Hot Rods Rochester Carburetor Rebuild
Discussion in 'The Hokey Ass Message Board' started by bustingear, Oct 2, 2015.
  1. bustingear
    bustingear
    Rebuilding some old Rochester 2 barrels from 1958. All going good except I am trying to pull the small T's out over the spring and the discharge ball. I put the needle nose on them and pulled like hell. It did not move. I don't want to screw them up as I don't have others. I have had the units in chemidip and sprayed them with penetrant. Still no action. They have even been boiled. Suggestions and tricks please.
  2. grab it as hard as you can with the needle nose and wiggle, it is staked. It may break, but you get one in the kit.
  3. bustingear
    bustingear
    10/4 just looked in the kit and there they are.
    Thanks
    I will twist it around
    PS anyone know where I can get a couple of those bowl vent stainless clips? for a 2G?
  4. 59Apachegail
    59Apachegail
    from New York
    If your talking about the little horse shoe things that are crimped around the shafts, they should be part of your kit. ImageUploadedByH.A.M.B.1443836111.616959.jpg
  5. bustingear
    bustingear
    No these are external clips that hold a grommet to cover a hole above the bowl
    They are mechanically operated by the linkage to open and close
  6. 59Apachegail
    59Apachegail
    from New York
    I know what you mean now, I don't think you can find those new on the after market. You might need to find used spares.
  7. saltflats
    saltflats
    from Missouri
    I may have some
    Let me look
  8. saltflats
    saltflats
    from Missouri
    I found these two
    one looks like someone bent the tab in the wrong direction it may brake off if bent back
    I may have some more at my shop in town I can check when I go back Monday if you don't find some. 20151003_094715.jpg
  9. 59Apachegail
    59Apachegail
    from New York
    Those look like they are good.
  10. PontiacPower67
    PontiacPower67
    Do what I did on my 400 that had a Qjet....
    Get a Holly!!! LOL
    I know I know.. Here we go...
