I was able to get some real nice pin stripping done this weekend on my truck. Jason Wharton, from Salisbury MD, came to the house and did some killer work. If you are in southern Delaware or on Marylands Eastern Shore, let me know and I can out you in touch with a very nice and talented young buck. I just told him to do his own thing. All I did was pick the blue color tone. Hope you all like his work.
Thanks for the comments. My daughter is designing some door art and I will post that hopefully soon. The doors need something as the vehicle is in primer now and without color it's just a lot of light gray. I hope to paint it all next winter.
I also like his work and the fact that he used a fatter line for the "Old Skool" look.! The use of colors really fits the truck well. Pinstripping is interesting in knowing what type of lines to lay down depending on what your stripping. Older rods look better with a fatter line while many other cars, trucks and bikes look better with a thin line. The low rider craze in many parts of the country really kept many strippers busy because these guy's want the entire car done pinstripped from the hood all the way back to the truck area and the dash board. I like the way it turned out. Jimbo
Guys, please, it's STRIPING. Stripping is something completely different that I enjoy seeing as much, if not more, than striping.
I can't believe that guys keep stripping pins. What is so special on stripping pins of all things? I like stripping women myself It really is funny when someone posts talking all knowledgeable about something and then uses words with a totally different meaning from the subject they are discussing.
Mike51Merc and Blue One, are you both happy now? I changed the post ***le. Now you can both go back to *****ing about another thread.
Just tryin' to help, no *****ing intended, but I bet you'll never make that same error again. You're welcome. By the way, nice striping job.
Mike51Merc, well you are right about not making that mistake again so I guess you did teach me (and others) something, so thanks for that. I was never a good speller so spelling something wrong is no shock to me. I was just busting on you. No worries brother! Now can you tell me how to stop a leak in my T5 at the speedo housing? It's a new speedo cable and housing so I am guessing the 'O' ring is bad?
The level is good and the angle is minimal so I'm guessing it is the O ring as I had it sitting with trans oil for several months and then I removed it to adjust the tunnel and bingo.....a new leak. Maybe I got some tiny piece of something in there or the O ring is just not seated. I will let you know if the new O ring fixes the problem.
