Projects Handmade 27 roadster... Spare time build
Discussion in 'The Hokey Ass Message Board' started by toreadorxlt, Sep 24, 2015.
  1. tjn
    tjn
    from US
    Hi;
    Dimensions are as follows:
    Height of panel below decklid 10 1/2" (does not include the return bend that is underneath the decklid
    Height of the panel above the decklid 8 1/4" total (this height includes a 3/4" flat lip on top of the panel).
    Decklid length in inches 26 3/4" x 34 3/8" wide.
    If you want I can send pictures and more information. PM me if you want anything else.
    volvobrynk likes this.
  2. toreadorxlt
    toreadorxlt
    from Nashua, NH
    thank you so much!
  3. toreadorxlt
    toreadorxlt
    from Nashua, NH
    ImageUploadedByH.A.M.B.1445917529.054180.jpg ImageUploadedByH.A.M.B.1445917539.759075.jpg
    Started the main section of subrails, heat and bent them to fit the wooden template. They got a little tweaked. I will straighten them and clean them up. Not happy with them at all actually. But the stock seat riser fits...
    volvobrynk, bct and patmanta like this.
  4. 1952B3b23
    1952B3b23
    from Western MA
    What gauge are the sub rails?
    Whats the reason for using the wooden templates to make them? Are they to long or is the material to thick to bend in a traditional box and pan brake?
    Sorry for all the questions at once, just trying to see if i can think of a way to not use heat to bend them. Then hopefully save you a bunch of time trying to tweak them at the end. Good luck.
    -Chris
  5. bct
    bct
    Only the outside edge that the sheet metal folds over is curved on the stock subrails, from the b pillar forward.
  6. timwhit
    timwhit
    Very amazing for those of us without the skill and or tools. Nice work. Tim
  7. toreadorxlt
    toreadorxlt
    from Nashua, NH
    Thanks for that tidbit. Makes it even harder. Oh well, mine will be curved the whole way I guess . I revisited and remade a new subrail with a new approach today. Came out better. More Pics tomorrow
    Thanks!
  8. bct
    bct
    Yes it would be hard to reproduce unless it was a seperate piece then welded on.
    thanks for showing us your progress. I'm especially interested in the sub structure.
  9. bct
    bct
    i had this picture handy of the tulip sub structure.
    toreadorxlt likes this.
  10. patmanta
    patmanta
    from Woburn, MA
    This was my thinking on the subject. I've been pondering it since yesterday. You could do a 2 piece construction pretty much like what you have but make the side profile out of a piece of sheet run through a shrinker then cut and welded on to the rail tube.
    It would probably work best on a tube that's got an inverted T shape to it at the height you need it. You should have room to do something like that, IIRC the top of the rails is only 1.25" give or take (that's the size tubing I am using on mine).
    Curving your whole piece should work great for your body though, I'm just thinking in terms of stock panels and bracketry.
  11. JohnJoyo
    JohnJoyo
    Alliance Vendor
    from Austin, TX
    Great work, great thread!
  12. falcongeorge
    falcongeorge
    from BC
    Ditto. Man, that's some nice work!
  13. toreadorxlt
    toreadorxlt
    from Nashua, NH
    ImageUploadedByH.A.M.B.1446090053.534754.jpg ImageUploadedByH.A.M.B.1446090065.861362.jpg ImageUploadedByH.A.M.B.1446090075.100046.jpg ImageUploadedByH.A.M.B.1446090103.579979.jpg
    Lots of Safety and subrails happened tonight
  14. Gary Addcox
    Gary Addcox
    John, what are the plans for the '36 ?
  15. Pete
    Pete
    Steve,,,, looks great....
    So cool to be surrounded by talented people, and learn from them.
  16. wheeldog57
    wheeldog57
    He is good, REAL good
  17. pitman
    pitman
    Somewhere in Dearborn...Henry smiles as he discovers this thread!
  18. mike bowling
    mike bowling
    Sometime I've got to see what goes on between the "beating with the nylon mallet" part, and a finished roadster panel. Steve you are a Wizard ( and your "Dad"'s pretty sharp too!)
    BTW-What's the impact rating of that headgear? Looks like something from the Italian Renaissance.
  19. toreadorxlt
    toreadorxlt
    from Nashua, NH
    Thank you guys so much.
    ImageUploadedByH.A.M.B.1446175072.123249.jpg ImageUploadedByH.A.M.B.1446175091.649541.jpg ImageUploadedByH.A.M.B.1446175119.013885.jpg
  20. Really great work!
  21. toreadorxlt
    toreadorxlt
    from Nashua, NH
    Mike you are welcome to swing by anytime
  22. toreadorxlt
    toreadorxlt
    from Nashua, NH
    ImageUploadedByH.A.M.B.1446348894.389003.jpg ImageUploadedByH.A.M.B.1446348903.541027.jpg
    Rear subs started.
    wedjim and kidcampbell71 like this.
  23. bengeltiger
    bengeltiger
    So very cool! Can't wait for each post!
  24. patmanta
    patmanta
    from Woburn, MA
    You could probably make your money back on this build by making up a batch of these and selling them!:
  25. rtsidejohnny
    rtsidejohnny
    Amazing work, thanks for the details!
    What gauge on the rear subrails? More details would be great considering how many of these (rear subs) are cut off...mine included!
    Thanks again, johnny
  26. toreadorxlt
    toreadorxlt
    from Nashua, NH
    Rear subs are 16ga. Factory is 13, but open on be bottom. I feel 16 fully boxed is sufficient.
    ImageUploadedByH.A.M.B.1446482170.680843.jpg ImageUploadedByH.A.M.B.1446482210.083348.jpg
  27. toreadorxlt
    toreadorxlt
    from Nashua, NH
    ImageUploadedByH.A.M.B.1446607482.093644.jpg ImageUploadedByH.A.M.B.1446607492.947986.jpg
    One more night I'll have subrails
    wedjim and cactus1 like this.
  28. The 39 guy
    The 39 guy
  29. 1952B3b23
    1952B3b23
    from Western MA
    Man this is going way to quickly for a "spare time build" lol..... looks great Steve.
    -Chris
