Projects Norm's A build!
Discussion in 'The Hokey Ass Message Board' started by norms30a, Jan 11, 2011.
  1. pitman
    pitman
    There were knicknames (not mentioned!) years ago for dem carb's!
    Great job thus far Norm!
    norms30a likes this.
  2. norms30a
    norms30a
    Like Quadra junk,lol
    pitman likes this.
  3. norms30a
    norms30a
    Got some more done to the dash, and got the gas tank mounted today. 129 003.JPG 129 006.JPG
    Richie R and kiwijeff like this.
  4. norms30a
    norms30a
    For what it's worth, the little panel below the dash with the 4 knobs and vent in it, I hand made from a piece of sheet metal because I could not find anything I liked to put there. That was a days job.
  5. Nice work, that engine will fry the tires in every gear :D
  6. 1931fordtruck
    1931fordtruck
  7. norms30a
    norms30a
    Thanks guys, "fryin the tires in every gear" that would be sweet! I have only had 1 powerful engine before this, and it was in a heavy 70 Chevelle and I was kind of disappointed due to it being so heavy.
  8. LTM75110
    LTM75110
    Great build,like the chop and the color..
  9. norms30a
    norms30a
    Got my E brake working, the Lokar stuff was easy to work with. 130 002.JPG Painted my exhaust pipes with barbecue hi temp black. 130 004.JPG Had to cut and change the inlet by a couple degrees. 130 005.JPG 130 007.JPG Now both pipes are hanging the same.
  10. norms30a
    norms30a
    Made an alternator belt tightener, I would rather have gone the other direction but the hose gets in the way. 131 001.JPG 131 004.JPG
    AHotRod likes this.
  11. norms30a
    norms30a
    Really don't like my belt tightener so I made a wire pattern and went looking for a different hose 132 087.JPG I found a hose that will work much better 132 085.JPG I took a belt tightener from a 283 I have and, with some altering it will mount like Zips intended. 132 088.JPG
    Studebakermatt likes this.
  12. norms30a
    norms30a
    Been doing wiring, slow going but I got through it. 132 005.JPG 132 015.JPG 132 009.JPG I taped the wires to the back to the floor then covered them with metal so I don't have to worry about them. I ran metal all the way to the firewall. 132 010.JPG
  13. norms30a
    norms30a
    My E brake handle was hitting under the dash so I took the handle out and shortened it about an inch and a half. 132 018.JPG 132 021.JPG 132 024.JPG
  14. norms30a
    norms30a
    133 001.JPG 133 002.JPG 133 003.JPG Been a while since I updated, been busy with the farm but, I have done a few things. I finally finished the wiring and I got a drive shaft and got it in.
  15. norms30a
    norms30a
    133 007.JPG 133 008.JPG 133 011.JPG 133 013.JPG 133 006.JPG I also installed a trans. cooler at the advice of a friend so now the radiator and trans are separate. I have also finished with all the hoses .
  16. norms30a
    norms30a
    133 005.JPG Got some of my gl*** installed too.
  17. kidcampbell71
    kidcampbell71
    Wow ... been a bit, but man it looks great.
  18. norms30a
    norms30a
    Kid Campbell you have a really cool avatar ;^)
  19. norms30a
    norms30a
    It took a while to get the door gl*** working as the windows wanted to **** a little and jam. So after filing and sanding and narrowing the track, 134 027.JPG and ruining a couple C channels I got the door windows working well. I ended up shortening the p***. window arm almost 2 inches to center it better....
  20. ScooterCO
    ScooterCO
    from Parker, CO
    Getting SO... Close.
    Stay on it and you will be smiling ear to ear!
    The car is looking great.
  21. norms30a
    norms30a
    SO close is right, I tested the wiring yesterday to see if I had wired it right. Everything worked, lights, radio, turn signals. The only problem was it would not turn over :^(. I am using a Dakota Digital neutral safety switch and I had hooked the power up to the radio feed. The radio and gauge feed shut off when cranking the engine which I did not know until I read the Ron Francis instructions carefully, geeeeez. I hooked the neutral switch to the wiper feed and it cranked over, yea!
    When I cranked it over without the plugs in it it showed 30 psi oil pressure----good. I was able to program in the gear locations to the Dakota Digital unit so, I think all the wiring is good. 135 005.JPG P is for park ;^)
  22. BLUECOLLARKUSTOMS
    BLUECOLLARKUSTOMS
    Looks good, your making good progress. The Vintiques run is only a few weeks away, any chance on making it the maiden voyage?
  23. norms30a
    norms30a
    Thanks bluecollar, I hope to get it running in a few days. I'm sure the first drives will be within walking distance from home until I get my nerve up, at least for a while. The Watertown event is awesome, I encourage anyone who is thinking about going to a car show to go to Watertown SD. and take in the Vintiques event, you won't be sorry, those guys do a ton of work and have so much enthusiasm for the hobby it's crazy.
  24. aplayer
    aplayer
    I ended up shortening the p***. window arm almost 2 inches to center it better....[/QUOTE]
    I did the same on my 33 truck doors. Looking good!
  25. norms30a
    norms30a
    I test fitted the windshield with the rubber attached and found it a little loose at the top so I made slots in an attempt to tighten it up. I have a feeling the windshield will leak some. 135 001.JPG 135 002.JPG
  26. norms30a
    norms30a
    I have had it running and after calibrating the speedo as well as I can I put the cowl and windshield on. The windshield will leak so I will try some weatherstripping here and there to try and minimize the leaks. 136 013.JPG
  27. norms30a
    norms30a
    I have decided to go a little more traditional with my headlights, so smaller ones went on yesterday. 136 012.JPG 136 015.JPG 136 016.JPG
  28. R35J1S
    R35J1S
    from Missouri
    I can't decide. I like it either way. Good looking ride.
    Sent from my SM-N900P using Tapatalk
  29. IowaMercMan
    IowaMercMan
    Norm I like that look with one big light and one small light. reminds me of the Bill the Cat cartoon
    Jet96 and norms30a like this.
  30. Imwalkin
    Imwalkin
    from Tucson, Az
    I like the big-uns.
