Technical 1954 Dodge Truck
Discussion in 'The Hokey Ass Message Board' started by hhoskison, Aug 23, 2015.
  1. hhoskison
    hhoskison
    from Texas
    I am working on a 54 Dodge C1-C6 pickup. The brake components are not available so I am changing the rear end to a 8.75 MOPAR. My question is on the front spindles will newer hubs with separate brake drum fit on the 54 spindles. Limited budget and do not want to change front end if possible.
    Jason Ezell likes this.
  2. 56 Dodge Pickup
    56 Dodge Pickup
    I used a kit from AAJ brakes for a disc brake conversion it uses the stock front spindles with modern rotors and calipers i'm not sure if that's the route you want to go just an option. Jim
  3. bomcadillac
    bomcadillac
    from Las Vegas
    Brake components are available from Roberts motor parts. I bought a disc conversion kit from scare bird. The problem is that the steering gear components are not available so there is no sense upgrading the brakes when the steering is trash.
