Technical Tips for moving cars in the dirt?
Discussion in 'The Hokey Ass Message Board' started by alteredpilot, Oct 23, 2015.
  1. rusty1
    rusty1
    ...and still no pics...
    kiwijeff likes this.
  2. 69supercj
    69supercj
    Instead of using paper cardboard find some plastic cardboard like they use for real estate or political signs, it will slide much easier and hold up better.
  3. rusty1
    rusty1
    we could've all went over there and picked it up and moved it by now.
    chiro, Chrisbcritter, Cosmo49 and 3 others like this.
  4. SmoKerch
    SmoKerch
    Wesson oil and a rubber sheet.
    Donald A. Smith likes this.
  5. stimpy
    stimpy
    neighbor used a pieces of upside down countertop with some soap under it, on sheets of chipboard even without soap it slides easily . even slides easy on dirt with a little water .
  6. xpletiv
    xpletiv
    from chiburbs
    "Wesson oil and a rubber sheet."
    ^Stay on topic!
  7. NORSON
    NORSON
    Buy a high-lift jack. jack it up and push it over. I've moved cars, cargo containers and machinery for years this way.
    Norm
  8. Tn. Trash
    Tn. Trash
    Power of the H.A.M.B. :D
  9. rusty1
    rusty1
    so,....did you ever retrieve this car?
  10. David Gersic
    David Gersic
    from DeKalb, IL
    He's probably still reading all of the suggestions here.
    kidcampbell71 likes this.
  11. exterminator
    exterminator
    Lets see a picture of the car.
  12. czuch
    czuch
    from vail az
    Check ER-3.
    Wesson and a plastic sheet!! WOOOOHOOOOOO!!!
    To tired to move a car now.
  13. blackrat40
    blackrat40
    He may be pinned beneath it. :eek:
  14. King ford
    King ford
    from 08302
    Buff out the roof , roll it over.......WAIT NO PICTURES YET.....
  15. gimpyshotrods
    gimpyshotrods
    Someone better go check....
  16. DDDenny
    Here's a picture of what works for me.
  17. ski
    ski
    from San Diego
    When I was in the Navy, sometimes in heavy seas our helicopter would slide sideways in the hanger even with 24 tie down chains. On a small boat there's about 6 inches of clearance on each side an absolutely no way to manuver it. Solution was to get a piece of sheet metal for each wheel set, grease it up real good and slide it under each tire. An eighth inch is enough. No jacking required. Ten guys could push a 20K lb helo one end at a time sideways to clear the door with ease. Jacks, dollys and plywood would work too like suggested. Is it out yet?
