home made tools and equipment...
Discussion in 'The Hokey Ass Message Board' started by kustombuilder, Jan 16, 2008.
  1. Eljorger
    Eljorger
    Rail Road Rail anvil....not done but real close....Thanks for the motivation Brent. Stand and paint to follow. 20151016_175912.jpg 20151016_175912.jpg 20151016_175923.jpg 20151016_175923.jpg
    whtbaron, 35PU, Rich B. and 1 other person like this.
  2. Fred D
    Fred D
    from Houston
    Needed a wrench to remove the clutch fan on my 5.9 ***mins.
    Dieselcatfish and loudbang like this.
  3. bct likes this.
  4. Eljorger
    Eljorger
    20150908_180916.jpg 20150908_180922.jpg 20150908_180922.jpg 20150926_135153.jpg 20150926_135158.jpg 20150926_135207.jpg 20150926_135217.jpg 20150926_135225.jpg 20150926_145711.jpg 20150926_145717.jpg 20150926_145726.jpg 20150926_145732.jpg 20150926_145744.jpg 20150927_115319.jpg 20150927_115323.jpg 20150927_115335.jpg 20151022_165403.jpg 20151022_165417.jpg 20151022_165428.jpg 20151022_165444.jpg 20151022_165452_001.jpg 20151022_165502.jpg 20151023_114517_001.jpg 20151023_114524_001.jpg 20151023_114524_001.jpg 20151023_115315.jpg 20151023_115332.jpg 20151023_115459.jpg 20151023_115504.jpg 20151023_140313.jpg Rescued from the back yard after almost 20 years.... 20150908_180900.jpg 20150908_180906.jpg
    dos zetas, loudbang and Ulu like this.
  5. Eljorger
    Eljorger
    20151023_192727.jpg 20151023_192727.jpg 20151023_192736.jpg 20151023_192736.jpg 20151024_154853.jpg 20151026_171427.jpg 20151026_171441.jpg 20151026_171513.jpg 20151027_163222.jpg Well here is my vice that I rescued from my back yard....been back there since I closed my Car Stereo shop in 96....been awhile, but its back at work and portable (sort of...lol)
    Ulu, bct and J. A. Miller like this.
  6. Mister T
    Mister T
  7. Mister T
    Mister T
    Any tool that will give me that home built look instead of that $350,000 Riddler Award look is what I need. You can't beat the look of hand made whether a louver, a bracket, a mount, whatever. Just make it different, make it neat, make it look like it belongs there.
    lawman, cptn60 and Eljorger like this.
  8. Eljorger
    Eljorger
    20151016_175935.jpg 20151016_175946.jpg 20151017_132406.jpg 20151017_132450.jpg 20151019_070817.jpg 20151019_073649.jpg 20151019_081215.jpg 20151106_114547.jpg 20151106_131818.jpg 20151106_152150.jpg 20151106_153407.jpg 20151106_163523.jpg 20151106_165239.jpg 20151106_175520.jpg 20151106_190146.jpg 20151107_122958.jpg 20151107_123929.jpg 20151107_125210.jpg 20151107_133437.jpg 20151107_145224.jpg 20151107_145234_001.jpg 20151016_175935.jpg 20151016_175946.jpg Anvil complete...., Bandsaw, drill press, lots of grinding, a flywheel as the bottom base and some primer and paint....not too shabby. and I have another to finish....a larger one I was able to get as a bonus when I bought my used drill press off Craigslist. 20151016_175935.jpg
  9. 1949 caddyman
    1949 caddyman
    from arizona
    Nice anvil, is that a piece of rubber between the anvil & its base plate?
  10. Eljorger
    Eljorger
    Yes, it is...cut a piece of a door mat to prevent the anvil from ringing too much.....worked well.
  11. seb fontana
    seb fontana
    from ct
    Hand Truck Tanker
    I got tired of lifting gas cans..One electric pump, old hand truck, bungie cord. Pump runs on 4 AA batterys, so far has pumped 15 gallons on first battery set and even has an automatic shut off built into the clip on nozzle..
    lawman and David Gersic like this.
