Technical Louvered batterybox from scratch - techweek
Discussion in 'The Hokey Ass Message Board' started by Finnrodder, Oct 3, 2015.
  1. Finnrodder
    Finnrodder
    from Finland
    I was thinking what kind of batterybox or tray to use with my shoebox build.The oem battery trays leave battery exposed and autopart stores sells mostly a plastic ****,so i decided to make my own.
    Here is the start,cut some sheetmetal and marked it:
    The box needed few dimples,so i made this dimple tool with lathe.I used a hydraulic press to make the dimples with these dies:
    The next phase was to roll some beads with beadroller and make dimples:
    Then i used metal brake and after that made testfitting to Fords inner fender:
    It needed some bracing,so the battery's weight didnt twist it:
    And again some testfitting with a junk battery i had.I made a temporary battery hold down bar too:
  2. spooler41
    spooler41
    Where are the louvers? I can't see them anywhere.
    ..................... Jack
  3. Finnrodder
    Finnrodder
    from Finland
    And now the louver part.I do not own a louver press,i've heard that some guys punch them in here Finland,but i dont have a clue who does them.I noticed that a fellow hamber marioD from Germany punches them.I know that people from Germany have a good quality in their products and their scheduling works like a clock,so i hired him to punch some louvers for me.I got a package from Germany,just what i was looking for.Thanks Mario!
    Then i had to some work with the sheetmetal brake again:
    I made dimples on the box lid too and welded the corners:
    After that was time to mount the louvered skin on the box frame with clecos:
    And the welding is done
    I made holes for the cables and wires,the grommits are there too:
    This is the battery hold down bar,the studs are for the lid:
  4. Finnrodder
    Finnrodder
    from Finland
    Then some testfitting with the inner fender again:
    The ****py battery is there too:
    Then i took a pile of parts for the powder coater,including the box:
    Here is the finished box
    Rich B., the man, 55willys and 3 others like this.
  5. HOTRODPRIMER
    HOTRODPRIMER
  6. Nice way to hide a nasty battery !
  7. donno
    donno
    Super nice job!!
  8. scrap metal 48
    scrap metal 48
  9. LWEL9226
    LWEL9226
    from So. Oregon
    Good looking box .......
    Lynn W
  10. Dean Lowe
    Dean Lowe
  11. Put an acorn nut on top of the exposed hold down studs....I have a 6 inch scar on my arm from one......
  12. Finnrodder
    Finnrodder
    from Finland
    Thank you all!
    Yeah,those studs are long,but i used what i have in my stash.Plan is to get shorter studs,or cut those shorter before i cut myself...
    Its just not easy to find non metric studs in here from hardware stores.I always use unf's/unc's when i build my Harley or US made cars.
    It could be easier to surrender and get the damn metric bolts and nuts from the local hardware store.
    I guess some people call it stupidity,but i call it obsession:D
  13. 55willys
    55willys
    Nice and it is ventilated so there will be less corrosion.
  14. Finnrodder
    Finnrodder
    from Finland
    Yeah,thats the idea.I drilled few drainholes too on the bottom beads
  15. marioD
    marioD
    Excellent turnout!
    Was a pleasure to punch for you :)
  16. Finnrodder
    Finnrodder
    from Finland
    Thanks!
    I'll contact you,if i need louvers in the future
  17. FOURTYDLX
    FOURTYDLX
    VERY NICE
    seb fontana likes this.
  18. Finnrodder
    Finnrodder
    from Finland
    Just remembered that i had a bunch of acorn nuts,which i bought when i was building my bike.
    So,just for ****s & giggles,i changed the studs to shorter ones and put the acorn nuts on the top:
    I think it looks better(and a bit safer too) with the acorn nuts,but its not so practical than its with the wingnuts..
    Well,i guess i can live with that.Thanks for the suggestion!
