Projects A new '32 project of my own.
Discussion in 'The Hokey Ass Message Board' started by hot rod pro, May 3, 2015.
  1. hot rod pro
    hot rod pro
    from spring tx.
    Thank you. I'm really excited about this one.
  2. hot rod pro
    hot rod pro
    from spring tx.
    Started on the front floor. ImageUploadedByH.A.M.B.1444485496.384563.jpg ImageUploadedByH.A.M.B.1444485509.591854.jpg
    Tn. Trash likes this.
  3. hot rod pro
    hot rod pro
    from spring tx.
    Floor all fitted and tacked together. A bunch of little steps make up a mile! ImageUploadedByH.A.M.B.1444663453.589844.jpg
  4. 3wLarry
    3wLarry
    from Owasso, Ok
    looks like a bread pan for the dizzy well
    kidcampbell71 and loudbang like this.
  5. DDDenny
    Thanks Bubba, I wanted someone else to make that observation first, that's what came to my mind. I just wanted some company before I said it.
    I did something similar for sinking a well into a project floor for an e-brake handle.
    Bread pans to wheelbarrows......whatever works.
    Danny....
    Your build thread reminds me of a radio ad (I don't recall which one), it said,
    "We'll sell you the whole seat, but you'll only need the edge".
  6. 1-SHOT
    1-SHOT
    from Denton
    All three window needs is a frame
    3wLarry likes this.
  7. hot rod pro
    hot rod pro
    from spring tx.
    I used the best bread pan I could find. $7.99 at the grocery store.
    They use that line for the motor cross where I live.
  8. hot rod pro
    hot rod pro
    from spring tx.
    Larry has enough information by now to build a dozen cars. [emoji2]
    3wLarry likes this.
  9. That is a 1 lb. cake pan , you can also use them to make a mold if you have a gl*** car. Are you can just put nots and bolts in them.
    3wLarry likes this.
  10. Tn. Trash
    Tn. Trash
    I have a few with nuts, bolts, odds and ends. Actually got the idea from my grandfather, who also left me a good portion of my nut and bolt collection.
    Car is looking great Danny.
  11. RodNoc
    RodNoc
    from Kelso, WA
    There is no doubt you are a pro. Truly inspirational. Subscribed
  12. hot rod pro
    hot rod pro
    from spring tx.
    Thank you. Glad you like my project.
  13. Kiwi Tinbender
    Kiwi Tinbender
    Danny--Have you thought about using two sided MDO for your front floorboard? I have done this for years, used Marine ply too. The paper backing on MDO takes paint really well, and it really does insulate the driving compartment. I tried to get a customer of mine to do that on his 32 Roadster with a hot 355 and Tremec, but he went with a steel floor. On the way back from Puyallup a couple of years ago, his feet got so hot he had them off the floor and actually had the drivers door open going down the freeway to let the hot air out.....And yes, I know that heaps of Dynamat, carpet and the rest will alleviate some of that, but still.......Just a thought.....
  14. hot rod pro
    hot rod pro
    from spring tx.
    My truck has a wood floor, but I wanted a steel floor in this one. Dynamat and carpet is all it needs to control the heat.
  15. Frankie's
    Frankie's
    Thanks Hot Rod Pro
  16. hot rod pro
    hot rod pro
    from spring tx.
    Made some progress on my coupe. Column is in. Master cylinder pad is machined and tacked in. ImageUploadedByH.A.M.B.1445444860.227557.jpg ImageUploadedByH.A.M.B.1445444871.815975.jpg ImageUploadedByH.A.M.B.1445444882.687276.jpg
    kidcampbell71 and CTaulbert like this.
  17. TexasSpeed
    TexasSpeed
    from Texas
    That MC mount is neat!
  18. hot rod pro
    hot rod pro
    from spring tx.
    Thanks. Wait till you see the rest of the pedal ***embly. [emoji2]
  19. hot rod pro
    hot rod pro
    from spring tx.
    Brake and clutch pedals fresh off the mill. ImageUploadedByH.A.M.B.1445534828.756905.jpg
    murpa, loudbang, Pewsplace and 3 others like this.
  20. R35J1S
    R35J1S
    from Missouri
    Nice work. Do you have your own CNC machine or are you just that good with a manual machine?
    Sent from my SM-N900P using Tapatalk
  21. hot rod pro
    hot rod pro
    from spring tx.
    I have a HAAS VF-4 cnc mill and a HAAS ST-20Y cnc lathe.
    R35J1S likes this.
  22. R35J1S
    R35J1S
    from Missouri
    That's awesome. I would love to have my own CNC machines.
  23. hot rod pro
    hot rod pro
    from spring tx.
    It's been a dream of mine for awhile. I've had my mill since 2010 and I got my lathe last year.
  24. pscalz
    pscalz
    I saw your 32 this past weekend at Burnout Houston...pretty bad ***...!
    brokenspoke likes this.
  25. hot rod pro
    hot rod pro
    from spring tx.
    That's strange. I was at the bayou roundup that weekend. [emoji2]
  26. hot rod pro
    hot rod pro
    from spring tx.
    Got the pedal pad bungs machined and welded on.
    There are many steps in a mile. ImageUploadedByH.A.M.B.1445624257.357706.jpg
    kidcampbell71 and Pewsplace like this.
  27. pscalz
    pscalz
    My mistake...thought I had replied to another 32 post....clicked the wrong thread to respond to...like yours as well...I'm in Houston
  28. hot rod pro
    hot rod pro
    from spring tx.
    No harm, no foul. [emoji2]
  29. Imwalkin
    Imwalkin
    from Tucson, Az
    Dear Mr Hot Rod Pro.
    Please make a not so good looking part for this car and show it here. It would make me and sure other guys here feel better.
    Thanks.
    54reno likes this.
  30. hot rod pro
    hot rod pro
    from spring tx.
    I'll try. [emoji41]
