Technical 1939 Mercury Build
Discussion in 'Traditional Customs' started by swissmike, Jun 28, 2015.
  1. swissmike
    swissmike
    Made the trunk floor today using the same method as the floor. I left a couple of inches on all sides to get a little less war page in the panel.
    The trimmed floor is trial fit. The flange on the first panel helps.
    I formed a flange at the end of the panel to keep it flat. The wood piece clamped ***he rear crossmember Keeps the panel at the correct final height.
    Kage and chryslerfan55 like this.
  2. swissmike
    swissmike
    Now on to the two filler pieces. I chose a size that allows me to finish the tapered section. I made a cardboard template first and transferred it to metal.
    Getting all the angles right and gaps aligned with multiple bends takes a little effort.
    Second side tacked in.
    Everything welded solid and finished. I hope to finish the corner pieces tomorrow.
  3. 36 ROKIT
    36 ROKIT
    Yowza; nicely done!
  4. CadMad
    CadMad
    It's always a pleasure to look at high quality workmanship.
    swissmike likes this.
  5. swissmike
    swissmike
    Got a late start today and I underestimated the time it took to make a template of the two rear extension on the trunk panel on either side of the recess for the tool box.
    I fit the template in the body shell and made minor adjustments until the fit was satisfactory and matched the rusted out original as far as I could tell.
    Here is a detail of the body mount. The cupped washer is spot welded to the trunk panel. I measured that I needed 1 1/4" of depth in the panel to get it to the right height.
  6. swissmike
    swissmike
    The plan is to use the wooden buck and an aluminum puck and shape the cup shape using the hydraulic shop press.
    I sprayed the bottom of the panel and the buck with spray adhesive to increase the friction, the clamp the top wood pieces down to keep the panel flat during the process.
    First try with the aluminum puck cut the panel around the puck. I only had a small chamfer on it and didn't expect it to cut the panel.
    I cleaned up one of the original cupped washers and used it to more evenly spread the force. I used grease between the washer and panel.
  7. swissmike
    swissmike
    This seemed to work better, but the panel really stiffened up before I got to the desired depth. Maybe it needs just some extra pressure... there, now it starts moving again... Oops...Mercedes hubcap anyone?
    The bitter taste of failure...
    Let's try again and stop when the panel starts to stiffen, then mark the depth on the press and repeat with the second panel.
    Success! About 1/4" short of the stock height, but will fabricate a washer to take up the space.
    Now I have two pieces to shape the missing corner pieces. Not the most productive afternoon...
  8. Great stuff Mike.. and learning is a productive process too! ;)
    Dave
  9. Hey, even Thomas Edison had several successful failures when inventing the light bulb. Thanks for showing the mess-ups / lessons learned as you determined the correct process. Great work!
    Toyjunky likes this.
  10. X38
    X38
    I disagree. You learned something, achieved something ...and shared it with us. I think that's very productive!
  11. Olson
    Olson
    More great work. Thanks a lot for including the mess it took to get there.
    You mentioned using spray adhesive to increase the friction of the sheet and bottom form. Did you try one without the adhesive? I'm wondering if the slightly lower resistance may allow the puck to full from farther out and get you that last 1/4". Just curious, as I have only limited experience with forming. Looking forward to seeing the finished floor.
  12. swissmike
    swissmike
    I tried that and it resulted in the failed sample with the fold in the material (middle sample in the picture). The problem is that the the force causes less material stretching around the outer periphery than in the middle at the edge of the puck, because the same force is spread over a longer distance. The material wants to fold rather than stretch at the outer edge.
  13. Olson
    Olson
    Makes sense. Thanks.
  14. southpaw-customs
    southpaw-customs
    swissmike, If you turn a 90 degree flange all the way around the part to be pressed it will have less distortion.
  15. swissmike
    swissmike
    Agreed, but I feel that I reached the maximum possible deformation with this set up, regardless of the edge treatment. The two finished panel each only had a small wave which could be hammered out with a couple of blows. I used the 90 degree flange idea on the back edge of the trunk floor, but only after hammering the beads.
