Technical ignition condenser problems
Discussion in 'The Hokey Ass Message Board' started by Racer29, Oct 19, 2015.
  1. Racer29
    Racer29
    What are some reasons an ignition condenser fails often?
  2. onthefritz
    onthefritz
    Do you have a ballast resistor or a resistor wire in your system? Loose or corroded condenser mounting strap or wires. Could also be a poorly made condenser from China. What are your symptoms?
    deathrowdave and dana barlow like this.
  3. themoose
    themoose
    dana barlow likes this.
  4. Racer29
    Racer29
    I do have a ballast resistor. It will start running real rough all of a sudden sometimes backfires and sometimes just dies. Then I put a new condenser on and it runs fine. A few weeks ago I had driven nearly a hundred miles no problems came back the next morning car wouldn't even start. New condenser, car starts and runs good again. Today starts up runs fine for a couple of miles and then starts running rough again I haven't put a new condenser on yet.
  5. Grahamsc
    Grahamsc
    from Colorado
    sounds like a coil breaking down.
    Maybe the new condensers are acting as a bandaid
    flatout51 likes this.
  6. gary terhaar
    gary terhaar
    from oakdale ny
    Quite possible graham, I have been plagued by condenser failures from off shore parts more than once. If the condenser is old but proven I never change it,and I keep a proven spare now as well.
  7. MengesTwinCustoms
    MengesTwinCustoms
    You can mount it off the coil instead of inside the distributor, perhaps it is getting hot and failing like the model As did. Just have a good ground!
  8. Rusty O'Toole
    Rusty O'Toole
    Old wax paper condensers wear out sitting on the shelf. If it is NOS and more than 20 years old it is on borrowed time.
  9. Truck64
    Truck64
    from Ioway
    Test them at 250+ volts (keep one hand in back pocket) if it p***es, should be OK. Those old wax caps had paper dialectric, the auto condensers should be a little better made I think.
  10. Check the polarity of your coil ( negative should go to your points in a neg. earth system). I know this can shorten the life of your points, may also cause capacitor failure.
  11. Racer29
    Racer29
    Thanks for the tips. I know this sounds like a simple problem but it's driving me crazy. I did get new condenser that was bad right out of the box. This just started happening in the last couple of months so something has gone wrong somewhere.
  12. pecker head
    pecker head
    I have a 61 283 with stock distributor, it has ate 3 condensers in a 1000 miles.
  13. pecker head
    pecker head
    How do you do this?? I’d sure like to try this , would be a lot easier to replace also.
  14. Mimilan
    Mimilan
    We had the same issue with the rebuilt engine in my 57.
    I had 3 failures in a row....straight out of the box.
    We rescued the old one from the trash and it has been there ever since.
    They are poorly made, and of limited demand nowadays
    pecker head and Desoto291Hemi like this.
  15. I think recently there was a post about the new condensers .
    Someone had several failures of the new ones,,,,so they opened one up .
    It turned out the wire was not soldered inside like the old ones,,,,it was only crimped on .
    So they were experiencing bad connectivity with the new ones internally.
    Sounds about right to me .
    Tommy
    ottoman, Mimilan and tubman like this.
  16. captaintaytay
    captaintaytay
    Maybe contact Jim Linder aka "Bubba" I believe he uses or used Napa (Echlin) brand on his distributor builds.
    Desoto291Hemi likes this.
  17. Truckedup
    Truckedup
    condensers, aka capacitors, are all about 21 micro farads,600 volt rating is best. Buy them online at electronics dealers. Usually better quality and can be mounted externally.
    LAROKE and wraymen like this.
  18. jimmy six
    jimmy six
    Many bad mouth them but after 3 condenser failures on my 56 Ford I installed a Pertronix ll following their instructions and coil. I also kept the stock Ballast resistor which is optional but after a call to one of their techs I decided to keep. That was 7 years ago.
    Jim, aka Squirrel, here has given the part # for a capacitor that I believe fits in the distributor.
    warbird1 likes this.
  19. tubman
    tubman
    These have proven to be very reliable. They mount on the outside of the distributor.
