Hot Rods Let's see your homemade speed equipment
Discussion in 'The Hokey Ass Message Board' started by Robert J. Palmer, Nov 26, 2014.
  1. RichFox
    RichFox
    And here is the 32 plymouth showing another intake i made using 4.6 Ford throttle bodies. Also the home made twin plug head, finned side cover, and duel distributor drive.
    Austin kays and Robert J. Palmer like this.
  2. Very nice, what is your best speed?
  3. RichFox
    RichFox
    The flathead Plymouth banger went 113.7 both with Suzuki and Ford throttle bodies.At El Mirage and Bonneville both. I guess 113 was it's number. With the Y block head it went 135
    Robert J. Palmer and Jet96 like this.
  4. RichFox
    RichFox
    This baby bug catcher that I made from the bottom half of a Nissan Maxama 3 liter V6 SOHC EFI intake. Again I used Hilborn parts It went 231 in F/FS in 2000.
    vtx1800 and Jet96 like this.
  5. RichFox
    RichFox
    Going around to the other side. I didn't make the crank, but I did make the main caps. Also you can kinda see the finned side cover I made on the 26 Dodge
  6. DDDenny
    Speed feed for my roadster.
    brEad, ekimneirbo, Lil'Alb and 7 others like this.
  7. ago
    ago
    from pgh. pa.
    Like it!
    jebbesen likes this.
  8. Nice work!
  9. TBone69
    TBone69
    from NJ
    Here's some home made speed parts for a Model A, ignore the old sneaker in the lower right corner.
    Intake that was converted from updraft to down draft and this cool header designed for an OHV
    conversion made out of some heavy piping.
    The header is just a wall hanger for now, but plan on running the intake and splitting two exhaust manifolds to run dual exhaust.
    Lil'Alb and patmanta like this.
  10. Very cool, for The Race of Gentlemen?
    You are from N.J.
  11. TBone69
    TBone69
    from NJ
    That is the plan. Been a spectator for all of them so far.
  12. This is a split exhaust manifold for a 216 by Joe Alexander picked it up with a Edelbrock 216 intake-
    Deuces, 46fatford and 6-bangertim like this.
  13. joelorocknrollo
    joelorocknrollo
    11695909_10153559324280676_8019447617791421092_n.jpg Header and intake combo on my banger. It sounds great and looks good at night. What else do you need! 20150403_130510.jpg 20150406_162847.jpg 20150616_142126.jpg 20150628_140719.jpg
    brEad, Deuces, mcnally351 and 4 others like this.
  14. Very nice @joelorocknrollo .
    This is a homemade quick change and in-out box in a homemade big car owned by **** and Jeff Ackerman
  15. joelorocknrollo
    joelorocknrollo
    I need that recipe. Do you have build photos? That is so great, I was talking with a friend when we were at the dirt drags at Chopped last weekend and to be able to change out the diff gears would be unreal. We don't have the coin for a quick change but do have a metal shop.
  16. patmanta
    patmanta
    from Woburn, MA
    I missed out on a homemade quick change on ePay a few years ago and haven't seen one come up for sale since. I'm still kicking myself because it did not go for big money.
  17. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Patmanta,
    Send me big money and I'll build you one. :)
    patmanta likes this.
  18. rtsidejohnny
    rtsidejohnny
  19. RichFox
    RichFox
    DSCN8335.JPG Here is a picture of a somewhat similar set up I did. The intake is attached to flathed screws attached from the other side of the header flange. before I put the flange on the block. I made three different intakes and wanted to be able to change them without pulling the exhaust. I know that I already posted a picture of this engine. This is to show how I attached the intake. Close but not the same as above. No I did not experience leakage problems. But this is a lot different than a street driven car.
  20. I do not have a photo, I will check with the Ackermans.
    The car is a barn find built just after the war.
  21. joelorocknrollo
    joelorocknrollo
    The exhaust and intake are on the same manifold plate and there are no sealing issues. The carbs are Bendix Strombergs from EJ Holdens from '63. I run a single Bendix carb and a quiet exhaust on the street and the performance enhancement when the header manifold combo is bolted on is dramatic. Next project is to make similar intake manifold and extractors, but might use some 94's instead.
  22. rtsidejohnny
    rtsidejohnny
    Thanks joelorocknrollo! Great looking and I'm pleased it performs well. I'm building a banger rpu right now and I may have to 'borrow' the look!!
    Johnny
  23. joelorocknrollo
    joelorocknrollo
    Tripple '81 manifold work in progress. Run one, two or all three! IMG_0360.JPG IMG_0361.JPG IMG_0362.JPG
    neilswheels, brEad, Deuces and 5 others like this.
  24. joelorocknrollo
    joelorocknrollo
    It is starting to take shape. But need to find another good '94 or rebuild all the '81s. IMG_0370.JPG IMG_0372.JPG IMG_0373.JPG
    brEad, Deuces, jaxx and 5 others like this.
  25. joelorocknrollo
    joelorocknrollo
    New exhaust. Damn right hand drive cars don't leave much room for headers. The front pipe is to avoid the oil filter on the aftermarket alloy side plate which is on the motor i'm about to put in. IMG_0397.JPG IMG_0395.JPG IMG_0396.JPG
    brEad, Deuces, 46fatford and 6 others like this.
  26. ago
    ago
    from pgh. pa.
  27. nickleone
    nickleone
  28. topfuel55
    topfuel55
    from Hebron IN
    ImageUploadedByH.A.M.B.1462850112.374179.jpg ImageUploadedByH.A.M.B.1462850143.716387.jpg ImageUploadedByH.A.M.B.1462850162.085592.jpg
    I love all the home built intakes! Here's mine the Dan-O-Ram twin 2gcs, top fill water neck. The distributer has a direct read advance indicator( the Ping-O-Matic) all going on a '62 283.
    natrlgas49, Deuces, 46fatford and 9 others like this.
  29. Max Gearhead
    Max Gearhead
    from Wisconsin
