Projects Major damage 1954 Ford Victoria Crestline Project
Discussion in 'Traditional Customs' started by VonMoldy, Sep 14, 2015.
  1. metalman
    metalman
    Hardtop and convertible doors are the same. I'd sure rather tackle that then a rust bucket, make a great car after it's together. Of course I got a soft spot for 52/54 Ford, particularly a hardtop.
  2. VonMoldy
    VonMoldy
    from UTARRGH!
    Made a bit of progress have had some set backs preventing ,e from working on this heap. Mostly cutting rusty crap out and mocking up new stuff. Kinda like a puzzle just need to figure out the first piece.
    Olson likes this.
  3. Devin
    Devin
    from Napa, CA
    Nice score! These cars are really cool and will look great cleaned up with some tasteful mods. If hate to have been the guy in the driver seat when he hit that post for a variety of reasons. I will be following your progress, keep up the great work!
  4. HOTRODPRIMER
    HOTRODPRIMER
    Keep us up to date. HRP
  5. falcongeorge
    falcongeorge
    from BC
    That's what went though my mind.
  6. VonMoldy
    VonMoldy
    from UTARRGH!
    Find the sum of the following: Ice, Corner, 390 V8, Idiot
    This is from what I remember. But the scenario in my head has the idiot going around a right turn too fast in winter conditions going into major understeer and sliding into a bollard.
  7. falcongeorge
    falcongeorge
    from BC
    I was figuring it must be something like that to hit on the front door post.
  8. Custom_Crestline
    Custom_Crestline
    You scored on those doors. The vent wings alone (those appear to be the early stainless ones) go for stupid money.
    Good luck with your build!
    VonMoldy likes this.
  9. VonMoldy
    VonMoldy
    from UTARRGH!
    hmm might have to check into that I don't need em.
  10. VonMoldy
    VonMoldy
    from UTARRGH!
    Some more progress One of the body braces was a rusted crappily welded back together. So this is about building a new one. rustedbodybrace.jpg
    I made a pattern the usual way using cardstock and matching it up to the good one on the car and compare it to this crappy one.
    Since my brake can't handle 16gauge like it said it could because harbor freight. Some metal beam and a piece of square tubing clamped together did the trick like a treat. Lots of hammering later time for piecing together.
    bending up the top and matching it to the sides. It was a little short because I wanted to use up cut offs. Just weld in a new piece.
    Lazily tacked up the pieces with my new TIG looks crappy cuz I suck and didn't even clean the metal. Yeah probably gonna MIG weld the rest.
  11. VonMoldy
    VonMoldy
    from UTARRGH!
    Realized there was like an inch of lead and screws in the quarter panel and rear of the rocker so I figured it would be good to replace the grot so I have good metal to weld the rocker and floor pan onto.
    One of these days I would like to post a finished project, but I keep finding stuff to fix before fixing other stuff.
    This whole lower door frame/rocker was filled with a mixture of lead and body filler but mostly lead and it was really like an inch thick..
  12. Fedman
    Fedman
    Keep at it, it looks like it is coming around nicely.
    It will be a Very Cool Cruiser when done!
    I am enjoying the build and tech posts,
    Thank you... :)
  13. Watching. Great work, nice save.
  14. steinauge
    steinauge
    from 1960
    Really nice work!
  15. phat rat
    phat rat
    You did good getting 52 doors, they are the only ones that are stainless. Back in the early 90's I bought a complete less motor 52 HT just to get the vent wings because the only other place I found them the guy wanted $400 for a pair
  16. VonMoldy
    VonMoldy
    from UTARRGH!
    well thats pretty crazy. why are the stainless ones better?
  17. phat rat
    phat rat
    Very simple they don't get all pitted like the others.
  18. Finnrodder
    Finnrodder
    from Finland
    And you can easily polish them by yourself,if you need to get them shinier
  19. VonMoldy
    VonMoldy
    from UTARRGH!
    I figured it must be something like that but wasnt certain.
  20. HOTRODPRIMER
    HOTRODPRIMER
    Not trying to be disagreeable but all the '52-'54 Fords all have stainless vent windows. HRP
    Model T1 likes this.
  21. Finnrodder
    Finnrodder
    from Finland
    Thats why i bought a pair of stainless vent window frames for my shoebox project.I have to modify them,because the top is chopped.So i dont have to take them to chrome plating,just buff them shiny again when i am done with them.
  22. VonMoldy
    VonMoldy
    from UTARRGH!
    that would save some cabbage!
    Finnrodder likes this.
  23. VonMoldy
    VonMoldy
    from UTARRGH!
    so are convertible and hardtoo also the same? I have been too lazy to compare. maybe I should take a second and pop some photos for posterity.
  24. HOTRODPRIMER
    HOTRODPRIMER
    Coupes,sedans and wagons,the convertible may be different. HRP
  25. Yes, all models have a stainless frame around the glass, but what Phat Rat was referring to was the frame that bolts to the door and holds the vent window assembly. The '53-54 hardtop/convert frames are chrome plated die-cast, the '52 versions are stainless.
  26. phat rat
    phat rat
    I should have said entire vent wing assembly
  27. epw1949
    epw1949
  28. Devin
    Devin
    from Napa, CA
    Man, you're killing it! Keep it up!
  29. nikesb1111
    nikesb1111
    from MA
    Nice work. Going to be a cool car. Keep it up
  30. Lad_RoadDevils
    Lad_RoadDevils
    Keep up the good work!
    kidcampbell71 and VonMoldy like this.