  16. southpaw-customs
    southpaw-customs
  17. DirtyNapkin
    DirtyNapkin
    from Napa, Ca
  18. swissmike
    swissmike
    I transferred the shape of the panel to piece of wood that I can use to shape the metal. After marking the outline I used an adjustable wrench to gradually bend the edge, followed by planishing with the dolly against the wood.
    Cutting another template to help transfer the outline of the new panel.
    Tacking in the new panel and test fitting the whole trunk floor.
  19. swissmike
    swissmike
    Fitting the second side in place ensures a correct fit. No rush here, this needs to be accurate else the panel will never fit correctly.
    Looking good so far...
    Welding and finishing after removal from the body.
  20. swissmike
    swissmike
    The original cupped washers were cleaned up and primered before spot welded to the panel. I will make a 1/4" spacer to account for the less than stock depth of the recess.
    Finished, shaped panel. Still needs the openings for fuel sender, filler neck and spring shackles.
    Here is a question for anybody familiar with these cars: the original rockers have 3 captured nuts along the lower edge. One is visible near the joint on the new rocker. Anybody know what is screwed to the lower edge of the rockers?
  21. jakespeed63
    jakespeed63
    The Ford Boys are smiling down upon you, from Heaven. ;)
  22. swissmike
    swissmike
    I prefer replacement sheet metal to smiles...cheap *******s!
  23. Nads
    Nads
    from Hypocrisy
    good job, young Mike, you are killing it.
  24. swissmike
    swissmike
    Back to work on the floor. The old floor is cut off leaving just a half inch flange. Mating the two pieces made earlier.
    Measuring, marking and cutting for a lap joint.
    Here is a little trick i used to transfer hole location to the panel. The space did not allow for drilling from the underside. Even with a 90 degree attachment.
    The center punch is held in a piece of 2x4". Now just hit on top with a hammer and a piece of wood. The small dimple clearly marks the exact location.
    chryslerfan55, junkjunky and 36 ROKIT like this.
  25. swissmike
    swissmike
    Here is one seat mount location. A 16 ga rectangle is spot welded to the underside. I decided to cut and reeled the perimeter to get the flat parallel to the ground like on the original. However, I woudnt do this again as the seat mounts are only about 2" wide sideways and don't really care about the tiny amount of wedge.
    Perimeter cut. A larger steel plate is placed under the entire area and the edges hammered down flat, then welded up.
    Dug out the seat for a trial fit. The welding on the panel of the seat mounts introduced a lot of warpage into the panel, which I couldn't completed get rid of by shrinking along the edge (see far side of floor does not fit edge of rocker. I will have to pie cut and weld a straight reinforcement piece to the underside.
  26. swissmike
    swissmike
    After welding all the small holes used for locating the lower die, I mounted the floor and located and drilled the remaining holes. Some holes are recessed and I made a forming die from aluminum s**** which worked surprisingly well.
    Test fit of the rockers...
    Still need to trim the outside edge slightly. I want about 1/8" to 1/4" clearance on the inside of the rockers. The rockers will be welded into the body shell first, then the floor is installed and spot welded to the rockers after the trunk floor and seat riser are welded in place as well. But that's still a long time off.
    Nobody makes a body mount kit for Mercs, but most of the shims can be cut from flat rubber mat. One of the rear spring shackles is missing, putting the entire ch***is into a slight twist. Got to fix that before fabricating the shims. I hope 40 Ford uses the same round rubber bumpers for the floor mounting bolts to eliminate any direct metal to metal contact.
  27. DirtyNapkin
    DirtyNapkin
    from Napa, Ca
  28. Finnrodder
    Finnrodder
    from Finland
    Wow,looks really great!
  29. bengeltiger
    bengeltiger
    You could try pre-stretching the metal to be formed if you have to attempt this again. That should also help the surrounding metal remain flat. Just my $.02. Love the work you're doing and appreciate the effort you go to sharing/do***enting your build.
  30. kopperkart
    kopperkart
    from Wisconsin
    You make it look easy, but it isn't.
