1963 Ford Fairlane 500 260 V8 Auto 4 door Runs and Drives Clean ***le New: -Battery -Battery Terminals -Voltage Regulator -Starter Solenoid -Rebuilt Generator Done in the last 2 years: -Disc Brake Swap (Front) - CSRP (discbrakeswap.com) Swap 1 Kit The kit includes everything needed to swap out your front drum brakes for OE Kelsey-Hayes type 4 piston caliper front disc brakes originally found on 1965-1967 V8 Mustang and other 60's Ford cars. All new easy to install parts including dust shields, caliper brackets, corrosion protected calipers, brake pads, braided stainless steel brake hoses, hose brackets and attachment hardware, adjustable proportioning valve with convenient mounting bracket, a master cylinder with an integral residual pressure valve, master cylinder outlet adapter(s), an all metal master cylinder bleeding kit, an adjustable pushrod, wheel bearings, wheel seals, caliper attachment hardware, wheel attachment hardware, dust caps, performance slotted rotors with bearing races pre-installed, correct grade 8 attachment bolts, medium and high strength thread lockers, and high temperature wheel bearing grease. Note that you will need to adapt or re-fab your hard brake lines to accommodate the proportioning valve and the master cylinder. -Added/Installed front seat belts -Added/installed Windshield washer pump/kit The body is in pretty good shape with no significant rust through issues. Some minor rust around wheel wells, rockers, and fenders. Rear wheel wells need the most work. Minor damage to front bumper and driver's side headlight area. Driver's side high beam headlamp is gone. All other lights work. All the gl*** is fine. Some of the seals/windlace could stand to be replaced. Aftermarket dual exhaust. Trunk interior has a few small rust spots but has been s****ed/primed/painted. Interior is alright. Seats could stand to be redone. Aftermarket cover on front seat. Front doors/rear package tray cut for speakers (not included). Could be replaced easily. Dash cut for modern stereo (not included). Headliner is gone. Heat works. All windows roll up/down. gas gauge does not work. Speedometer needs adjustment. My son drove this to school/work for the last few years until he moved off to college last fall. This car makes for a pretty nice cruiser and we always got a lot of compliments on it.
