Sbc tri power with hei?
Discussion in 'The Hokey Ass Message Board' started by olds vroom, Sep 27, 2015.
  1. olds vroom
    olds vroom
    Does anyone make a sbc tri power intake that you can use an hei distributor?
  2. No, but what is wrong with running points, millions of cars have run them with no problems.......
    saltflats likes this.
  3. Rex_A_Lott
    Rex_A_Lott
    I like the HEI, I raced one for years in a dirt car, they work well. They even look good on '70's and up muscle cars. BUT, to me they look out of place with the tri-power setup. If you dont want points there are other options to run electronic with the small cap and it looks better IMHO.
    volvobrynk likes this.
  4. chevyfordman
    chevyfordman
    I run three 2jets DSCN2652.JPG with a DUI distributer which is electronic, very small.
  5. dirt t
    dirt t
    Bubba built me a small cap HEI with vacuum advance. The module mounts on the bottom of the housing.
  6. oldolds
    oldolds
  7. swade41
    swade41
    from Buffalo,NY
    Tri/power and hei, thought I was on the HAMB
  8. 59Apachegail
    59Apachegail
    from New York
    I thought the only limitation was the hole diameter on the manifold. I think you just need to make the hole bigger. I also thought you can convert points distros to HEI. I could definitely be wrong on both points.
  9. You don't have to have a big honkin distributor to run electronic.
    Sometimes when we change on little thing we have to change several other little things to make it work.
  10. volvobrynk
    volvobrynk
    from Denmark
    Driving under influence?
    Nice detailed engine
    chevyfordman and HOTRODPRIMER like this.
  11. HOTRODPRIMER
    HOTRODPRIMER
    I guess I'm having a senior moment but what the heck is a DUI distributor? HRP
  12. 34toddster
    34toddster
    from Missouri
    I ran an Offy 3 2 manifold on my OT El Camino, I machines the back of the intake on the mill for clearance, worked fine if you just have to run a large HEI.
  13. 48stude
    48stude
  14. FrozenMerc
    FrozenMerc
    DUI = Davis Unified Ignition
    Nothing wrong with points and a condenser in a street motor. I am a big fan of Pertronix if you feel the need for electronic ignition. At least it looks right, no need for the ugly *** HEI coil or big MSD box.
    crminal and volvobrynk like this.
  15. Ran a small body HEI with a tri power for years _CAM6325.jpg . No issues.
  16. swade41
    swade41
    from Buffalo,NY
  17. Blue One
    Blue One
    from Alberta
    There used to be a guy who built small body HEI's , Dave's small body HEI's but I think he may be out of business now.
    A small cap GM distributor from Pertronix is probably the best way to go.
  18. HOTRODPRIMER
    HOTRODPRIMER
    Thanks for explaining that. HRP
  19. Damned Unfriendly Ignoramus. :D :D
    I don't recall what the letters stand for but it is a good ignition as aftermarket ignition goes. pretty near bullet proof.
  20. BigDogSS
    BigDogSS
    from SoCal
    Still in business as far as I know --> http://www.davessmallbodyheis.com/
    What makes you think he is out of business?
    I have one on my OT Impala SS on a 327 right now and it works great.
  21. Blue One
    Blue One
    from Alberta
    I was unable to get to his website for some reason and there was some talk on another forum that they were having trouble contacting him and that he had some health issues.
    Other than that I have no idea.
  22. primed34
    primed34
    Just tried the link. Didn't work. I'm also looking for a small hei type.
  23. check out Bubba on here, he is a distributor master of masters and has a damn good "speedster" hot sauce as well.
  24. bobss396
    bobss396
  25. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    HUH?
    1956 F100 likes this.
  26. gimpyshotrods
    gimpyshotrods
    What the what?
  27. bobss396
    bobss396
    Yeah, stop serving that guy and call him a taxi.... we all been there....
    gimpyshotrods likes this.
  28. 59Apachegail
    59Apachegail
    from New York
    You can either bore out the hole in the intake manifold so that the larger HEI distributor shaft will fit through
    or
    there was someone who was converting points distributors to HEI. Seems like others on this thread also mentioned these options.
  29. squirrel
    the problem is the rear carburetor won't clear the larger HEI housing...
    AHotRod likes this.
  30. 40fordtudor
    40fordtudor
    A number of V8 GM pickups used a small HEI with the module on the firewall--this may be an alternative.
