looking for pics or ideas on where to run the front brake lines to the rubber hoses on hyd brakes. I'm running into my drag link when placing them on the bottom of the ch***is. I tried through the frame mounts but couldn't find fitting for the an3 to old ford thread on the rubber hose. Any body put the line on the top of the frame? Help is appreciated
Cut the AN fitting off and drilled and tapped the hole for 1/8 NPT and installed the inverted flare fitting that worked with the rubber hose I am using. D
