Art & Inspiration Tech Week – Making a Column Transition From A Lampshade
Discussion in 'The Hokey Ass Message Board' started by D-Russ, Oct 3, 2015.
  1. D-Russ
    D-Russ
    Number three for my man Steve:
    For my steering column, I'm running a super simple 1-1/2 inch diameter tube with bearings at each end and a factory 65 Nova steering shaft. I cut a double D shape at the box end of the shaft, and because the wheel end of the shaft already had GM splines, I could easily install my 58 Chevy wheel.
    The problem was the steering wheel center was a lot bigger than the column diameter, and GM column transitions from the era mate to larger diameter column tubes.
    So I had to make a column transition. Here's how I did it:
    I looked around at office supply and department stores for a metal lampshade with a conical shap I found appealing. Found this one for $12 at Bed Bath and Beyond.
    First, I cut it down to the correct size.
    Welded up all those little slots. Migging the thin material was tough.
    I ground down the welds.
    Then I cut a couple of wood donuts to insert inside the transition to center it on the column and to give me something sturdy to mount my tach onto.
    Then I glued the donuts into the transition with some JB Weld.
    And here's the finished piece.
    embyman68, Hnstray, cfmvw and 13 others like this.
  2. williebill
    williebill
    You're a pretty talented guy....... well, maybe not pretty, I dunno
  3. HOTRODPRIMER
    HOTRODPRIMER
    Now that's thinking outside the box,looks like a factory piece.
    On a side note,the slots wouldn't bother me,fact is they have a lot of character, HRP
  4. GTS225
    GTS225
    Now, that's hot rodding! Second-hand stores can also net you pieces just like that.
    Roger
  5. Racer29
    Racer29
    I'm with HRP, I kinda like the slots but great job either way. It's simple and I like simple.
    falcongeorge likes this.
  6. Dan in Pasadena
    Dan in Pasadena
    Yeah, and the slots woulda cooled the mechanicals! Lol
  7. mad mikey
    mad mikey
    Great idea! That came out nice, and the price is right as well. A win win.
  8. Bulletnose26
    Bulletnose26
    That is very out of the box thinking. Nice job.
  9. rusty rocket
    rusty rocket
    Kool. Im with a few of the others on the slots. A guy could have cut some backers and j.b. welded them to the inside so you couldnt see to the inside.
  10. Buddy Palumbo
    Buddy Palumbo
    I may be crazy , but I kinda liked the slots as well . Either way , splendid job !
  11. fordor41
    fordor41
    I liked the slots also. maybe paint the wood block black and let it show thru
    falcongeorge and Hudson52sam like this.
  12. 55 dude
    55 dude
  13. Yeti Man
    Yeti Man
    from NorthTexas
    That is a great idea!
  14. Wooster
    Wooster
    from Soso, MS
    The slots were the first thing to catch my eye and I immediately started thinking about how they would look if you dimpled them in.
  15. 56don
    56don
    Why thats so simple even I could do it!
    I think you should have put neon lights in the slots...:eek:
    oldandjaded likes this.
  16. olscrounger
    olscrounger
    Looks great--ingenious solution!!!
  17. theHIGHLANDER
    theHIGHLANDER
    Put me in the liking the slots crowd. Awesome thinking and imagination there. I'd have used some stainless screen and epoxy glued them in behind the slots to give it even more character, but smooth rules too. Great idea...
    falcongeorge and sko_ford like this.
  18. CadMad
    CadMad
    All you guys who " love the slots" should hire a bus and go to Las Vegas and get it out of your system. haha
    We have a local s**** merchant and I can spend hours looking for uses for all the cool stuff thrown away.
    Hnstray likes this.
  19. GTS225
    GTS225
    A "tuner" would have put (gag) LED's behind the slots.
    Roger
  20. Andy
    Andy
    The column turned out great!
    I thought I would share a similar deal. Pic is of my 3W built in the late 60's. It has a 64 Revi tilt column cut down to fit on 1 1/2" tubing so I could use the 32 drop. The transition piece is a Melmac coffee cup with the bottom cut out. I epoxy'd it on. Still there after almost 50 years.
  21. Vern01
    Vern01
    I just through out a set of double lamps like you used two days ago, had been tripping over them in the shop to long, to late for a dumpster dive, the trash man already took them
  22. Hudson52sam
    Hudson52sam
    Really cool and creative, got to be creative now adays,and the slots did look cool
  23. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I wouldn't use LEDs but I would put *** lights behind the slots. (Purple?)
  24. Nailhead Jason
    Nailhead Jason
    Simple and really slick looking. Totally dig it.
  25. Blue One
    Blue One
    from Alberta
    Is that shade stainless steel ? And you used mild steel mig to weld up the slots ? Horrors :D:D
  26. Nice job David!
  27. Blue One
    Blue One
    from Alberta
    Cool, I don't know how many times I have seen guys just go at it (stainless) with mild steel mig wire.
    On something like that it would not likely have made much difference if the plan was to paint it however it's good to see something done right. :)
  28. TomT
    TomT
    Pretty slick, Dave - that old shade never looked as good as it does now!
  29. Smokin Joe
    Smokin Joe
    Great thinking. You can find great bendable hoses in the shower head area of your local home depot or lowes to use to cover your headlight wires from the light to the frame too. Also I like useing the piston rods from your old grenaded engine for the column drop. Adds a little sentimental value to the new ride. Always try to encorporate stuff from the old into the new when you can.
