Hot Rods fitting a Model A coupe on a 32 frame...my way.
Discussion in 'The Hokey Ass Message Board' started by Standard32, Oct 25, 2015.
  1. Standard32
    Standard32
    from LA
    anthony coupe lift.jpg This is one of the projects I have in the works right now between other things.
    I never post much about stuff I'm working on....largely because I'm always doing multiple things and will jump back and forth....and I really **** at any kind of self promotion.
    Anyway, here's where I'm at...I'll post some more in the future when I move forward.
    What we started with was a coupe body that needed a lot of attention...and a really nicely built 32 frame from Gary Maxwell.
    I'm a big proponent of starting with the absolute nicest car/body you can find...but the customer has owned this for quite a while and it has some sentimental value,...so I'm making an exception and we're gonna work with what we've got!
    I started by trying to get it square before anything else.
    I swapped a better door, m***aged the hinges (they were tweaked), and aligned and braced the body once I got the doors and body lining up...
    I decided to fit the subrails to the frame first. So, I cut off the back of the subrails to clear the 32 kickup. Then after lots of measuring, I located the front of the floor (this is really critical, because this determines everything...including how the rear tire will sit in the wheel well!)
    I boxed the underside of the subrails around all mounting points.
    a shot of the front boxed area under the front of the door/cowl area...
    Then set the body on to see what we've got...
    and a lot more pulling/pushing to get everything where it needs to be...
    akoutlaw, Joel W, -Brent- and 4 others like this.
  2. Standard32
    Standard32
    from LA
    I then shaped some cold rolled flat stock to the rear kick up...
    made some mounting pads on the underside of the new subrails.. 17.jpg 18.jpg 19.jpg
  3. Standard32
    Standard32
    from LA
    Next was to start blending the transition between the factory and new subrail pieces...
    I started by widening a factory crosspiece...
    Here it is after widening and fitting...
    Then welded...and a sleeve added for the mounting bolt to p*** through...
      352.7 KB
      368.9 KB
    akoutlaw and Johnnee D. like this.
  4. Standard32
    Standard32
    from LA
    Then some more pieces to blend it all together...
    akoutlaw, A Boner, -Brent- and 5 others like this.
  5. Johnnee D.
    Johnnee D.
    great job, really clean...
  6. Standard32
    Standard32
    from LA
    patch panels always take some m***aging...
  7. Standard32
    Standard32
    from LA
  8. Hotrodmyk
    Hotrodmyk
    Very nice job!
    Standard32 likes this.
  9. prpmmp
    prpmmp
    Excellent Work!!! Pete
  10. Crusty Nut
    Crusty Nut
    Nice work, you should post more often...says the guy who is bad about taking the time to take pictures, let alone post them up.
  11. The37Kid
    The37Kid
    Great job! With welds like that this is one project I want to follow. The steel body blocks in place of the stock wood ones is a nice feature.Bob
  12. timwhit
    timwhit
    Very nice work and YES we want to see more!! Tim
    lothiandon1940 and Standard32 like this.
  13. brady1929
    brady1929
  14. Standard32
    Standard32
    from LA
    The lower b-pillar on both side was pretty much non existent...so I made pieces to splice in.
    I also replaced the factory gusset with one that's more stout...and then reattached the brace to it that goes up to quarter window wood.
  15. gnichols
    gnichols
    from Tampa, FL
    Excellent-O! Gary
  16. Standard32
    Standard32
    from LA
    the wheel wells were next... and were challenging with little/thin metal to work with...
    I'm really happy with the way it all flows from this view...
  17. Standard32
    Standard32
    from LA
  18. Standard32
    Standard32
    from LA
  19. Standard32
    Standard32
    from LA
    now back to the front...
    volvobrynk and Rich B. like this.
  20. Standard32
    Standard32
    from LA
    I made little pads to match the profile of the firewall... and welded them to the cowl piece.
    I wanted it to have a sorta pronounced "foot":
    then boxed the inside edge, and added a plate to the bottom to maintain the defined foot...but still keep stuff solid.
  21. Standard32
    Standard32
    from LA
    and worked my way up the a-pillar...
    akoutlaw and volvobrynk like this.
  22. The37Kid
    The37Kid
    This just keeps on getting better. Bob
  23. Blues4U
    Blues4U
    from So Cal
    Such clean work, very nice.
  24. 55willys
    55willys
    Rust repair takes a long time to do right after you make the customer understand that sentimentality costs a lot of money. Great job on the metal work, looks like I did it. please take that as a complement.
  25. vtwhead
    vtwhead
    very nice work. An inspiration as I work on mine!
  26. The37Kid
    The37Kid
    Just in case you were missing it this piece tacked to the subrail allows the cowl panel bottom to be attached to it. Snyders sells them. Bob AFTER Hersher 2015 235.jpg
    volvobrynk and Standard32 like this.
  27. jeta12
    jeta12
    Very Nice!!!...Will be watching...Thanks for posting.
  28. Bill Leland
    Bill Leland
    I've never taken on a body with such rust eaten panels, you're a brave man, skilled as well.
  29. 3wLarry
    3wLarry
    from Owasso, Ok
    the hell with the A, I can't stop looking at the 32
  30. Sky Pilot
    Sky Pilot
    nice job k he told me it was ruff didn't think it was that bad ----lookin great brother--- the deuce looked sweet too at the bayou round up
