Projects Swedish 40 Willys
Discussion in 'The Hokey Ass Message Board' started by Tomastudor, Apr 7, 2014.
  1. Tomastudor
    Tomastudor
    And the Willys in color:)
    kidcampbell71 and kiwijeff like this.
  2. elgringo71
    elgringo71
    Is that a Rootbeer brown color? It's looking good, can't wait to see it painted and bolted back together.
  3. Tomastudor
    Tomastudor
    Its called Mahogany Brown and I also would like to see it put together but its gonna take a while.
  4. loudbang
    Good choice on the paint color.
  5. Tomastudor
    Tomastudor
    My Willys in the sun to see the color and have started with the sound deadener. Had to install the instrument cluster just to see how it looks, I like it.
      354.6 KB
      455.2 KB
      417.9 KB
    kiwijeff, elgringo71 and Sjoestroem like this.
  6. Tomastudor
    Tomastudor
    Have done some work on my Willys decided where the ac and heater hoses should p*** the firewall.
    Mounted the fuel pressureregulator and some more soundproofing.
    elgringo71 likes this.
  7. Tomastudor
    Tomastudor
    Last month I have wired most of my Willys. I have placed the Holley Terminator ECU in front of the p***eners feet and covered it with an extra floor. The cruise control unit is on the left side of the cowl an ther fuse panel on the other side of the brake pedal. And the switches and hibeam turn signal indicator is also done.
    Sjoestroem and loudbang like this.
  8. Tomastudor
    Tomastudor
    Most of wiring is done on my Willys, have installed the driver side glovebox, parking brake is also there.
    Sjoestroem likes this.
  9. loudbang
    Getting close now. Do you have to go through a giant inspection to get it on the road over there?
  10. Tomastudor
    Tomastudor
    I guess its a lot more than you have to do, first a ch***is inspection they check for weak construction, bumpsteer and those things it is already done. Then a road test where brakes and handling is checked, these checks are done by SFRO " swedish vehicle builders organisation". After that a final check where the car is checked for safety and emissions the same way all cars have to do in Sweden
  11. Tomastudor
    Tomastudor
    Test fitting the headlights, I have used 5 3/4" H4 headlights behind the original Willys lenses and a turnsignal kit from Willys replacement parts. The car came with only garnish mouldings for the windshield and I did not want to pay $2500 for a new kit.
    I bought garnish mouldings for a 36 Chevy for $60 + shipping and a lot of cutting, welding,hammering and heating they look pretty god. No I will not chrome them its bondo time.
  12. Tomastudor
    Tomastudor
    Started with the engine for the Willys today its a 4-bolt Chevy 350 with .030 overbore.
    I am using a Howards hydraulic roller cam so I started with test fitting the cam ****on, it didnt work with the aluminium timingcover I intended to use.
    Cleaned an old cover reinforced it with a steel plate and checked the play for the cam ****on and it was OK
  13. elgringo71
    elgringo71
    You are making nice progress
  14. Tomastudor
    Tomastudor
    Thanks its been a lot of bodywork lately so its nice to do something else.
  15. Tomastudor
    Tomastudor
    Started the final ***embly of the engine, installed the Eagle crank, Cloyes timing set and the Howards cam.
    Also checked the deckheight of the engine the pistons where 0.007" down in the bore and with a 0.039 headgasket I think thats fine.
  16. Tomastudor
    Tomastudor
    The ***embly of the engine for the Willys continues, the shortblock is done and the Edelbrock heads are there.
    Have checked the pushrod length and it looks fine
  17. 3day
    3day
    from UK
    Interested in knowing more about using the 36 Chevy mouldings, how many sets needed, how similar are they to Willys? Thanks
  18. Tomastudor
    Tomastudor
    I bought 4 from a 36 Chevy 4-door, the ones from the rear doors where enough to do the rear windows. For the Willys doors i used the ones from fronts that whas much more work, more cutting and welding. The Chevy moulding are a little to thick I had to make them thinner. I can take some pics if you want.
  19. Tomastudor
    Tomastudor
    Working on my Willys, have painted the inside of the front section gloss black and red on the DeLuxe emblem on the dash
  20. jays41willys
    jays41willys
    from nj
    yes please.some picts of making the molding.thanks jay
  21. Tomastudor
    Tomastudor
    OK here are the pics, I didnt take any while I was making them but you can see the cuts. Make cardboard templates from the the car find a suitable piece from the garnish moulding, cut it out and make new templates, new pieces and weld them together. First 4 pics are the door garnish I had to make a new bottom piece the Chevy moulding where not long enough. The rear windows are just 4 carefully cut pieces
    3day and loudbang like this.
  22. 3day
    3day
    from UK
    Thanks for the info, reckon I need to find me some chevy moldings!
  23. Tomastudor
    Tomastudor
    The evaporator installed behind my Willys dash, not much room for anything more.
  24. Tomastudor
    Tomastudor
    Finally the Chevy 350 installed in my Willys
  25. Dick Stevens
    Dick Stevens
    Looks real good in there!
    [​IMG][​IMG]
    kidcampbell71 and loudbang like this.
  26. Tomastudor
    Tomastudor
    Last weeks its been hard to focus on my Willys, why a couple of days ago I bought this barnfind.
    A 34 Ford Fordor that has not seen the sun or rain in more than 40 years. Now I know what to do when the Willys is finished:)
    kiwijeff and 3day like this.
  27. kustomchry
    kustomchry
    from Norway
    Nice work you do on the Willys, looking forward to see it live. And what a great barnfind, not many left up here in the north!!
  28. Tomastudor
    Tomastudor
    Thank you, Yes the Willys will be running next summer and it was nice to find a car like that.
  29. Tomastudor
    Tomastudor
    The wiring, fuel hoses, trottle and TV cable done on the engine.
  30. Tomastudor
    Tomastudor
    The under side of the Willys is almost done, only the exhaust system and some small parts left
    kidcampbell71 likes this.
