Technical Anyone run the same wheel size both front and rear?
Discussion in 'The Hokey Ass Message Board' started by moonami, Sep 27, 2015.
  1. moonami
    moonami
    i know most guys run a larger wheel in the back but was curious if anyone runs the same size wheel front and rear and stool achieve a nice rake?
    I've cut 1 coil and have 2" dropped spindles setup in the front and 2" blocks in the back. Curious to know if I can get a nice mellow rake without the need for a larger wheel/tire in the back.
  2. missysdad1
    missysdad1
    Drop the front tire a size or two on the same size rim for a very subtle difference in stance.
  3. moonami
    moonami
    Thanks missysdad1. I'm curious as to why a lot of guys have a larger rear wheel?
  4. mgtstumpy
    mgtstumpy
    Big & littles fill up the fenders. Running same size tyres & rims on my 46 Olds, F&R.
  5. HOTRODPRIMER
    HOTRODPRIMER
    Because it looks so darn cool on a hot rod. HRP
  6. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Your avatar? Hot Rods= For Sure! Customs= No
  7. moonami
    moonami
    Stumpy I like what you did there!
    HRP no doubt w that ride!
    So suggestions on my 58 Ranchwagon? I do really like the restomod vibe.
  8. motoandy
    motoandy
    from MB, SC
  9. moonami
    moonami
  10. timwhit
    timwhit
    Same wheel size, different tire size. I think THIS is the norm. Tim , edit....I'm trying to upload a pic but Hamb's not cooperating
  11. DeLuxe 32
    DeLuxe 32
    Ditto!
  12. gnichols
    gnichols
    from Tampa, FL
    I'd say no on American hot rods and race cars, for the most part. But ok for sports rods and customs. You can get your rake with rubber, or just start with the wheels and tires you want regardless of their sizes (always a very good idea) and build the rake into the frame as you fabricate it so the body sits like you want. Gary
  13. moonami
    moonami
    So for the wagon. Suggestions would be the same wheel size with a smaller tire up front. That should give it a subtle rake.
    Hot rods are the ideal candidate for the big littles.
    Any other examples of same wheel sized cars?
  14. Crusty Chevy
    Crusty Chevy
    both cars we have, have the same size so you can actually do a full rotate to wear them evenly
    tb33anda3rd likes this.
  15. moonami
    moonami
    Definitely looking at a custom setup. Might take the advice of the majority and same wheel different tire size.
  16. swade41
    swade41
    from Buffalo,NY
    Mine are the same size rim as well, with big n little rubber 11807738_917721544937844_5902720686056172867_o.jpg
    gfbracing and lothiandon1940 like this.
  17. DeLuxe 32
    DeLuxe 32
    Re-reading your question, you will find that the majority of cars have the same diameter wheel front and back and rake is achieved through tire size as well as other factors. Look at every hotrod with '40 ish wheels, they are 16" front and back, tire size however is always different.
  18. moonami
    moonami
    Hot rods look really good either way.
    That totally makes more sense to me now DeLuxe.
  19. I ran several sets of wheels on my 54 Chevy 210. Best looking set was 7 and 5" wheels with 195s front and cheater slicks or equivalent 235s rear. Sat fairly low witha nice rake.
  20. You don't have to have a rubber rake if that is what you are asking. You can do it all with suspension.
  21. denis4x4
    denis4x4
    from Colorado
    I'm running 16" wires on both my cars and the rake comes from big and little tires. As a side note, went from Excelsior bias ply tires to radials on the roadster and the rake all but disappeared. However, it drives and handles much better.
  22. Fif-t-3
    Fif-t-3
    from Edmond, Ok
  23. DeLuxe 32
    DeLuxe 32
    Why did you ditch the Excelsiors ? Which Im sure are not bias ply.
  24. denis4x4
    denis4x4
    from Colorado
    Went from Excelsior bias plys that were discontinued two or three years ago to Excelsior radials
  25. Gastrap
    Gastrap
    Same wheel & tire all around.
  26. DeLuxe 32
    DeLuxe 32
    Ok, so why did the rubber rake disappear? I'm about to buy a set ! 5.50 fronts and 7.50 rear.
  27. wex65
    wex65
    from WV
    Running 16 x 4 1941 (no, not 1940) original Fords front and rear, 450s and 750s. This setup gives me all the rake I need.
    DeLuxe 32 and lothiandon1940 like this.
  28. moonami
    moonami
    For the guys w same wheel size all around on your cars and wagons, are your rear wheels a wider width?
  29. I usually run fatter tires on the rear then on the front, it is hard to find tires the outside diameter in different widths though. Normally the narrow tires are shorter then the wider ones unless you use different aspect ratios on a radial or different manufacturers on a bias ply.
  30. denis4x4
    denis4x4
    from Colorado
    DeLuxe 32, Check the Coker catalog for tire diameters
