Blown 56 chevy gasser build for 2017 meltdown or bust
Discussion in 'The Hokey Ass Message Board' started by fast30coupe, Jan 19, 2015.
  1. fast30coupe
    fast30coupe
    from Illinois
    Not much work this weekend the little lady didn't work. But I managed to sneak in the garage a little and start on the pedals. I still have a lot of work to do but this is a good start. I think these are going to need to be chromed.
  2. fast30coupe
    fast30coupe
    from Illinois
    Finished the pedal ***embly. At first I didn't think the clutch master had enough travel but after some reading i have more than enough I'll add a hard stop soon.
  3. fast30coupe
    fast30coupe
    from Illinois
    Then I played around I cleaned the paint off my scoop. Turns out if was polished at some time so that will save me some money.
    I drove down to Indy to pick up some wheels I'll post pictures tomorrow.
    After that I went to the Nhra qualifying. I can still smell the nitro.
    I wish I could run my car on it.
    Butch M, Dog_Patch, deto and 4 others like this.
  4. fast30coupe
    fast30coupe
    from Illinois
    Here's the goods
    Has original Michelin radial x tires on them that aren't dry rotted. Look at the made in France!
    kiwijeff, Butch M, Dog_Patch and 4 others like this.
  5. cs39ford
    cs39ford
    WOW Nice Score !!!
  6. Dog_Patch
    Dog_Patch
    Like where this is going :D
  7. fast30coupe
    fast30coupe
    from Illinois
    Haha, the're ford spindle I have a model a thats a life project. Gotta get the good stuff when you find it.
  8. fast30coupe
    fast30coupe
    from Illinois
    Not much work this weekend. Went to the hunnert drags on Saturday was nice to see done cars run since I missed the meltdown. Would've been a good time for test and tune. I did get the door lined up better and started seeing what was needed to do the rockers next weekend.
    I also got some new wheels for the car.
    Who needs some blue streaks 8.90 x15
    Butch M, Dog_Patch and cs39ford like this.
  9. Smoothy
    Smoothy
    Makes me want to put the blower on my 56 build!
  10. fast30coupe
    fast30coupe
    from Illinois
    It's only right.
  11. fast30coupe
    fast30coupe
    from Illinois
    Got a little time in today. This sets me up good for Saturday. I got the doors braced up and ready to cut the outer rockers out. I also started to clean up the seat cross me ever I cut out today. It's fun cleaning off a 1/4 of under coating.
    This is putting me one step closer to getting the floor in then the seat in so I can sit in the car and make noises.
    Butch M, Dog_Patch, loudbang and 2 others like this.
  12. fast30coupe
    fast30coupe
    from Illinois
    After getting the rear wheels I had to find some fronts.
    American racing lemans. They are ford pattern no big deal though.
    I'll redrill my hubs for mock up and the brakes I plan on running are dual pattern.
    I did some restoration based on some info from shakey puddin
    There was a screw stuck in one of the holes so I made a dam out of grease and let Gibbs soak in
    After that I attempted to weld a screw to what was left that failed but I think that little bit of heat helped free the screw up so vice grips finished it off.
    Next I blasted the wheels
    I then used mag wheel etching cleaner to darken them up.
    They are a little splotchy but should even out with time. I'll get new caps.
    I also started on the drivers rocker
    Here's the inside I definitely don't feel bad for replacing these anymore.
    Started fitting the rocker it's pretty close.
    quick85, Butch M, Dog_Patch and 3 others like this.
  13. fast30coupe
    fast30coupe
    from Illinois
    Rockers welded in about 80%.
    Butch M, Dog_Patch and saltflats like this.
  14. saltflats
    saltflats
    from Missouri
    Looks like good progress.
    Do you have any test and tune planed for this year?
  15. geetarman502
    geetarman502
    Dayuuumm u beat to getting rockers welded in it's hard to find time. thanks for the inspiration great job!!
  16. DirtyDave
    DirtyDave
    Tell me more about etch wheel cleaner!? Big fan of darker. Mine are aluminum
  17. fast30coupe
    fast30coupe
    from Illinois
    Not this year maybe late spring next year. Hopefully get everything right for the meltdown.
  18. fast30coupe
    fast30coupe
    from Illinois
    Haha it's only one I still need to do the other side. I bought a harbor freight spot welder it's 200 but it will make for quick work once I get to the inner rockers and floor.
  19. fast30coupe
    fast30coupe
    from Illinois
    It's an eagle one product. I'm not sure what it will do on aluminum. It works good for magnesium. It's called eagle one mag etching cleaner.
  20. fast30coupe
    fast30coupe
    from Illinois
    Not much work on the car, but got the blue streaks taken off the rims. Then I cleaned the wheels off and soaked them with Gibbs.
    Can't wait to put these on the car. I might try for next weekend we will see.
    kiwijeff, Butch M, deto and 2 others like this.
  21. cs39ford
    cs39ford
    Wish they were on my car. Can t wait to see them on the car!
    fast30coupe likes this.
  22. low budget
    low budget
    from Central Ky
    Thought these were goin on the front til I went back and re read everything, a little confusing but Im back on track now:D
    Butch M likes this.
  23. fast30coupe
    fast30coupe
    from Illinois
    Would be cool but the cars a little heavy for no front brakes.
  24. fast30coupe
    fast30coupe
    from Illinois
    Got something to help make this a street car
  25. fast30coupe
    fast30coupe
    from Illinois
    Had a good weekend. Got the new front wheels on. I was having tube problems with the rear wheels so I couldn't roll the car outside that ****ed, but I'll order new tubes this week. I also painted the headlights blue and it completely changed the look of the car.
    I also got the drivers side rocker in.
    Also found a few more spots of cancer. One in front of the drivers wheel that I knew about, but was going to wait until I paint the car to fix, but I'm going to fix it now.
    And then one on in front of the p***enger wheel well where the inner rocker attaches.
    Hopefully that will be the end of the bleeding.
    Butch M, Dog_Patch, brut4s and 2 others like this.
  26. wrenchbender
    wrenchbender
    Looking good man just curious about the bleeding is it you or your wallet lol keep it up hope to see you at meltdown this year
  27. HEMIBERT
    HEMIBERT
    What kind of paint did you use on the headlights? Easy to do? Looks good.
    Thanks, Bert
  28. fast30coupe
    fast30coupe
    from Illinois
    Haha when I read your comment I did laugh out loud. I hope I make it this year too I've been trying for two years. I think the bleeding has just begun I still have to redo the injection, build a motor, and build the rear end $$$$$$$.
  29. fast30coupe
    fast30coupe
    from Illinois
    Thanks
    It's called dupli color metal cast. I was really easy to do I cleaned them gave them two coats and they came out great. Took 15 mins.
  30. fast30coupe
    fast30coupe
    from Illinois
    Rear wheels are on. Rolled the car out for some pictures. ImageUploadedByH.A.M.B.1444441119.526544.jpg
    quick85, nanos1932, kiwijeff and 8 others like this.
