one?
    Most times down here, that's what's demanded of us. I don't mind doing the swap, I'd prefer not to be speared through the chest if there was an accident.
  27. 56 Dodge Pickup
    56 Dodge Pickup
    No we are not required to install a modern collapsible steering column although you definitely want to engineer in an angle through the couplings so you are not creating the spear affect. Please feel free to ask any questions I find it really interesting to see the differences in the country s Jim
  28. 40Ford!!
    40Ford!!
    56 Dodge Pickup.....damn brother, you are one handy builder. I like all the homemade stuff. Way to go!
  29. 56 Dodge Pickup
    56 Dodge Pickup
    Wow Thank you! 40 Ford I really appreciate your comment I love doing metal fab work. There will be more to come I've been busy working my regular job. Jim
  30. 56 Dodge Pickup
    56 Dodge Pickup
    I have made some more progress on my custom dash. I made the column drop and the bead rolling ties in with the factory switch panel a nice detail. Then I bolted my new gauge pod to the dash and installed the gauges. I really like the way this is going I will be starting the finish work soon looking forward to seeing how this comes out. Jim
