T5 into 40 ford
Discussion in 'The Hokey Ass Message Board' started by johnale, Oct 4, 2013.
  1. johnale
    johnale
    from Melbourne
    I'm looking at putting a chevy s10 t5 behind my flathead in my 40 ford. I'm converting to open drive.
    My question is has anybody done this keeping the rear stock radius rods and used a torque arm, or should I look at a ladder bar system for it?
    Any advice would be great!
    Thanks
    John
  2. Texas Webb
    Texas Webb
    Just me,but radius rods and torque arm
  3. johnale
    johnale
    from Melbourne
    That's the way I'd like to go, just want to make sure the stock 40 radius rods will cope!
    This will save me a fair bit of cash as well.
  4. brokenspoke
    brokenspoke
    Checkout T-5 Tech in a search......crazydaddyo makes agreat adapter for the t-5 and keeping torque tube
  5. johnale
    johnale
    from Melbourne
    I was going to go that way, but ive gone a 2 x 4 transmission where his adaptor needs a 4 x 4 transmission
  6. brokenspoke
    brokenspoke
    In would use a ladder bar system like P and J's
  7. 36 ROKIT
    36 ROKIT
    Apply the k.i.s.s. principle here; the stock Ford radius rods have been used for eons
    behind flatheads. However, you will be worrying more about snapping axles, than
    bending the rods if you have a heavy foot!
  8. 36tbird
    36tbird
    Might do a search about the rear radius rods. I think I saw a recent thread where some broke.
    Also, over on the FordBarn there has been some discussion about using t-170 trans. and that there is an adapter offered where some have kept the closed drive shafts. That trans is from mid-80's F-150's and is a 3 spd with OD. I think that it is an interesting option.
  9. check out bob drake reproductions article on google ***led roadster 36, has your answers, its a great build, let me know truckrick
  10. krylon32
    krylon32
    from Nebraska
    Also check out Hot Rod Works In Idaho They wrote the book on your open drive rear end conversion
  11. Tim G
    Tim G
    Hi, is that article on here or do you mean on the Bob Drake website?
    Thanks
