Technical dash top tach tech (tech week)
Discussion in 'The Hokey Ass Message Board' started by 49ratfink, Oct 2, 2015.
  1. 49ratfink
    49ratfink
    first thing you need to do is find a bullet tail light that fits your tach, that is probably going to be the hardest part. I didn't think of this idea until I saw the tail light at a swap meet. I think I may have had to trim the front edge on this one to make things work right.
    then you need to work building elevators for a couple years and bring home all sorts of little extra parts like the bracket shown below... I suppose you could bend your own from flat stock, but then it would not be cad plated.;)
    the rest is kind of self explanatory. drill 3 holes in the bracket, gather up some hardware, a stainless allen head and drill a hole in the back of the tail light, it is kind of countersunk as well.
    ..then put it all together like you knew what you are doing all along.
    my dash is curvy on top, so I mounted it directly to the dash. you may want to use a spacer of some sort.
    Hnstray, scotty t, HEMI32 and 8 others like this.
  2. Bulletnose26
    Bulletnose26
  3. 49ratfink
    49ratfink
    here is the rest of the dash.... now say DASH TOP TACH TECH 5 times really fast.
    scotty t, LOST ANGEL, HEMI32 and 5 others like this.
  4. weps
    weps
    from auburn,IN
  5. That's pretty slick.
    I might get some mileage out of this one myself
    lothiandon1940 and volvobrynk like this.
  6. Max Gearhead
    Max Gearhead
    from Wisconsin
  7. mad mikey
    mad mikey
    Very cool! Looking good.
    lothiandon1940 likes this.
  8. akoutlaw
    akoutlaw
    That's a cool idea. Thanks for posting it. :) Bill
  9. 49ratfink
    49ratfink
    this is what I call found metal engineering. I'm standing there with the tach in one hand and the taillight in the other looking at a pile of misc metal and this bracket is sitting there almost perfect. I didn't have to do much thinking.
  10. Looks good, any better shots of the lower gauges?
  11. 49ratfink
    49ratfink
    just some tube welded to the bottom of the dash. here's a close up
  12. jcmarz
    jcmarz
    from Chino, Ca
    Reminds me of a Chevy clock
  13. Yeti Man
    Yeti Man
    from NorthTexas
    That is slick!
    49ratfink likes this.
  14. i.rant
    i.rant
    Looking good,great idea.
    49ratfink and lothiandon1940 like this.
  15. lothiandon1940
    lothiandon1940
    I like it.:)
    49ratfink and i.rant like this.
  16. 56don
    56don
  17. Finnrodder
    Finnrodder
    from Finland
  18. clem
    clem
    Simple, - but also brilliant. I like it !
    Nicely done.
  19. rusty1
    rusty1
    ...in the old days we used a chrome bicycle headlite for a bucket
    lothiandon1940 and 49ratfink like this.
  20. Bugguts
    Bugguts
    Very cool. I might copy this one.
  21. slowmotion
    slowmotion
    Pretty slick.
  22. jdownunder
    jdownunder
    nice job
    i was thinking along the same lines 38 chev tail light is good fit
    thanks for sharing
  23. indyjps
    indyjps
    Could you mount it with lamp pipe to p*** the wiring thru. I'd weld a nut on one side to make a bolt. If you've ever mounted a ceiling fan you've seen this stuff. Different diameter is available to keep you dash hole size under control
