Projects 49 Plymouth Business Coupe update
Discussion in 'The Hokey Ass Message Board' started by falconvan, Jul 26, 2013.
  1. falconvan
    falconvan
    from festus, Mo
    Fixed! The valve cover vent tube was supposed to be hooked to a fresh air tube on the throttle body but I had it hooked to manifold vacuum. It was ****ing oil right out of the valve cover into the intake. Great news but I am going to have to pull the trans back out as the throwout bearing is not disengaging the clutch. But compared to what I though I was going to have to do, that's pretty minor.
  2. cowboy1
    cowboy1
    from Austin TX
    Glad that's easy fix
  3. falconvan
    falconvan
    from festus, Mo
    OK, clutch is fixed, grill is on, and a couple of annoying oil leaks fixed. Should be road testing by next weekend! I decided to put a short build video together, check it out if you have 8 minutes to spare.
  4. falconvan
    falconvan
    from festus, Mo
    photo 1.JPG photo 3.JPG I should be doing a short road test tomorrow; over the last few days I wrapped up a lot of little stuff. I built a new shifter handle with some 1/2" stainless rod, wired the radio and put a check engine light in next to it, got the carpet and seat back in, plus some other goodies. Still a fairly good list of misc to finish but it should start making some short shakedown trips this week.
  5. falconvan
    falconvan
    from festus, Mo
    Success! Two short trips today without a hitch!
  6. honeyman
    honeyman
    from Steiner
    You sir are a maniac...I can't believe how much work you've done in a fairly short (to me) period of time. Great catch on the vent tube and best of luck with the computer work still to come, I'm sure you'll power your way through that as well. Looking freakin' great!
  7. falconvan
    falconvan
    from festus, Mo
    Thanks! Other than a few minor bugs to address, it's pretty much done. My wife and I gave it a bath today and took it out a little. It runs and drives really nice. Should be hitting the first show next weekend.
  8. Jersey Larry
    Jersey Larry
    Wow! This car came out amazing!!!
  9. falconvan
    falconvan
    from festus, Mo
    Well, after a year of driving I have to say I'm not too impressed with the setup. Runs great but the power band is really high on these, the gear ratio on the Ranger trans doesn't match well with the power band on the engine, bottom end power isn't very good, they don't sound very good through headers.....it's like a good looking girlfriend with a really annoying personality. You can only stand being around her for so long and then its time to go. So, back to the drawing board; I'm putting together a 451 stroker for it.
  10. Hnstray
    Hnstray
    from Quincy, IL
    hey Pat,
    Thanks for the update.....and the candor!
    Ray
  11. Peanut 1959
    Peanut 1959
    Really appreciate the update. Glad you went for it, still. :)
  12. falconvan
    falconvan
    from festus, Mo
    I'll just call it fabrication practice. Definitely not the first car I made changes to after I "finished" it.
  13. falconvan
    falconvan
    from festus, Mo
    The SHO motor left today on a truck to Milwaukee for it's new home in an Austin Healy Bugeye and I got some $$ to help finance the 400 swap. The crank and freeze plugs went in today; I'll be out of town working all next week but hope to get a little more done next weekend.
  14. patrick66
    patrick66
    I love that car! The 451 sounds like a good plan. It's cool you were not afraid to experiment with the SHO engine.
  15. falconvan
    falconvan
    from festus, Mo
    Thanks! I decided to just stick with a .030 400 with some bolt on goodies rather than doing the stroker but it will still be nice step up over the V6.
  16. falconvan
    falconvan
    from festus, Mo
    I did some prep work tonight; I couldn't find the right oil pump pickup for the rear sump pan anywhere as it's out of production and the pan itself was hard enough to come by. So I just welded on a 6" extension and it looks like it will work and clear the crank fine. Also pulled out the clutch pedal as I'm going with a 727 trans, pulled out the 5/16" fuel lines and pulled off the exhaust. I hope to get the short block together next week if the machine shop gets my pistons put on the rods.
    bct likes this.
  17. falconvan
    falconvan
    from festus, Mo
    Pistons and cam are all in. The more I looked at my oil pump pickup the more I didn't like it so I got this one from Milodon for a deep sump pan and did a little surgery on it. This fits much better and has a bracket to hold it in place. I also got the heads checked and resurfaced and started some mild porting. Nothing wild, just cleaning up the bowls and combustion chambers and port matching the intake. As soon as I get it all back together, I need to hunt down a 727 trans and start doing some trial fitting in the ch***is.
  18. 1949 caddyman
    1949 caddyman
    from arizona
    You may have said, but what is the engine make? I don't recognise it in the pics.
  19. falconvan
    falconvan
    from festus, Mo
    It's a chrysler 400.
  20. 1949 caddyman
    1949 caddyman
    from arizona
    What year would that be?
  21. falconvan
    falconvan
    from festus, Mo
    1975; came out of a Newport, I believe. Basically a low deck 383 with a bigger bore.
  22. falconvan
    falconvan
    from festus, Mo
    Got the short block finished up today along with one head ported and back together. Hopefully I can get the other head finished and have them bolted on in a week or so. Lots of hours at work for the next 6 weeks so I don't have much fun time to spare.
  23. Jersey Larry
    Jersey Larry
    I'm so glad to see you still have this car.
  24. falconvan
    falconvan
    from festus, Mo
    Thanks, Larry. How's it going with you?
  25. falconvan
    falconvan
    from festus, Mo
    Sad day today; my #1 garage partner Monica went home to Jesus. 15 years old; she was a good friend. :(
  26. patrick66
    patrick66
    I'm so sorry to read about your cat!
  27. falconvan
    falconvan
    from festus, Mo
    Thanks; it wont be the same without her hanging out in the garage with me. She saw a lot of projects come and go over the years.
  28. Jersey Larry
    Jersey Larry
    Sorry to hear about your cat. I'm finally getting settled in our new home in Florida. We are slowly making the house our home and hope to have a new project in the garage soon. Keep all your good work. I love reading your post
  29. falconvan
    falconvan
    from festus, Mo
    Thanks, Larry. Glad to hear you're doing well and starting to think about a project. Im sure you can find some nice rust free examples to work on in that warm Florida climate.
    I got the motor ****oned up today; time to bolt it to the trans and start building mounts and figuring out headers.
  30. falconvan
    falconvan
    from festus, Mo
    I did some trial fitting today and got the motor mounts built. Luckily I was able to reuse the mounting pads I built for the SHO motor and just moved them back. Also, the cutout I had made in the firewall for the SHO was the perfect width for the new engine. The big snafu looks like the factory steering box has to go; the motor is too wide. Looks like she getting a rack-n-pinion conversion. Also had to do some trans tunnel surgery but that was pretty minor. I ordered some block hugger headers and the next step is to modify the cross member for the trans.
