Hot Rods Roadster build.
Discussion in 'The Hokey Ass Message Board' started by bct, Oct 21, 2015.
  1. bct
    bct
    I found a really nice stock 32 frame for my 28 roadster. I've been gathering parts for years and have a 48 flatty and 38 trans. Ive done plenty of searches but can't find what i need.
    What parts do i need for mounting trans to 32 K member . I found the rubber mount part aftermarket but is there a spacer i need too?
    Who makes nice engine mounts that work well with an unboxed frame.
    Starting to think about pedals too. Feel free to send me in the right direction.
    Thanks
    dana barlow and chop job like this.
  2. bct
    bct
    RodKnuk likes this.
  3. clem
    clem
    Looks like you are doing well without us.........
  4. ratamahata
    ratamahata
    from Argentina
    Hey bct, I know for a few post over The Hamb... You will modified the toploader by taking off the support and change to the model B support....
    bct likes this.
  5. ratamahata
    ratamahata
    from Argentina
  6. MN Stumpjumper
    MN Stumpjumper
  7. rusty rocket
    rusty rocket
    My pops is building an A v8, for motor mounts we used a piece of 3" x 1-1/2 rectangle stock and made the mounts with some nice radius on them. He bought a set of stock biscuts also. Ill try to find a picture.
    bct likes this.
  8. rusty rocket
    rusty rocket
    DSC02759.JPG ****y picture but maybe this will help.
    bct likes this.
  9. orangeamcs
    orangeamcs
    You can get mounts from tardel I think
  10. bct
    bct
    Thanks for that. What parts are 32 and what are later. I know i can buy the mount but is there anything else i need?
  11. orangeamcs
    orangeamcs
    Does someone reproduce these complete mounts?
    bct likes this.
  12. bct
    bct
    I did some more research after posting and it mentioned that between sacremento vintage ford and tardel you can get the parts. I think i have a couple pre 37 trans that i can use the stuff from. I'll check this w/e.
  13. bct
    bct
    Now to figure out what rear spring? Had no idea that the 32 mount is curved. 85yr old stuff and its all new to me.
    Doctorterry likes this.
  14. Duke
    Duke
    You can grind the 35 and newer spring to fit. I have seen it done on old hotrods with 40 rears. Curved springs are 32 to 34. Where did you find the frame?
    bct likes this.
  15. bct
    bct
    Kamloops
    jordabennett likes this.
  16. dumprat
    dumprat
    from b.c.
    32-34 rear springs are around.....
    bct likes this.
  17. RICH B
    RICH B
    If you do use a '32-'34 spring, you are limited to either using an early banjo or changing the spring hangers on a later rear. If you grind a '35 up spring to fit the '32 crossmember you can use a later banjo rear as is.
    bct likes this.
  18. bct
    bct
    I have a 40 rear and spring. I am ***uming you just need to hollow out one side of the spring pack to clear the curved member? How deep ? Must not be much .Sorry i dont have all the stuff in one place.
  19. rusty rocket
    rusty rocket
    Im sure you could transplant a later model rear cross member.
  20. sanfordsotherson
    sanfordsotherson
    from So. Cal.
    A Model 'A' rear crossmember & spring works and looks great. Not sure if the 'A' spring is the same length as the '40 spring though. I think it is...
  21. orangeamcs
    orangeamcs
    Will Model a spring will work on any of the spring behind rearends? With a model a crossmember of course.
  22. Here is a top view of a '32 spring IMG_8317.jpg I just sold.
    Charlie Stephens
    bct likes this.
  23. RICH B
    RICH B
    Sure; but usually only used on a deuce frame to gain room for a quick change.
  24. RICH B
    RICH B
  25. bct
    bct
    Thanks for the info all ! Trying to build this in my head before i start for real.
    I will leave the frame stock as possible. Considering the cost I'm not going to start cutting . Might not pinch even.
    I collected aftermarket rails, 39 x with pedals , 40 rear cross and a nice A front crossmember before i found this stock frame. I feels good to be using the real deal and worth the money as i like antique.
    I found a donor trans in my pile for the mount parts so that is sorted. car003.jpg
    Here is the body. I sold everything else.
  26. bct
    bct
    What's the deal with unsplit bones? I will be running a 48 8ba . Is there a certain width front yoke i need or will they all work. I think i will be splicing a yoke on to some late 40s bones. TIA!
  27. alchemy
    alchemy
    A wider yoke like a 32-34 will work best to move the wishbones toward the outside to miss the oil pan. It gets close on low cars in the flywheel area. Sometimes you can buy yokes from guys who split their wishbones.
    bct likes this.
  28. Bruce Lancaster
    Bruce Lancaster
    Mount...the flat plate from '32 that actually bolts to the frame and the rubber ring are reproduced. The casting can be sourced from a late model car, '33-36 with the 2-ear types of mounts...that means look for the rubber ring in there, if you see that you have the kind you need to cannibalize.
    Pete Van Seggern on the barn did a nice pictorial of the work on a late spring. Nothing too dramatic.
    You want Hurs a-28 mounts that bolt to the inside of the frame channel...Tardel sells new ones essentially identical. All others I know of are short to weld to a boxing plate.
  29. bct
    bct
    Thanks bruce. Those are exactly what i have in mind. Found this pic you posted earlier via google .
    Was there only one sized p***enger car /truck trans 33-36.? I have one but man it looks tiny.
  30. bct
    bct
    my frame. Super excited about this!
    kidcampbell71 likes this.
