Technical T-10 Help
Discussion in 'The Hokey Ass Message Board' started by bolsa boy, Oct 10, 2015.
  1. bolsa boy
    bolsa boy
    I picked up a T-10 at a yard sale. Guy didn't know anything about it. It was in the garage when he bought his place. So now I'm looking for help to ID this thing.
    This is what I found on it.
    Case has T10D-1 cast on it. The flange has WL2923 stamped on it.
    Tail stock has WG.Div. R1 cast, T10-7D, and 11/27/68.
    Input shaft has one ring.
    If anyone knows what all this means It be a great help. Did some on line research. But came out more confused then when I started. Appreciate any help.
  2. uncle buck
    uncle buck
    How about posting some pictures ?
  3. It could be out of a GM, AMC, or Ford (Mopar didn't use the T-10 much if at all), but by '68 it probably isn't a Ford application as Ford had pretty much switched to nothing but their own toploaders by then. Pics are really what's needed....
  4. DDDenny
    Last Chevy production issue T10 was 1963, Pontiac used them thru 64 IIRC.
    The Super T10 was issued as a replacement for the Muncie M22 about 73-74 until the early eighties.
    When I was in high school around 1971, I bought a T10 (GM case) for my 57 BelAir, from a local trans shop that had built it for a drag racer but never picked it up.
    What was special about this trans was it had been fitted with a Ford input shaft that was made of a high nickel content, dont recall the tooth count, but it required that I use a Ford clutch disc.
    This was my first real experience with parts swapping between brands.
    special-k likes this.
  5. bolsa boy
    bolsa boy
    20151010_085935.jpg This is it. I think you can see all the casting numbers here. I know it's a chevy because of the bell housing. And it is a aluminum housing which i understand to be a Super T10. But is there any way of knowing what year it is and what the gear ratios are?
  6. Mr48chev
  7. a super has an extra bump at bottom of trans towards tail, that looks like a regular t-10
  8. falcongeorge
    falcongeorge
    from BC
    When I was IDing mine, I found some really good stuff on codes on a transmission parts vendors site, but I cant find it now...:rolleyes:
  9. Could that date be a 63 instead of 68?
  10. badshifter
    badshifter
    Show us the other side. The bell housing has nothing to do with trans type, pretty much any GM bell housing will bolt to any GM trans of that era.
  11. DDDenny
    That's what I was thinking also.
    Thought maybe 68/69 AMC tailhousing, but not same as GM casting in photo.
  12. cavman
    cavman
    [​IMG] More than likely for a 1963 build. No cast Chevy emblem on the t-housing. Could be Buick, Pont, Olds, or? Date code indicates Dec, '62
  13. badshifter
    badshifter
    I think it's a T10, And single groove is wide ratio, and your case is not matched to the tail shaft as far as part numbers go. Seems like its a 63 corvette based on the T10D1. There were no 1968 T10s.
  14. Could be a service replacement, not necessarily a OEM install... I will agree that it isn't a ST-10, but the older 'standard' T-10.
  15. cavman
    cavman
    th (7).jpg This is what won't show in my previous post. I don't know why it can't be enlarged. oh well
  16. bolsa boy
    bolsa boy
    20151010_090009.jpeg Here's the other side. I looked really close and it's a 68. But it could be a tail stock from a later unit. Again just trying to get as much info as I can. Thanks for the help.
  17. bolsa boy
    bolsa boy
    20151010_152319.jpg Here it is without the shifter & linkage. After looking at it this way it seems that it is a late 62. I also noticed another number stamped on to the flange next to the date code. A142164. If that helps. So i think i have the year or at least close enough to get parts for it if necessary. Badshifter you say its a wide ratio because of the single grove. Where can I find what the ratios are? So I can match a rear end to it.
    Again Thanks guys.
  18. stillrunners
    stillrunners
    from dallas
    what's the # on the bell housing...?.....most likely the car it came out of.....show a pic.....
  19. inliner2318
    inliner2318
    from Tyler, TX
    Anything good about a 1961 Pontiac T10?
    A guy locally has one for sale...
  20. Nothing special other than the numbers for someone who cares about that stuff.
  21. krgdowdall
    krgdowdall
    from Alberta
    T10 was also used in the Studebaker Lark, Hawk and Avanti ,1959 to 65
    Same housing as a GM unit.
  22. 48jeep
    48jeep
    I believe there is a difference between the input shafts on the Stude versus Chevy T-10's. I sold a 1963 Stude T-10 to a guy years ago that needed one for his 61 Corvette and he had to change the input shaft.
  23. DDDenny
    See post #4.
