Art & Inspiration Tech Week – Relocating Electrical Leads
Discussion in 'The Hokey Ass Message Board' started by D-Russ, Oct 3, 2015.
  1. D-Russ
    D-Russ
    Here's number two Steve – a low profile, rigid way to relocate electrical leads. This example is a starter solenoid, but the concept could be applied to many different wiring challenges.
    Things were getting really tight between the frame rails and the engine on my current build (Model A, Deuce rails, 354 Chrysler). Because I'm running block hugger headers and I tucked the exhaust so close to the oil pan, there was no way to make the electrical connections to the starter solenoid because they were pointing down, straight into the exhaust. That meant I had to move the leads to the opposite side of the solenoid. Here's how I did it.
    I cut up a piece of copper plate into two strips.
    I bent them around the solenoid.
    Then I press fit and soldered new threaded leads on the relocated ends.
    And to wrap it up, I insulated the copper strips with shrink wrap and slipped a strip of rubber insulation between the leads and the solenoid.
    Here's the starter installed. The blue at the bottom is the frame rail.
    LongT, gonmad, hipster and 12 others like this.
  2. okiedokie
    okiedokie
    from Ok
    Nicely done.
    lothiandon1940 likes this.
  3. King ford
    King ford
    from 08302
  4. GTS225
    GTS225
    Yes.....quite nice, and a hell of a good idea. Me, I would be concerned with a long-term stress crack developing in the copper from vibration, but that might take a loonnng time.
    and you're right.....things are getting a bit tight in there.
    Roger
  5. Bulletnose26
    Bulletnose26
    Very slick. Nice, clean work.
  6. ago
    ago
    from pgh. pa.
    Great Idea!
  7. righty tidy man.
    Some of the semi engine builders have a similar setup on their starter solenoids to add additional power terminals.
  8. belair
    belair
    very sanitary
  9. Rocky
    Rocky
    Classified Editor
    Now, why didn't I think of that? The HAMB is a great place to stea-er, borrow ideas like this.
    hipster, brad2v and lothiandon1940 like this.
  10. 55Caddy62
    55Caddy62
    Beautiful job!
  11. Rusty O'Toole
    Rusty O'Toole
    Should work great when it's cold.
  12. lothiandon1940
    lothiandon1940
  13. pat59
    pat59
    Nice and neat. I like it! :)
  14. olscrounger
    olscrounger
    very nice and creative work-I like it.
  15. 55willys
    55willys
    Nice and clean
  16. Hotrodmyk
    Hotrodmyk
    Very cool and soooo sano!
  17. Finnrodder
    Finnrodder
    from Finland
  18. gatz
    gatz
    very nice work...looks great
  19. Very clever! I'll note that you don't need to use copper buss for this; aluminum will work just as well, although you may need to increase the cross-section slightly. You can even laminate the bus from multiple pieces of thinner material (which from an electrical standpoint is actually better) if you have issues forming the thicker material or don't have it available. A cross-section of .3 square inch will carry 250+ amps, enough for nearly any starter load.
    hipster likes this.
  20. Johnny99
    Johnny99
    Slick! That's why I watch this show.
    Thanks
  21. Buddy Palumbo
    Buddy Palumbo
  22. tb33anda3rd
    tb33anda3rd
  23. Bugguts
    Bugguts
    This is better than anything Red Green comes up with. Good idea for a tough problem.
  24. Smokin Joe
    Smokin Joe
    And no duck tape needed...
  25. bobss396
    bobss396
    Very neat... copper is a breeze to work with too.
  26. 29AVEE8
    29AVEE8
  27. tb33anda3rd
    tb33anda3rd
    good tech, this is something i will do.
  28. The 39 guy
    The 39 guy
  29. 383deuce
    383deuce
    I for one like this idea......
    tb33anda3rd likes this.
