Projects Border Bandits Gas class builds to the Southeast Gassers rules.
Discussion in 'The Hokey Ass Message Board' started by II FUNNY, Nov 5, 2014.
  1. strokedstang331
    strokedstang331
    from Beloit WI
    Yea your set up would work just fine and actually I started doing it like that if u look at the frame down by my pedals I have the tube welded through the frame to do it like yours. I changed my mind a few weeks ago wanted to do something a little different so I dug out my stock pedals and started chopping lol
    beebee78 and 91whitestang like this.
  2. saltflats
    saltflats
    from Missouri
    Would the pedal swinging as to pushing have more to do with ones driving style or more to do with making room?
  3. Quain Stott
    Quain Stott
    I have drove both and can't tell any difference. Both ways are era correct, all the petals were under the floor in the early 50s. I just hate a z bar and don't want the master cylinder in the way on the fire wall is the reason I do them the way I do. But you would never know the difference setting in the seat.
  4. saltflats
    saltflats
    from Missouri
    Makes sense
    And I do like the simplicity of your setup.
  5. Quain Stott
    Quain Stott
    I'm lazy I always try and find the easy way LOL.
    OahuEli and saltflats like this.
  6. sonic03bluegt
    sonic03bluegt
    from sc
    Where's the updates????
  7. Dog_Patch
    Dog_Patch
    Saw a timeslip on the Meltdown thread. Someone was going pretty fast.
    strokedstang331 likes this.
  8. saltflats
    saltflats
    from Missouri
  9. strokedstang331
    strokedstang331
    from Beloit WI
    I'm working on headers rite now on the ford. Had to make a die to to D shape the tube to match the port in the head. I was at the track on sat with the coupe ran a 9.93 @143mph first p*** second p*** went 9.90 @ 138mph had a lean pop just before the traps so that's y the mph is off would have went faster. Had issues rest of the day made 2 more 10.0 p***es then the car died at the line will only idle has a fuel delivery issue I think gonna change the pump and see if it fixes it checked everything else I could think of at the track car just won't rev up falls flat on its face when u stab it.
  10. II FUNNY
    II FUNNY
    I mocked up the front axle brackets and hairpins, then tacked them together. Normally I would have just burned the brackets on, but I decided that a tig bead would look cleaner. I tig weld at work, but on nothing more than an 1/8" thick material, so I dropped it off at Jefferys and had him burn them on. ImageUploadedByH.A.M.B.1442975832.592776.jpg ImageUploadedByH.A.M.B.1442975848.931237.jpg
  11. II FUNNY
    II FUNNY
    Tonight I put the spindles and brake rotors on...the drilled and slotted rotors look gayer than a bag of fake ****s, but they came with the kit, and were a good deal. I will be switching to a set of standard rotors for final ***embly. ImageUploadedByH.A.M.B.1442975991.353343.jpg
  12. Quain Stott
    Quain Stott
    Good looking axle where did it come from. I like the gentle bends instead of the real sharp bends at the very end like the speedway stuff.. Yours looks like a copy of an old Don Long axle.
    powrshftr likes this.
  13. II FUNNY
    II FUNNY
    It's a new old stock MAS axle that I bought from the cl***ifieds...I bought it for the same reason you like it. It looks more correct than what's available today....it's also wider than speedway sells 51" kp to kp and only a 2.5" drop.
  14. Not sure if you noticed Kip, but those brakes look gayer than a bag of fake ****s.., just kidding man, use what you have now, and change em out as you can. We all know where your heart & head are at buddy.
  15. CGkidd
    CGkidd
    Where did you get the brackets for the axle? Looks cool
  16. II FUNNY
    II FUNNY
    The brackets are from speedway and the hairpins are from the Panneton Bros.
    beebee78 likes this.
  17. CGkidd
    CGkidd
  18. strokedstang331
    strokedstang331
    from Beloit WI
    One header all tacked together building them from scratch just a bunch of random bends cutting and welding together. All the tubes are pretty close to exactly the same length. They start with 2" then step up to 2 1/8" then to 2 1/4. The engine builder is Lance Line at Line performance he gave me the specs to get it pretty close for the motor. I have a buddy that Is a mechanical engineer so he drew them all up on his computer software first to make sure they were exact. Not sure if it makes to much of a difference but I atleast tried. The drawing made it easy gave me the degrees and length the tube needed to be. Was hoping to make greer but it's not gonna happen this year. The motor is breaking the bank and I don't want to rush anything on the car so I decided to just wait til spring and bring it out totally complete no loose ends.
  19. Quain Stott
    Quain Stott
    That's cheating using a computer design. Very nice looking work and it does make a difference when the tubes are the same length. If for no other reason they look right to someone that knows what a tuned header should look like. I've seen some that claim to know how to build headers with the tubes just run the best route and be 5" different.
  20. Dog_Patch
    Dog_Patch
    Jeff that's some nice work right there. Why do you increase pipe size as you go? I had a buddy who owned a muffler shop and he said the gases cool and get smaller as they go. He would start at a 3" pipe and end at the back of the car with 2.5" or 2". Is it different near the head?
  21. strokedstang331
    strokedstang331
    from Beloit WI
    I'm not exactly sure the reason for doing that. But I know all the expensive headers u buy are all stepped headers. I never would have guessed I needed to end with a 2 1/4" pipe though we were thinking smaller like start with 1 7/8" and go to 2" and that's it. But lance asked me all the specs and did some math for me and told me roughly how long to make each section and a total length to shoot for and said these should be pretty close to optimal performance. So I just did what he said. The tricky part was the port starts out D shaped. So I made a die to pound in the end of the pipe to make it match the port. It's kinda a pain to do but turned out great in the end. I'll post a pic of that tonight.
    Pufff, Dog_Patch and beebee78 like this.
  22. Quain Stott
    Quain Stott
    When the pipe size increases it causes a vacuum before the end of the charge to help scavenge the cylinder and cool the cylinder on the cam overlap. Tube length also has a vacuum on the tail end of the exhaust before it exits the tube. That's one reason length is important. If the length is different one cylinder is happy at low speed while some of the others are happy at high speed. Also the tubes should go into the collector in firing order to help each other. Really getting complicated now.
    Ric P can explain this a lot better to where it would make more sense, i can't get it into the right words.
  23. allwilly
    allwilly
    Usually exhaust velocity/scavenging is better when you reduce diameter in length. ..at least it showed more power in the 30 r so engines ive had dynoed
  24. allwilly
    allwilly
    Beautiful craftsmanship either way
    Dog_Patch and Quain Stott like this.
  25. 3dnsouth
    3dnsouth
    from North Ga
  26. II FUNNY
    II FUNNY
    I went past the point of no return tonight... ImageUploadedByH.A.M.B.1444179797.546079.jpg
    beebee78 and strokedstang331 like this.
  27. II FUNNY
    II FUNNY
    I saved the stock front frame horns...since this is going to have the Ford style front suspension I don't need heavy tubing all the way out front for strength.
  28. II FUNNY
    II FUNNY
    I have the tail pan and fin area panels in and rough ground. I also made the front frame rails. I hope to pull the body off and carry the Frame into the shop so I can start working on the ch***is. ImageUploadedByH.A.M.B.1445529212.420072.jpg ImageUploadedByH.A.M.B.1445529229.359658.jpg
  29. Another stock Tri-5 front clip headed where it belongs.., IN THE S**** HEAP, THAT'S WHERE!
    fast30coupe and II FUNNY like this.
  30. sonic03bluegt
    sonic03bluegt
    from sc
    Ya'll boys better get to busting ***, we expect y'all at the first race next spring!
