Technical TECH WEEK: How I made a model A hood top and stretched the sides
Discussion in 'The Hokey Ass Message Board' started by HarborKustomSpeedShop, Oct 12, 2015.
  1. Here is my tech week entry on how I made a 2 piece model A hood top and stretched the hood sides. I needed to lengthen the hood 5" to get the grille shell out in front of the axle like on the Rolling Bones cars and Doane Spencer roadster. I used two hoods for the lower side hinges and belt line.
    I started with the hood sides first, I cut the first louver off the rear hood portion and then cut after the sixth louver on the new front section of the hood sides to get the needed extra length needed. Tack and then weld together. Grind, hammer and dollie flat.
    For the center hinge, I got some 1/2" tubing and drilled it out to just over 3/8" ID. Then I cut the necessary amount of hinges needed, I needed 11 at 3" and 2 at 1/2".
    Next I cut just above the belt line on the two hoods and remove the needed pieces. Then I slip rolled and cut the hood tops from sheet metal. Cut extra off to fit up to the center hinge and tacked to the corresponding hinges. then I marked and cut extra off the bottom, cleeco'd together and checked for proper operation, (repeat for both half's)
    Once I was happy with the operation I tacked and welded just above the belt line, hammer and dollied to a metal finish.
    For my application I had to take a pie shaped piece out of the bottom of the hood side to match the grille shell.
    I wanted louvers in the hood top but I wanted something different, so I came up with a set of 5 staggered louver that I cut and shortened from the spare hood side.
    Next I marked out and cut the large hole in the new top for the louvers. Tacked and fully welded them in place, hammer and dollied flat to a metal finish. At this stage is were I also fully welded the center hinge, be careful as I had to re drill the tubing as it shrunk during welding, then metal finished center hinge.
    Once all done, this is what I had.
    Justin
    wdglide, bct, AHotRod and 16 others like this.
  2. falcongeorge
    falcongeorge
    from BC
    Now THATS pretty trick!
    volvobrynk and laidout53 like this.
  3. T Hudson
    T Hudson
    Awesome work
    laidout53 likes this.
  4. Crusty Nut
    Crusty Nut
    great idea! Even better execution!
  5. Deadbird
    Deadbird
    Dang! That's nice.
  6. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    Man, you made that look like you've done that before. Great job.
  7. pigfluxer
    pigfluxer
    Well done.
  8. jimz31
    jimz31
    from PA
    Great job!!
    That is awesome!
  9. Yep!!!
    There's awesome talent and creativity on the Hamb
  10. 117harv
    117harv
    Very nicely done!
  11. dodge35
    dodge35
    from kentucky
    That is absolutely beautiful, you do great work!
  12. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I'd vote for you, and I have my own Tech Week thread!
    I wonder if Chip ever made louvers that way?
  13. hipster
    hipster
    Very nice!
  14. Wow thanks for the kind words! they really means a lot!
  15. Bugguts
    Bugguts
    Wow! that looks so cool. Your craftsmanship is excellent. Thanks for sharing .
  16. Sancho
    Sancho
    Excellent job! The louvers on the hood top are the perfect detail.
  17. Rich B.
    Rich B.
    from Portage,IN
    What a great look, perfect height on the grill shell makes for a
    great at***ude!
    Rich
  18. Dave Rondou
    Dave Rondou
    Really nice work. I need to have the same thing done to my hood. Thanks for the motivation
  19. thanks guys, glad I could motivate you Dave!
  20. IowaMercMan
    IowaMercMan
    Nice. Wish I had seen this sooner
  21. Stevie Nash
    Stevie Nash
    Like that you added louvers on the hood sides! Most just add flat sheet metal....
  22. Dino 64
    Dino 64
    from Virginia
    Great job, was wondering how an extended hood would look on my coupe. Thanks for the post and you are very talented indeed !! How much of a chop did you do ?
  23. AHotRod
    AHotRod
    AWESOME job !
    Thanks for sharing your project.
  24. Thank you sir, It's almost 5 3/4". I started with 5" but was set on 6". Decided to ask my friends if i should go 6" and everyone said no, so i went 5 3/4" haha
    thank you
  25. Bam.inc
    Bam.inc
    from KS
    Perfect Proportions. I hope to build a stretched Hood similar to your idea too (someday).
  26. rusty rocket
    rusty rocket
    Thats damn nice. Killer stance mang!!!!!!
  27. Great idea and well executed!