  12. bjinx
    bjinx
    Here is my take on a tool to straighten the fender bead on my Model A
    pat59, Johnboy34, lawman and 7 others like this.
  13. Eljorger
    Eljorger
  14. heyitsnate
    heyitsnate
    I have made several of these cp style hammers.
    sko_ford, bengeltiger, lawman and 2 others like this.
  15. Show us some more pictures of this cp style hammer, how is it driven
    RICH B, Rich B. and 54reno like this.
  16. heyitsnate
    heyitsnate
    Uses a cp motor,compressed air. Excuse the mess in the background!
    sko_ford and stealthcruiser like this.
  17. Ulu
    Ulu
    from CenCal
    So is a pneumatic preferred over a mechanical hammer?
    Or vice versa?
    Are there clear advantages of one type over the other?
    I was considering making one that just runs from an electric motor with a fork & cam-action mechanism that works both ways. (Like desmodromic valve lifters on a Ducati.)
  18. gatz
    gatz
    Made this anvil from a chunk of rail, way back in '73 or so. It's been sitting on my bench since then.
    Didn't know much about making tapered parts at the time I was attending community college, so this was really winging it.
    Drilled a center-drill hole at the back or "hanging" end, and another at where the point would end up.
    Kinda half-***ed guessing what the angle would be.
    Chucked it up in a big ol' lathe and set to work making the bick (I had to look up the parts of an anvil).
    The 1/2" sq hardy hole was a PITA to make.
    And, in case anyone is curious, these are the features of an anvil
    tenlug, JOYFLEA, Eljorger and 4 others like this.
  19. Eljorger
    Eljorger
    Here are a couple of tools I fabricated over the thanksgiving weekend. One is is a set of six(6) triangles for aiding in leveling a welding project on uneven concrete or floor. The other is a a pair of clamps to hold two pieces of round stock to be "****" welded together. Mind you, both of these ideas were found while surfing the net, so I cannot take credit for these.
    although I did add a 1 1/2 inch hole to the tube clamp, to be able to weld from underneath. And yes I did use the tube clamp before I painted...just had to try it out....lol. 20151120_090902.jpg
    bct likes this.
  20. twenty8tudor
    twenty8tudor
    from Ohio
    my contribution...
    rollers for straightening line
    only used it on 1/4" and 3/16" so far seems to work pretty good
  21. saltflats
    saltflats
    from Missouri
    I caveman together this stamping die to make some spears for a dash project I have been working on. 20151129_123056.jpg
    lawman, heyitsnate and biggeorge like this.
  22. twenty8tudor
    twenty8tudor
    from Ohio
    Figured I would throw this up as I used it again tonight...
    Pretty simple slide hammer and threaded the end to thread the attachment on that has the same thread as the end bolt as the vise grip..
    The you can attach any vise grip to it.. I made the end before I had a lathe so it's kinda crude haha
    lawman likes this.
  23. ago
    ago
    from pgh. pa.
  24. bkap
    bkap
    Cool. Any photos on how you made and use this?
  25. saltflats
    saltflats
    from Missouri
    I took a peace of round stock and ground a flat side on it then shaped the point.
    Then found a peace of s**** plate stock and went after it with my polish bridge port aka die grinder to shape the female die.
    Now after some practice I found that I needed a guide or should I say a stop for the sheet metal and my female die so I welded the spear and some more s**** on a plate for my stop.
    Then its a trip to the shop press and pump away. 20151130_200228.jpg 20151130_200251.jpg 20151130_200324.jpg 20151130_200535.jpg 20151130_200654.jpg
  26. bkap
    bkap
    Nice. Thanks.
  27. heyitsnate
    heyitsnate
    I made some press dies for 36 ford wheelwell/subrail details. They have locating pegs with a depth mark on them. Press until you see the mark and you know its the same depth as stock
    Fender1325, cretin, Ulu and 6 others like this.
  28. RICH B
    RICH B
    Needed a spring compressor for a nailhead today.
  29. That is very nice Ulu, looks like something a sailor might do to p*** the time. You don't happen to be a former canoe club veteran?
  30. T Hudson
    T Hudson
    My freestanding vice. The base is an old cream separator stand.
    Roadsir and saltflats like this.
