Camaro T5 transmission + Hurst shifter, bellhousing, clutch, starter
Discussion in 'Parts For Sale' started by 46Ford, Sep 20, 2015.
  1. 46Ford
    46Ford
    City: Vidala
    State: Louisiana
    Price: $500
    T5 trans out of 80's Camaro/Trans Am - not world cl***
    Hurst Billet Plus shifter
    Bellhousing for small block
    153 tooth flywheel for 2 piece rear main
    Clutch that was used with this setup
    Starter for 153 tooth flywheel
    Trans and everything else (except shifter) was in a non Hamb project car I'm working on.
    Bellhousing rotates trans a few degrees toward the driver side for slave cylinder clearance in the Camaro. I don't have the slave or any of the bolts. Trans will bolt up to regular Chevy BH.
    Clutch looks like it has a lot of life left. I drove this car for several thousand miles before I pulled it and it all worked well. Flywheel and bell should bolt up to later in line sixes and all 2 piece rear main small blocks except 400.
    I want to sell all of it together. Pick up only.
  2. 46Ford
    46Ford
  3. 46Ford
    46Ford
