Customs 1950 Pontiac Driveshaft woes....advice needed
Discussion in 'The Hokey Ass Message Board' started by Ragtops Forever, Oct 30, 2015.
  1. Ragtops Forever
    Ragtops Forever
    from Poole UK
    Hi.
    I have a 50 Pontiac convertable which has been slightly rodded.
    At some point in its life it's had the original motor and trans swapped for a Pontiac 400/TH350 from, I'm told, a 67 GTO.
    The rearend seems to be the original one but the driveshaft has run into some problems. It started vibrating and investigation revealed that the rear u-joint was in trouble. It's a strange looking set-up as the u-joint goes directly into a pair of bearing blocks with cleats that bolt to the pinion flange. The u-joint has damaged one of these blocks and these now need replacing.
    I'm also not so sure that the driveshaft itself is 67 GTO as the parts listed for the u-joint should be a 1 1/8" one and the one I need to replace is a 1" diameter.
    My problem is two-fold:
    First I need to know if this bearing block deal is indeed original to the car and if so where I could find replacements.
    Second, if I can't get replacements, I'm looking for another way to get the driveline back together again.
    Here's a couple of pictures of what I mean by bearing blocks.
    Any help would be greatly appreciated
  2. TudorJeff
    TudorJeff
  3. J Twitero
    J Twitero
    from Minnesota
    Also looks similar to the rear u-joint on my '52 Ford, was able to get it at NAPA, comes with 2 of those instead of the "normal" caps on all 4.
  4. ROADSTER1927
    ROADSTER1927
    My 40 Pontiac had that setup also. When I put the v8 and four speed in it with a chevy drive shaft, I actually looked through an old u joint book and bought 2 u joints and swaped the caps to get the spacing I needed. It was pretty easy. Gary
  5. stimpy
    stimpy
    you can still get that style its called a saginaw U joint a good driveline shop should be able to order them o have them in stock as they use them on some heavy equipment
  6. Ragtops Forever
    Ragtops Forever
    from Poole UK
    Thanks fellers............easy when you know what you're looking for.
    Now I'm a happy camper.............!!!
