Technical Who makes this rim ?
Discussion in 'Traditional Hot Rods' started by DMcNulty1, Oct 10, 2015.
  1. DMcNulty1
    DMcNulty1
    hi it's a 16 5 on 5 1/2 bolt pattern just don't know much about them
  2. harleymark
    harleymark
    from Kelso, WA
    My guess is an early Jeep. They had the big hole in the middle w/five bolt holes and no provision for hub caps. Just a guess though.
    DMcNulty1 likes this.
  3. verde742
    verde742
    could be a farm implement, want more?
  4. DMcNulty1
    DMcNulty1
    Tires say 6.50 x 16 inch rim
  5. big duece
    big duece
    from kansas
    2nd on the jeep idea
  6. llonning
    llonning
  7. DMcNulty1
    DMcNulty1
    Thank you everyone ! Wish I know the years
  8. 117harv
    117harv
  9. DMcNulty1
    DMcNulty1
  10. Is the center welded in or riveted?
  11. It ain't a rim, it's a wheel
    lothiandon1940 likes this.
  12. DMcNulty1
    DMcNulty1
    Weld on
  13. DMcNulty1
    DMcNulty1
    Weld please look at photo
  14. DMcNulty1
    DMcNulty1
    Found two stamps on it
  15. DMcNulty1
    DMcNulty1
    Bump still looking for answers can't find much about them
  16. Hollywood-East
    Hollywood-East
    Definitely early jeep...
  17. k9racer
    k9racer
    I am not sure but I think it might be a jeep. Maybe someone else might add a line of what it might be.Or could it be 4 wheel drive bronco?? Intenational harverster ?? Russian or maybe german field car with 1/2 track perhaps or Maybe a JEEP. Or maybe a land rover. maybe a 1955 XK 120 jaguar.. Last a dana 44 axel.
  18. spooler41
    spooler41
    Most early wheels were not welded (before the 1950's) they were riveted.
    I can remember making reversed wheels for my '55 Buick by drilling out
    the rivets , flipping the center piece and using several taper punches to
    align the center before welding them back together .The first thing I learned
    was to drill a new stem hole in the new front side of the wheel, before
    mounting the tires rather than after.
    .............................. Jack
    volvobrynk and lothiandon1940 like this.
  19. 4444Design
    4444Design
    i restored 3 willys-jeeps of different making years - for me rim is definately willys Jeep postwar production - started on the first civilian model CJ2a and was used on all willys 4x4models throughout the 70ies (not sure about end of production of the rims)
  20. Dapostman
    Dapostman
    A five hole 5.5” bolt pattern with a 4.125 center hole will fit a jeep and an International truck with 4WD it also fits the older Postal jeeps but they used a 15” tire.
    Hollywood-East likes this.
  21. Blue One
    Blue One
    from Alberta
    The rim was probably made by the same company that put the center section into it and made it into a WHEEL. :D
  22. stimpy
    stimpy
    if you cannot find the date code on the outside , it will be stamped on the inside of the rim under the tire .
  23. Hollywood-East
    Hollywood-East
    I Own over half a dozen Willys jeeps, as stated, international/Jeep, the early ones had clips on the inside for center cap(CJ's) I have these wheels all over the place...
  24. 3wLarry
    3wLarry
    from Owasso, Ok
    word
  25. lothiandon1940
    lothiandon1940
    Me thinks he's been hangin' with that "donk" crowd.
  26. HOTRODPRIMER
    HOTRODPRIMER
    Here in the South they are called wheels & rims.' It kinda depends on which part of the State your in. HRP
  27. hotrod1948
    hotrod1948
    from Milton, WI
    Rims - wheels, every one knew what the OP was asking, even included a picture. What would we do without the word/grammer police?
  28. Continue to say it wrong? :rolleyes:
    Around here the dubs crowd calls them wheelrins. Every time I see an '84 Cutl*** with 22+ inches of wheel and rubber band tires I jump up and holler, "Circle the wagons!!!!!"
    The wheels look like Ford truck wheels to me by the way.
  29. 38Chevy454
    38Chevy454
    I am late tot he party, but with the large center hole, those are likely Jeep wheels as stated by several before me. The large center hole is required for the hub size on the 4x4 axles.
