Technical Dipping Master cylinder to remove internal surface rust
Discussion in 'The Hokey Ass Message Board' started by belair_54, Oct 14, 2015.
  1. belair_54
    belair_54
    from australia
    Hi everyone re-building my master cylinder from a 1946 Chevrolet truck its all cast iron the bore is in good condition and I will give it a quick hone. the problem is the inside of the reservoir it has quite a lot of surface rust. Does anybody know of a cheap home dipping chemical I can make up to dip my master cylinder in? Does vinegar work ? Any help appreciated
  2. jcmarz
    jcmarz
    from Chino, Ca
    I just rebuilt the MC for my AD truck. It also had surface rust inside, as well as outside. I soaked in Apple Cider vinegar for a week and half and it cleaned it really nice.
  3. rfraze
    rfraze
    I think it's white vinegar.
    Save the apple cider vinegar for heart burn. Now there's a tech tip for ya.
    Hnstray, snowroutes and Atwater Mike like this.
  4. jcmarz
    jcmarz
    from Chino, Ca
    I've done and used it. Vinegar is Vinegar. Are you lacking common sense?
  5. Grahamsc
    Grahamsc
    from Colorado
    You can use a much more aggresive acid than vinegar , the exposure time and temperature of the acid is the key.
    Then neutralise in soda ash ( or baking soda).
    We do this all the time ,as I rebuild Hydraulic pumps and valves for a living.
    We have a 100 gal acid tank.
    We never leave cast iron in for more than 30 min and that would be a heavily rusted piece .
    muratic acid can be bought at the hardware for $10 to $15 per galon,it may not cut as fast as our industrial chemical but would have to be 10 times faster than vinegar especialy if put in the sun on a warm day.
    After the acid dip ,rinse with water then a short dip in baking soda solution, rinse with water again, blow it dry with compressed air then spray it down with WD40 and leave it set for a couple of hours then wash with solvent.
    The WD40 keeps it from flash rusting and seems to neutralise any leftover acid in the pores of the cast.
    By trial and error , this is how we get the best results.
    302GMC and kidcampbell71 like this.
  6. tubman
    tubman
    One word - Evaporust. It is probably the only product that I have ever used that did what it said it would. Yesterday I removed an old Ford flywheel from soaking for 2 days. All the rust was gone! Also, unlike vinegar, zero chance of damage to the subject part.
  7. Grahamsc
    Grahamsc
    from Colorado
    Our chemical is Acid Magic by Certol international.
    The lable reads ( same as full strength muratic with 90% less fumes)
    This was a 2 min soak
    We use it for control bodys with spool valves as small as 1/4 inch
  8. Da Tinman
    Da Tinman
    Vinegar works great, will not damage cast iron and when your finished it can be dumped in the yard or down the sink. If you spill it or get some on you it wont burn you or eat your floor.
    Soak it, wire brush it, soak again, rinse, WD40 and re***emble.
  9. 302GMC
    302GMC
    from Idaho
    I've been gl*** beading mine for 40 years .. may change technique after reading this one.
    Thanks !!!
  10. Mol***es and water.
    Atwater Mike likes this.
  11. Bruce Lancaster
    Bruce Lancaster
    Evaporust will do the job without worry about acid pitting. You can leave the thing in ER for a month and it will not go beyond the rust.
  12. rfraze
    rfraze
    I don't think so. I'm just trying to p*** along info, like you. I am not saying that apple cider vinegar won't work or that you didn't done do it.
    What I am saying is that if you take a look anywhere that shows how to clean with vinegar, white vinegar is specified.
    On the other hand, white vinegar is not used for acid stomach.
    brokenspoke likes this.
  13. Da Tinman
    Da Tinman
    I use white vinegar full strength, mol***es will do it but it will take a week or 2 whereas vinegar will do it in less than an hour unless its really screwed up.
  14. Atwater Mike
    Atwater Mike
    Also, there are grades of white vinegar on your Wal Mart shelf:
    1. White vinegar
    2. White CLEANING vinegar (Heinz label)
    Apple Cider vinegar is less caustic, aids digestion...(acid stomach)
    rfraze likes this.
  15. David Gersic
    David Gersic
    from DeKalb, IL
    If you're using muriatic, do it outside, not in your shop. The fumes from muriatic acid will cause any open steel to surface rust.
    302GMC likes this.
  16. Grahamsc
    Grahamsc
    from Colorado
    This is true, as our 100 gal tank is outside of the building.
    For most hobby type situations I would imagine a small tub and a gallon or less of mutatic, which would be easy to do outside.
    Temperature makes an incredible difference though.
    What will take 5 min at 30deg will take one min at 90
  17. jcmarz
    jcmarz
    from Chino, Ca
    All, I know is that it works for me and the proof is in the pudding and talk is cheap. Makes no difference to me what type of vinegar you want to use, but I am happy with Apple Cider.
  18. timwhit
    timwhit
    I've used concentrated lemon juice on sheet metal and it worked very well. Shared this with a friend and he used it to clean a '32 door lock ***embly....worked real well.
  19. lewk
    lewk
    from Mt
    Holy vinegar fight! I like the white vinegar from Costco 'cause it's cheap.
  20. Depends on mixture concentration. A stronger mixture with mol***es will speed up the process. Still will take a few days though. And make sure you don't forget it, cuz it'll be a pile of rust at the bottom of the tank!.
  21. belair_54
    belair_54
    from australia
    Thanks for all the replys will get some white vinegar and see what it does.
  22. tubman
    tubman
    If you really feel that you must use acid to derust it, think about masking the bore to protect it. Don't hone until you are done getting rid of the rust. No sense taking chances with your brakes, especially with a single master cylinder.