    LAROKE, warbird1, egads and 4 others like this.
  20. pprather
    pprather
    For those needing a condenser, contact @tubman above.
  21. G-son
    G-son
    from Sweden
    Sounds very large for an ignition cap, my memory suggests something closer to 0,2 micro farad/200 nano farad. Too tired to research now unfortunately, 4AM just being awake to get the heat out before trying to sleep. Summer hit hard, at 36C in the shade in Sweden.
  22. rusty valley
    rusty valley
    I am no electrics wizard, but I remember from an ignition seminar I attended once the speaker told of looking at the carbon build up on a used set of points. If the pile is all on one side and the other side is a burn hole you are using the wrong condenser. Ideally, the residue would be equal on each side. Hopefully someone here can expand on that
  23. Blues4U
    Blues4U
    from So Cal
    Yeah, the article linked to earlier in this thread says .20 - .22 microfarads. 600 volts.
    Here you go:
    Axial leads - https://www.mouser.com/ProductDetail/Cornell-Dubilier-CDE/940C6P22K-F?qs=zsnhSutGCZWd1UevJM1khQ==
    Radial leads - https://www.mouser.com/ProductDetail/Cornell-Dubilier-CDE/715P22456MD3?qs=mKWJoQeCbqC0Cv58%2BZJ2pg==
  24. TrailerTrashToo
    TrailerTrashToo
    NOTE: Those single strand leads are not going to like the vibration of the engine. The capacitor body will need to be securely fastened to something.
    Russ
    Blues4U likes this.
  25. MeanGene427
    MeanGene427
    from Napa
    In '77, my gf says her gf has an old Ford she wants to sell, runs bad, smokes, bad mileage yadayada will you take a look at it (as she bats her eyes)? OK, have her bring it over. She shows up in a dead straight 63-1/2 Galaxie 500 fastback, pale yellow with perfect black interior, tinted gl***, running terrible and dragging a blue cloud, 390 flags on the fenders. Hmmmm, engines I have.. Well, what do you want for it? She says can you give me $200, I want to buy a little Honda car. Well, OK. First pull plugs, rear on both sides fouled, so pull valve covers, and rear oil drainbacks completely plugged. So now it's running on 8 but still not well, and smoking has gone away. Off with the cap, point are pretty crispy, easy enough, but doesn't look right- there's no condenser- nothing there. Put some fresh points in, and curious, tried to start it- wouldn't start again without the condenser, even though it did with the old points. Put a condenser in it, popped to life and ran soooo sweet. Yeah, should have kept that one
  26. pprather
    pprather
    The car or the gf?
  27. pecker head
    pecker head
    1F1A3EF6-E46C-489D-B06F-1F2A38F9AAFF.jpeg I just moved my condenser out of distributor and on to firewall, will be lots easier to change. Went to Oreileys and bought a lifetime warranty condenser and a year warranty condenser.
    loudbang, jimmy six and dirty old man like this.
  28. Truck64
    Truck64
    from Ioway
    Production tolerances of the components themselves. Lead length will also affect the capacitance. Not necessarily the "wrong" condenser. The capacitor and the coil secondary winding together make a "tuned circuit". The condenser is like a shock absorber for the coil output. Slightly "too much" or "too little" capacitance would tend to cause deposits to build on one side of the point face versus the other.
    Back in the day when twice yearly regular tune-ups were the norm, a lot of mechanics would leave the condenser alone when replacing the points, if the point faces were wearing evenly. Condenser replacement was a bit of a ****shoot back then too. Not like now but a serviceable part like that, there was really no benefit to replacing it just for the heck of it.
    loudbang, wraymen and rusty valley like this.
  29. G-son
    G-son
    from Sweden
    And the environment is likely quite a bit cooler there the life of the condenser may improve quite a bit too.
    pecker head likes this.
  30. 2OLD2FAST
    2OLD2FAST
    from illinois
    IIRC , wasn't there a condenser mounted on the coil as well as inside the distributor on many different vehicles or was the can on the coil something else ?
    Truck64 likes this.
