Projects 28/29 rpu .... av8 sheetmetal work
Discussion in 'Traditional Hot Rods' started by Flop, Sep 29, 2015.
  1. Flop
    Flop
    real nice solid start
    door ... another story
    put the welder down !
    patch panel put in !
    extra firewall holes
    more patches
    filled in
    rivets ...just like ford
    one piece
    9 billion spot welds holding the back panel in
    seems like its missing some things
    ford gaps
    cup full o rivets
    new back panel sitting in
  2. Flop
    Flop
    riveted the back panel in
    put a brookville door on the drivers side . bad fit but eventually got it fitting well
    all one piece
    found a mess in the p*** door
    allll together
    the owner did the ch***is and motor work
    thanks for looking folks !!!
    lodaddyo, Drewfus, Texas Webb and 4 others like this.
  3. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    Great work, and you did it all in only a couple posts! So what are you doing AFTER lunch?
  4. Flop
    Flop
    took 10 days !
    HOTRODPRIMER likes this.
  5. HOTRODPRIMER
    HOTRODPRIMER
    I always enjoy seeing your work,thanks for taking the time to share. HRP
  6. bct
    bct
    If you find the time please elaborate on how you do your rivets.
  7. I think he burns them in with a TIG on the backside IIRC. Tom, Always great to see what you've been up to. How's the arm been feeling?
  8. 31ster
    31ster
    Here it is in primer
  9. Dean Lowe
    Dean Lowe
    Man, that is getting a '29 RPU cab the hard way!! Nice job saving it.
  10. I ***embled the brookeville bed on my truck using the rivet and tig torch method. It actually works better than I thought it would. I clamped the panels tight, drill the hole, clean up the burrs, then I made an aluminum buck with a small dome machined into it to support the rivet head, clamp the buck to the panels with the rivet trapped inside tight, then just heat the shank of the rivet into a ball with the tig and then let it spill over onto the panel slightly and let it cool. If all goes well you put most of the heat into the rivet so it contracts when it cools and squeezes the panels together.
    lodaddyo and bct like this.
  11. great work, great to see the detail.
    Cheers,
    Drewfus
