comet/falcon exauhst?
Discussion in 'The Hokey Ass Message Board' started by zimm, Feb 16, 2006.
  1. zimm
    zimm
    from iowa
    what do u think i shoulf run for exhaust on my 61 comet 144 i-6 w/ stock manafold i was goin to dual it out w/ stright pipes. what size pipe should i use i was thinking 2 in but would 1.5 be better, what about backpresser? sound? any one out there running no muffs on there comet falcon whats it sould like?
    LETS SEE SO PICS ON THE COMETS!!!
  2. zimm
    zimm
    from iowa
    SORRY CANT TYPE VERY WELL!!
    lets try this
    what do u think i should run for exhaust on my 61 comet 144 i-6 w/ stock manafold i was goin to dual it out w/ stright pipes. what size pipe should i use i was thinking 2 in but would 1.5 be better, what about backpresser? sound? any one out there running no muffs on there comet falcon whats it sould like?
    LETS SEE SOME PICS OF THE COMETS!!!
  3. Tito
    Tito
    from Sacramento
    I have pacemaker full length dual outlet headers, 144ci connecting to 1 1/4" pipe, straight back exiting out under the bumper with peashooters. Loud. Smaller diameter pipe creates more backpressure.
    ***o
  4. Powerband
    Powerband
    My 61 Comet has a set of ****** Dual Outs that go from Collectors to Stainless steel flex fittings then to separate Turbo type mufflers than to a Y pipe feeding the Xhaust Splitter(Dump). The cable allows me to: 1) run through the additional rear Gl***pack in the stock position exiting under rear right bumper or 2) Dump out the side through an angle tipped pipe in front of rear right wheel. The dump still exits after the dual turbo type mufflers.
    I can go quiet with gl***pack low frequency or raspy loud with open xhaust rumble. And it sure feels faster with the dump open!.
    The flapper valve contolling the dump broke after @ 1/2 hour. I had to disconnect the pipes and MIG it up in place in the cast Dump fittiing. After that it was just fun , fun , fun.
    Powerband
    More Comet and other car albums at:
    http://photobucket.com/albums/v296/Powerband/
  5. A buddy of mine has a falcon set-up with dual straight pipes dumping straight into mufflers. The mufflers end at about mid body. He's runnin a HO289 so obviously it sounds mean but that set-up would be a cheap try. Otherwise just get a bunch of 10 foot sections and try out as many set-ups as you can untill you find something that fits your needs. Just don't go too small on diameter or you'll end up sounding like a missile. I'd say between 2 and 2-1/2. Depending on how far back the exhaust goes.
  6. Barn-core
    Barn-core
    I did the same thing to my '64 Falcon Wagon that I did to my old '62 Comet. I cut the muffler off and went down to Home Depot and bought a length of 1.5 electrical conduit to run a straight pipe out the back. Cheesy I know, but stick a chrome tip on it, and none shall be the wiser. Raps like a *****. I would eventually like to split the manifold, and run true dual straight pipes. By the way I've heard ***o's Falcon and it soulds *****in'.
