Hot Rods Radiator cap part number?
Discussion in 'The Hokey Ass Message Board' started by Michigander, Oct 22, 2015.
  1. Michigander
    Michigander
    This is driving me nuts. I want to walk into Carquest, NAPA, etc. and buy a radiator cap, but without a part number they are lost. It would be a Ford p***-car radiator 1937- 48 (not pickup) with either a 4 lbs. or 7 lbs. rating. Stant or whomever. Any part numbers?
    Otherwise, it's ordering through Mac's and waiting.
  2. Rui
    Rui
    Have you lookd at rockauto's? They usually have the parts's numbers.
  3. squirrel
    probably the reason you can't find it at the parts store, is because they don't sell them any more. Rock Auto doesn't list it either.
    Happy waiting
  4. Hotrodmyk
    Hotrodmyk
    Try Bob Drake #78-8100-B.
  5. Michigander
    Michigander
    Ordering is always on option, but walking in and buying one locally is the question. Perhaps the correct part will cross to a newer application, say farm tractor or something.
    All online part numbers are the old Ford PNs suppliers like to reuse that don't cross to a common generic part number.
  6. Bruce Lancaster
    Bruce Lancaster
  7. Michigander
    Michigander
  8. stillrunners
    stillrunners
    from dallas
    you sure it's not a pick up....or industrial Ford radiator....?
  9. thorpe31
    thorpe31
    from nor-cal
    Stant R5 4lbs and R6 7lbs fit a 1" deep neck
  10. Michigander
    Michigander
    The pickup uses the smaller ID cap, for the 'A' size neck. P*** cars thru 1948 use the 'B' size neck. Just can't find one with a seal deeper than 3/4".
  11. Budget36
    Budget36
    My buddy had the same issue, I'll see if I can track him down, but he put something in the neck so a "modern" cap pressure thingy <<<tech term there, would seal.
  12. Michigander
    Michigander
    I believe those are for the smaller 'A' size neck.
  13. Michigander
    Michigander
    I suppose a flat rubber washer/seal would help, as long as it doesn't block the overflow pipe.
  14. thorpe31
    thorpe31
    from nor-cal
    Stant R7, 4lbs, 3/4 deep 2.1 dia neck in on my 39.
    I can only vouch for the last 20 years
  15. cometman98006
    cometman98006
    you might try a good radiator shop. I just had my '41 chev pickup radiator recored and they gave me a new 7 lb cap.
