If everything is good, you should be able to remove the belt and turn on the key and the generator should motor. If it doesn't something is wrong. Just the way I tested them on the engine too many years ago.
Been years since I motored a generator, but pretty sure the way you describe won't work, I recall having to pull a wire off and jump something.
Can you explain motoring? The truck will run fine but the battery won't charge and the electrical system is my biggest enemy.
What brand of car....because of how you jump the field wire... if FORD only, a working generator will produce, if you put a HOT jumper to the FIELD terminal all other like GM and Mopar, you jump the field terminal to GROUND You should only do this with wires removed at the generator. Now put a voltmeter to the BATT or + terminal on generator. Then jump the field terminal while engine is at driving RPMs, but only jump long enough to see if the volts go way beyond the normal battery voltage. Jumping the field makes a generator run "wild" to very high voltage, so do it quickly. I use an older ****og meter with the needle, but it should also get a reading with a digital, I ***ume.
Oldnuts, If you are working on cars, you should have a voltmeter. They aren't expensive - hell Harbor Freight gives them away sometimes. Just sayin
Hey, what about the poor mans way of seeing if there is more than 6 or 12 volts, ..... When jumping the field, you are supposed to see perhaps two times or more, the normal voltage at around 1200 or 1500 rpms. So, what about using a small car light bulb, to see if the bulb burns out instantly? Just use a 12 v bulb on a 12v gen, or 6v bulb on a 6v generator....it should burn out quick. if it barely glows in the dark, that is likely only a couple of volts like you would see with shorted fields. ---or it may not glow at all. Just make sure the bulb works on the battery first
Sorry for the delay, busy in my shop. Motoring is when you supply electricity to the generator. If everything is good the generator will spin on it's own. When you spin the generator that is when it will produce electricity, then provided everything is good it will charge.
I've got a voltmeter but I've loaned it to a friend last week and he's out of town. It's a 63 ford yblock. I'm charging the battery and I'll use some of these tips shortly. Thanks fellas
So buy a DVM. They aren't expensive and have lots of other uses too. Anyone working on cars (new or old) can't get along without it.
